Question about Seiki Televison & Video
Seiki se50uy04 tv black screen goes black. Starts with rainbowing and then goes black. At times wiggling the HDMI input cable will cause the picture to return. No consistence in when it goes out.
Changing HDMI does not fix the problem either.
  • 208 Answers
SOURCE: hdmi input not working
Sounds like a failure on the main or av pwb in the TV. Do you have another component such as sat. rec or cable box to try with hdmi?
Posted on Feb 05, 2008
SOURCE: Screen Goes Green TV goes to stand by blinking 8 times
try adjusting your color tuners located inside tv behind speakers.
Posted on Nov 25, 2008
ladywinn
  • 5138 Answers
SOURCE: screen goes black randomly during use and tv shuts off
check your capacitors cp150 114 120 if any of them is puffed up on top it is bad replace all 3 cap. 2200uf 1`6v and two 220uf 35v. also resolder FBT pinns.
Posted on Feb 20, 2009
SOURCE: Samsung 40 inch LCD LNS4092D No Picture
I had a very similar problem, TV was 1 day old! Samsung engineer came out and replaced the motherboard - all sorted now.
Posted on Mar 01, 2009
  • 8457 Answers
SOURCE: Half the tv screen goes black randomly,then returns to normal
The Tuner signal board have problems.The board CPU,Chip,have intermitten short.When the chip is completely dead.The tv will get only LED light indicator power only,will not get tv signal pictures.
Posted on Apr 12, 2010
Monitor goes black - green light stays on
My screen is black, why do I not have a picture?
Answer Antenna is not hooked up to television.
  • Make sure that the antenna cable is correctly connected to the television. If it doesn't work there appears to be no signal.
Problem is caused by television broadcast
  1. Push 'INFO' button.
  2. If the screen shows channel number (1, 2, 3, etc) try another channel. Not all channels broadcast at all times.
  3. You may have a signal problem. Contact cable provider or local broadcaster regarding the specific channel.
Television is in EXT or SIDE mode, and there is no external source provided, so screen mute (black screen) is activated.
  1. Push NEXT SOURCE button on the remote.
  2. On the screen appears all sorces.
  3. Press the UP button to switch to the TV mode.
If you are using an accessory device (DVD, DVR, or VCR), be sure the device is on and running.
Blank screen when connecting to the accessory (DVD, STB, PC) device via HDMI to HDMI.
Answer
  • Make sure the cable is well connected .
  • To check which connection is selected, Press the i+ button on the remote control.
  1. When you see Blue mute / blank screen and the i+ display does not indicate any video resolution indication then there is no valid signal detected.
    • Make sure the HDMI output of the accessory is valid by changing the video output resolution to a resolution which the TV can handle.
  2. When you see a blank screen and the i+ display shows a video resolution indication then the connection is correct.
    • The blank screen is caused by the accessory device and not by the TV.
    • To detect and remedy the problem caused by the accessory device, check the instruction manual of this device.
  3. If the problem remains : reselect the HDMI external source input by changing to the other HDMI input and back to the connected HDMI :
    1. Press AV on the remote
    2. Press up and then ok
    3. Press AV again
    4. Press down and ok
    5. The compatibility check process between TV and accessory device will start over again.
  4. Reset (switch off and back on) the TV and also reset the accessory device.
Mar 05, 2008 | Philips 42PF9630A 42 in. Plasma Television
Power indicator on, logo flashes briefly, but then no picture. What's wrong?
SEIKI Tv SC501TS has audio but no video, repair - YouTube
? 1:38
https://www.youtube.com/watch?v=cWpF4q_rBaw
Oct 19, 2014 - Uploaded by EurekaRecycler
SEIKI Tv SC501TS has audio but no video, repair ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight Test - How to Fix LCD ...
LED TV Repair Main Board Overview Blank Screen-TV Has ...
? 2:57
https://www.youtube.com/watch?v=-TU2KSuect4
Mar 4, 2014 - Uploaded by ShopJimmy.com
Learn why your screen is blank and you have audio - No image LED TV Repair Review Main Board Problems ...
LCD & LED TV Repair - No Image & Blank Black Screen ...
Dec 13, 2015 | SEIKI Digital Seiki SE32HY10 32 720p...
Size wide 1 is stuck on my screen at all times how do i get rid off it
My TV just started displaying this message too. I have FIOS. I shut off the FIOS box and turned it back on again and the message disappeared. FIOS problem, not a TV problem.
Jan 15, 2015 | SEIKI Digital SE50UY04 50" LED TV...
Seiki TV has NO SIGNAL message. I changed the main board but that didn't fix it. Light goes from red to blue when I turn it on. Sometimes after about a half hour I'll get signal but sometimes it'll...
Do you have cable ,satellite? Does the no signal come up on all inputs?
Reset cable or satllite box by unplugging from the wall. If HDMI is being used unplug and replug HDMI at d both ends.
Dec 29, 2014 | Seiki Televison & Video
Can i hook up a seiki model SE39UY04 to a comcast HD box useing only the HDMI cable and which slot on the TV do I use
You should be able to. You should be able to hook the HDMI cable into the tv, than go to "TV Input" and select "HDMI 1" "HDMI 2" or "HDMI 3" depending on which input you used
Nov 30, 2014 | Seiki 39" Class 4K 120Hz LED Ultra HDTV -...
Ps3 display demo games or folding@ home
well it could be the resolution of your tv if your or a damage cable that is causing the problem what you can do is to hook up the ps3 to you tv with the regular cables A/V components(red, white and yellow) and try to play a game or demo, if you could see the picture then is the cable or the display settings. you can also try to check different display settings. for example if you use 1080p change it to 720p and try it to see if it works. also try changing the input to a different input on your tv if you're using HDMI 1 change it to HDMI2. and viseversa
Apr 26, 2008 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
64 people viewed this question
Top Seiki Televison & Video Experts
Andrew Taylor
Andrew Taylor
shaun taylor
Are you a Seiki Televison and Video Expert? Answer questions, earn points and help others
