Question about Sewing Machines
Bernina 930: the thread pops out of the uptake lever every few seconds of sewing.
  • Sewing Machines Master
  • 11,462 Answers
Be sure that when you thread the top thread, the presser foot is ALWAYS IN THE RAISED POSITION.
I have a different machine with the opening on the top of the take-up lever and the thread "jumps" out when I sew fast. I simply folded a piece of tape over the top of the opening and it doesn't jump out anymore... Just create something that will close the opening at the top.
Posted on May 14, 2017
How to adjust stitch length on my 930 record? I need to make length longer.
On the right side of your machine, there is a lever that moves up and down that has lines marking 1 through 4. Setting it on 4 will give you the longest stitch length available. If you push the lever all the way up above the numbers, it will reverse stitch.
Sewing Machines Bernina 930
Aug 25, 2015 | Sewing Machines
How to adjust the tension on a 930 record
There is a dial on the top of your machine (shows + and -) just to the left of the decorative stitch selector. Plus increases the tension, minus decreases it.
Make sure that you raise the presser foot BEFORE threading the upper thread. This helps the thread seat properly in the tension guide.
What is the difference between a bernina record 930 and just a bernina 930
At the present time, Bernina 930 Record and Bernina 930 are the same machine. Although, technically the name is Bernina 930 Record, referring to the mostly mechanical sewing machine produced in the 1980's. They are very coveted machines and one of the more popular models.
However, Bernina has, in the past few years, begun producing computerized machines and labeling them with the same numbers of older mechanical machines (makes things very confusing), ie Bernina 830 Record vs Bernina 830 computerized model. At this point in time, Bernina has not yet produced a computerized 930.
Jul 08, 2013 | Bernina Sewing Machines
My thread uptake lever keeps coming unthreaded. It causes stitches to be skipped and eventually the thread breaks. I have adjusted the tension, it doesn't help.
take up lever--try putting some tape on it to see if that will stop the thread from coming off.
also change the needle--make sure is the correct one for the fabric
Apr 14, 2012 | New Home Sewing Machines
Blanket stitch for the 930 bernina
The Bernina 930 Record does not have a blanket stitch. It has a few decorative stitches that are similar, but not exact.
Mar 16, 2012 | Bernina Sewing Machines
Thread is catching & breaking somewhere inside the machine before it gets to the needle. brother XL-5600 machine
According to page 18 of the manual, the only place the thread could be catching would be the tension discs or the uptake lever.
Lift the presser foot and run a heavier thread or flat, unwaxed dental floss through the threading procedure to see if this will clean out a thread that may have jammed into the discs.
Always thread with the presser foot up and make sure the uptake lever catches the thread.
If this continues, take the machine to an authorized Brother dealer for service.
Apr 10, 2010 | Brother XL-5600 Mechanical Sewing Machine
The upper thread tension on my Bernina 930 is too loose. I have changed the needle (it is in correctly) Checked for dust/thread remnants in both the tension springs and bobbin. Cleaned and oiled the bobbin...
If you threaded the machine with the presser foot lever raised and the stitching is still loose, the tension control may need a new spring or the entire control may need to be replaced.
Berninas tend to be the only brand that hold their value and it would be worth the expense to take it to an authorized Bernina dealer for service and repair.
Mar 25, 2010 | Sewing Machines
Bernina830.thread lifter
What is the question?
If the thread uptake lever is broken, you will need to contact a Bernina dealer regarding repair.
Mar 14, 2010 | Bernina Sewing Machines
Sewing Machines Logo
46 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
