Question about Radio Communications
I cant pair my with my pbt100 even though the led light is on
I want to reset my HBS 900 to my phone I have a ZTE from cricket how will I be able to do that
Your manual is here. You just need to go into the Cricket settings and go to Bluetooth and Pair. You don't have to reset the headset.
ENG
1) Easy Pairing a) Slide the Power switch to the ON position. b) If it is your first time pairing the device it will automatically enter pairing mode. If it has been paired but no paired device is in range it will enter pairing mode after 10 seconds. • The LED indicator will be solid blue. c) On the device you wish to pair, find the Bluetooth menu and search for or add new devices. d) Select LG HBS900 from the list of devices. e) If asked for a Pass/Pin Code enter 0000 (4 Zeros). f) Once the devices are paired, you will hear “Your headset paired.” • The HBS-900 will automatically turn off if not paired within 3 minutes. 2) Manual Pairing (pairing with another phone or re-pairing) a) With the power off, press the CALL button and slide the Power switch to the ON position at the same time for 2 seconds. b) When the headset enters Pairing Mode, the LED indicator will show a solid blue light. After the procedure repeat Easy Pairing steps c though f.
http://www.lg.com/us/support-product/lg-HBS-900#manuals
Sep 23, 2016 | ZTE Cell Phones
Big Ble / iphone 5s pairing
clear any past stored passwords. reset unit and put into discovery mode. Usually holding the pair button for a few seconds puts the LED blue into fast flashing - discvery mode
Apr 09, 2014 | Brookstone Big Blue Live Wireless...
Viper fob unpairs after car battery removal. Antenna indicator LED never lights up even when doing the re-pair procedure. wut?
The first problem is, you went to bestbuy. The second issue is the remote should not lose the pairing because the battery was removed. Your remote is probably defective.
Nov 19, 2012 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Explorer 320 will not pair with ipod touch
After researching the web, this is what's recommended for your Explorer 320, even though it's an older model. You need to put the headset into pairing mode, the LED on the headset must be flashing red/blue, red/blue when it is in pairing mode, then the phone will be able to find the headset.
Good luck from Headsets Direct - 800-914-7996.
Aug 11, 2011 | Plantronics Explorer 320 Wireless Headset
My razor appears to have died even though the LED
Usually the batteries last only a few years before needing replacement. Rechargeable batteries are good for only so many cycles so you've done well to go 8 years. You can replace the batteries if you're handy with a soldering iron - I've done it many times. However, with 8 years on the clock you'll probably want to replace the blades too. The batteries are about $10 for the pair (AA rechargeables with solder tabs) and the blade set is about $30 so you're approaching the cost of a new shaver already. Here's a link - you'll need two.
http://www.zbattery.com/NiCad-AA-1000mAh-Rechargeable-Battery-with-Solder-Tabs
Apr 18, 2010 | Norelco SmartTouch 9160XL Electric Shaver
Headphone symbol though no headphones in so cant talk to people
It sounds like your device may be paired with a Bluetooth headset. Try turning off bluetooth connectivity and see if that fixes the issue.
Oct 25, 2009 | HTC Hero Smartphone
Elddis caravan porch light bulb blown cant remove cover
Take a pair of safety glasses, work-gloves, and a hammer, and swing the hammer to break the cover. Remove the whole unit, and replace it with an energy-efficient LED light & socket.
Apr 23, 2009 | Computers & Internet
Free Pulse
The following procedure will re-establish the communication link between the Headphones and the Wireless adapter, this is called "pairing". Before you start please make sure both the headphones and the wireless adapter are fully charged and turned off.
Note: The headphones and the wireless adapter come pre-paired from the factory.
1. Press and hold the power button on the headphones. See Figure 1.
Figure 1
2. Continue to hold the button down until the LED starts flashing red/blue in an alternating pattern. Release the button when the LED starts flashing red/blue. See Figure 2.
Figure 2
3. Once the headphones LED is flashing red/blue, press and hold the power button on the wireless adapter. See Figure 3.
Figure 3
4. Hold down the button until the LED starts flashing red/blue in an alternating patter. The LED will blink blue, then turn off for a few seconds then blink red/blue. Release the button when the LED starts flashing red/blue. See Figure 4.
Figure 4
5. Once both the headphones LED and the adapter LED is blinking red/blue, press the volume up button once on the headphones. See Figure 5.
Figure 5
Once the headphones is paired with the adapter, the LED on the headphones will blink blue once every two seconds. See Figure 6.
Figure 6
When the adapter is paired the LED will be solid blue. See Figure 7.
Figure 7
The adapter may continue to blink red/blue for a few seconds even after the headphones LED starting blinking blue. This is normal; the adapter may take a few additional seconds before the LED turn solid blue.
Once the headphones and the adapter are paired, it is not necessary to pair them again even if the batteries on both units are completely drained.
Additional Note: Repeated pairing will not improve the sound quality or give the headphones and the adapter a cleaner connection.
Mar 11, 2008 | Logitech FreePulse Wireless Consumer...
Trouble pairing my bluetooth Macally BT micro mouse
Q: After pairing my mouse, the button click works but cursor tracking does not move. What can I do?A: The cursor tracking problem is because red sensor LED is not on. Please try another set of battery or fully charge battery again, and verify if bottom red LED turns on. If red LED still does not turn on, please remove batteries from mouse, press and hold the pairing button for 5 seconds, next press and hold the left and right buttons simultaneously for 10 seconds, followed by several clicks. Install the battery into mouse, you should see red LED turns on, mouse cursor will move.
Oct 03, 2007 | Macally BTMicro Mouse
Radio Communications Logo
44 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
