Question about Maytag 25.6 cu. ft. Side-By-Side Refrigerator with 5-Button Ice and Water Dispenser
Water/ ice issue
Hello! About a month ago the water from the door of the fridge started to just trickel out - so I went and bought a new filter - nothing - spewed water when i first chaned it and then back to the sam - the ice make make cubes that are hollow - obvioulsy a water intake problem but where do I start to figure out what's wrong? thanks! My fridge is a Maytag side by side msd2651hew model -- thanks again!
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 162 Answers
This problem is either low water pressure or a faulty water inlet valve. if u have good pressure, change the valve. repairclinic.com
Posted on Jul 26, 2009
Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Jul 04, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice tastes bad
If It were me I would change the filter in the fridge, that always worked on mine.
Dec 03, 2013 | LG LRFD22850 Bottom Freezer Refrigerator...
Where is the filter?
the filter is inside the water line.
Sep 16, 2009 | KitchenAid KSCS25FKSS Side by Side...
Ice dispenser won't work, light won't work.ge side by side fridge
A GE uses a 12 volt bulb . It will not come on , if you went and bought a bulb with the same receptical end . HAS to be a 12 volt .
Sep 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
WATER DRIPPING FROM DISPENSER IN DOOR. GE Model TFX20JRBG WH
You are correct. this is actually a faulty inlet valve(dual) assembly. replacing this faulty valve will fix this issue.
Jun 19, 2009 | GE GSH25JFR Side by Side Refrigerator
Ice tastes bad from ice maker
Sometimes filters have issues like this even being new , it is located at the bottom kickplate [round] , pick up a new filter -part number 4396841 - install the filter , dump remaining ice in bin out , purge the water through the new filter through water in door for a few minutes and you should be good.
Phil
Apr 14, 2009 | KitchenAid Superba Architect KSCS25INSS...
Particles in ice cubes
Most new water/ice systems have break-in procedures in the manual, including flush a couple gallons of water through the water dispenser and disposing the first 24hrs of ice.
Are the particles present in the filtered water before adding ice? If so, you can probably assume the contamination is from the water tank so you should flush several gallons of water through the system to get rid. If the particles are present after adding ice, try pulling out the ice bin and dumping the ice.
Dec 30, 2008 | Whirlpool ED2FHEXN Side by Side...
My new Whirlpool Refrigerator the water and ice still stink
We have the same problem. Started 2 weeks after purchase. (6 months ago). Tech. replaced fliter, worked for another 2 weeks, then water & ice awful again. Tried to live w/ it - ordered another filter a week ago. Replaced & within 24 hrs. problem was back. Called Whirlpool. Said tech who came to my househad written in his report that tap water & fridge water tasted the same. A lie - he agreed w/ me that the water from fridge was bad, & replaced filter which had a musty odor. Whirlpool basically called me a liar but agreed to send another tech to check it out. I will never buy another Whirlpool product & plan to tak this problem as far as I need to in order to get satisfaction. This is ridiculous!
Dec 19, 2008 | Whirlpool Refrigerators
Bad water & ice cube taste
Hello redwood City
Welcome
You said,
Your Kitchenaid Superba KSRG25FKBL15 has bad tasting water and ice cubes. You replaced the copper tubing which delivers the water to the fridge and that didn't help. You replaced the copper tubing again with plastic tubing...no better. Any suggestions? Your tap water doesn't taste this bad.You bought a Kenmore french door fridge with water dispenser in the door in July 2008. The fridge has a filter. A few weeks after the fridge came the water and ice started tasting really bad, unlike any bad water taste I have ever tasted. And your tap water is fine. The bad taste appears to be random. Sometimes you get a cup full of nasty water and sometimes it tastes fine.
First you must know you have a 1 year warranty and can have them come out to fix anything, no charge.If it persists. You will have to get tough and you , MUST INSIST THEY REPLACE YOUR FRIDGE
When installing the water line these were a part of the directions!
Did you do this before connecting the water line to your fridge?
"Place the free end of the tubing in a container or sink, and
turn ON the main water supply. Flush the tubing until water is
clear. Turn OFF the shutoff valve on the water pipe. Coil the
copper tubing."
Whirlpool remedy
Off-taste, odor or gray color in the ice
1.Are the plumbing connections new, causing discolored or
off-flavored ice? Discard the first few batches of ice.
2.Have the ice cubes been stored too long? Throw old ice
away and make a new supply.
3.Does the freezer and ice storage bin need to be cleaned?
See “Cleaning” or “Ice Maker and Storage Bin.”
4.Has food in the freezer or refrigerator been wrapped
properly? Use airtight, moisture-proof packaging to help
prevent odor transfer to stored food.
5.Does the water contain minerals (such as sulfur)? A filter
may need to be installed to remove the minerals.
6. Is there a water filter installed on the refrigerator? Gray or
dark discoloration in ice indicates that the water filtration
system needs additional flushing. Run additional water
through the water dispenser to flush the water filtration
system more thoroughly (at least 2 to 3 gal. [8 to 12 L] or 6 to
7 minutes initially). Discard discolored ice.
Let me know what works,
Thank You ,
HUUUM!!
Please remember to leave a rating.
Sep 25, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
247 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
