Question about Lowrance Boating
Reset Lowrance 4X to full page sonar. Only want depth and bottom
  • Lowrance Master
  • 3,497 Answers
hydetech
  • 113 Answers
SOURCE: I have a Lowrance LMS
Are saying you can't read the screen at night, or is it hard to read the screen anytime?
If you tap the power key, you should here a beep and the screen should get brighter. If you hear the beep and there is no light, then the internal light has failed.
If you can't read the screen in normal light conditions try viewing it under a bright light at various angles. You may notice that the screen is just barely visible. If this is the case you may be able to fix the problem by adjusting the contrast. Try tapping bthe power key and then tap the right or left side of the track pad. It may take several taps to see the results. If left or right doesn't work, try up or down.
Posted on Jul 21, 2008
hydetech
  • 113 Answers
SOURCE: Globalmap 2000 sonar not responding
Not enough info to diagnose your problem. It sounds like a networking problem. I couldn't find a manual for the sam-st module so I'm not sure how you have it hooked up. Typically with these devices only one would be hooked up to the SONAR module, and it would then share the data with the other display via an ethernet or NMEA2000 network. The erratic behavior of your bluewater could be due to some sort conflict with the current coming from the GlobalMap2000. Do you get the same problem when the 2000 is turned off? Have you tried running the GlobalMap2000 with the bluewater turned off?
Posted on Aug 19, 2008
hydetech
  • 113 Answers
SOURCE: proper set up for lowrance sonar
Where do you use your boat?
There are so many variables it's hard to fit it all here, but there are some excellent tutorials on the Lowrance website. The most important thing is to pick the right frequency, for the depth of the water. (200khz for less than 70', and 50 khz for greater depths). Depending on how serious you are about fishing, there are a lot of extras that you may never use. The key is to figure out which features will help you the most and forget about the rest.
You may also get some help at this link: FixYa Service Directory
It's common for SONAR to lose contact with the bottom at high speeds. The better the transducer installation, the faster you can go. Turbulence and bubbles will cause the SONAR to drop out. Lowrance's transducer installation guide explains it very clearly.
Posted on Jan 08, 2009
MarineTech1
  • 76 Answers
SOURCE: Lowrance 3500 Digital Depth Guage flashed 0.5 continuously
If you have a glue in style transducer, be sure that the fluid has not leaked out of the cup. Otherwise, there really is no effective way to troubleshoot those without having known good parts to swap and try. If the cup is empty, it will need to be resealed with silicone (100% silicone) and then refilled with mineral oil.
Posted on Sep 03, 2009
  • 4 Answers
SOURCE: sonar does not appear to work - not picking up
This problem is most likely linked with your transducer.
1. Check your transducer cable and make sure the plug terminals are clean, as well as the plug on the back of the unit.
2. Make sure the transducer cable is plugged in correctly and securely.
3. Make sure the transducer is in the water and mounted according to the directions, parallel to the bottom of the boat
4. Turn the unit on while the boat is in the water, but with the engine OFF.
IF it works when the engine is off, but vanishes when the engine is on, you may be having electrical interference.
IF it works when the engine is running, but vanishes when the boat is moving, it is a turbulence problem. Move the transducer.
IF it does not work at all, try borrowing a new or a "known good" transducer and seeing if it works then. If so, replace the transducer.
Let us know if these work or now.
Posted on Dec 14, 2009
Tip
Lowrance X515C Manual Download
Download Lowrance X515C Manual
Models: X510C / X515C
Have you misplaced your Lowrance X515C Fish Finding & Depth Sounding Sonar Owners Manual?
Would you like a digital, searchable, pdf version of the Lowrance X515C Fish Finding & Depth Sounding Sonar Users Guide?
Follow this link (& click FREE) to download a pdf version of the Lowrance X515C Fish Finding & Depth Sounding Sonar documentation.
I hope that helps.
__________________________________________
on May 06, 2010 | Boating
Tip
Lowrance X510C Manual Download
Download Lowrance X510C Manual
Have you misplaced your Lowrance X510C Fish Finding & Depth Sounding Sonar Owners Manual?
Would you like a digital, searchable, pdf version of the Lowrance X510C Fish Finding & Depth Sounding Sonar Users Guide?
Follow this link (& click FREE) to download a pdf version of the Lowrance X510C Fish Finding & Depth Sounding Sonar documentation.
I hope that helps.
How do i disable the depth sonar
There is a selection either under sonar options or the main menu sonar tab that allows you to turn the sonar off. Article Details
here is a link to Lowrance to download your users manual in a PDF format.
Oct 17, 2014 | Lowrance Elite-4 DSI Combo with 455/800kHz...
Lowrance troubleshooting
Pay attention if depth readings shift during times when moving from spot to spot at higher speeds. If this is the case then you have air bubbles disrupting your sonar signal causing inaccurate readings or a loss of bottom lock for the unit. If over this weeds in shallow water, this at times creates havoc with sonar readings because of the wide variance of signal returns.
check the voltage at the head unit.You should have a minimum of 11.7 volts. 12.5 to 13.5 is optimal
lower power input can affect the overall performance of your unit.
Sep 04, 2014 | Lowrance Boating
How do i find water depth
Water depth should show automatically on your sonar page.
if it does not then either you have selected "stop sonar" under your sonar options or you have opted to turn off the depth displayou so the numbers don't show up.
if you areally viewing your GPS or split screen sonar/GPS page, sometimes the depth display is not visible on these pages unless you specifically instruct the unit to display it.
Lowrance HDS 5 Gen2 Fishfinder GPS Chartplotter
Here is a link to Lowrance where you can download a pic version of the operators manual.
Go to page 11 "overlay data" this will give you a step by step of how to add data or readouts to different screens.
Aug 27, 2014 | Lowrance HDS 5 Fishfinder GPS Chart...
Sonar not Working
Transducer not parallel to bottom - kicked up. Manually set depth to see if the auto depth is the problem.
Aug 12, 2017 | Lowrance Elite-4x DSI Sonar with...
My lowrance sturcture scan shows the bottom and depth but doesn't show structure
don't quite understand what your saying far as the question..when you click the page button on your unit does it show structure scan on the page and if so you go into structure scan and its not showing structure on the screen ?? maybe you need to (fine tune ) your unit or check your transducer to see if its working
May 28, 2011 | Lowrance LSS1 StructureScan Sonar (Lss1...
My fishfinder will not continue to read shallow depths as well as in shallow depths when drifting and occasionally running across the water. My unit is a lowrance 522c color gps/fishfinder.
Hello. Your observation is spot on and it is actually a characteristic that is always true when using sonar. Yes, your Lowrance uses the same sonar as a nuclear powered submarine does. The two factors you focus on, water depth and boat speed are perhaps, the two biggest factors when it comes to the quality of the fishfinder. The boat's engine should be in gear at an idle or just above. Experiment with your boat to find the best throttle location for good arches. Usually, a slow trolling speed works best. The depth of the fish can determine if the fish will arch on the screen. If the fish is in shallow water, the fish is not in the cone angle very long, making it difficult to show an arch. Typically, the deeper the fish, the easier it is to show an arch.
If you would like a complete tutorial on Lowrance sonar, go to this link. Enjoy. http://www.lowrance.com/Support/Tips-and-Tutorials/Sonar-Tutorial/
Nov 20, 2009 | Sport & Outdoor - Others
Proper set up for lowrance sonar
Jan 03, 2009 | Boating
Boating Logo
118 people viewed this question
Top Lowrance Boating Experts
Phil Walker
Phil Walker
Jerry Greenberg
Jerry Greenberg
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
