Question about The Computers & Internet
I have had this camera for 3 years and have never been able to access the wifi to any device.
Momentum wi-fi video camera does not a readable QR code
1. When connecting a Momentum camera, on the top-right hand of the screen is a "+" for adding for devices.
There are two forms of adding new devices. The easiest method is by simply scanning the QC barcode.
(Located on the bottom of the camera on a silver sticker.)
2. Your mobile device's camera will automatically prompt you to begin scanning the QR barcode.
3. After the QR code is read, you will be requested to enter the WiFi password.
The camera will try to make a connection with the WiFi router.
4. Lastly, the camera will need to be named. Once the camera is named, select "Finish".
I Hope This Help's ,Best
Oct 12, 2017 | Video Video Game Consoles & Games
My tablet is saying i am offline and will not connect to Wi-fi
Firstly Check if your WIFI router is working by accessing the WIFI connection from another computer, tablet or phone.
If it does, then use the same WiFi connection settings that it has on your ARCHOS.
You could also try connecting your ARCHOS to a friend's WiFi network and if this works, change your access point parameters to similar ones.
OTHER TROUBLESHOOTING OPTIONS:
1. Check your WiFi router/modem documentation to see if it has a pairing button that needs to be pressed. Some modems have such a button that must be pressed the very first time you try to make a WiFi connection with a new device.
2. If you have to enter a password (a security code of type WEP or WPA) be very careful that you do not confuse a 1 and I (one and letter "I"), a 0 and O (zero and letter "O"), or U and V. These are common mistakes.
3. When entering a security code for your WiFi access, check the box "Show Password" which will allow you to see exactly what you are typing in. This will avoid any mistakes.
4. Some access points use what is known as MAC filtering. That means, the WiFi access point has a list of access numbers (every hardware device has a unique MAC number) which are the only ones allowed to access to the WiFi point. The person managing the WiFi modem/router should shut off this MAC filtering system to see if this solves the problem. It is recommended to shut off MAC filtering in general as this is now known to be an outdated and ineffective system for WiFi security. If you must use it, you can find your device's specific MAC address by going to Settings >Wireless & Networks > Wi-Fi settings > Menu > Advanced. It will look something like 00:16:dc:5e:9e:39.
5. Try temporarily shutting off the encryption system of your WiFi router/modem to see if the problem has to do with the encryption system you are using. The preferred encryption system is the WPA2.
Aug 14, 2014 | Archos Tablets & eReaders
What is access point ?
Access point is how and where a device connects to internet...that would be a router sending WiFi signal out..if no WiFi ..want connect..wirelessly..
Jul 17, 2014 | Sony Playstation 3 (PS3) Console
We can only access the camera via wifi. Not able to use or view via cellular connections. Contacted Swann support 3x, they cannot figure it out. Any assistance is greatly appreciated!
I assume you have a App on your phone? To use a Cellular connection you must add :80 (which means Port 80), to the end of the Server Name. Check your Tablet or Phone that is connecting via WiFi for the Server Name and enter it into the phone. You may need to use a DDNS Domain usually when accessing remotely such as a computer over the internet.
Nov 15, 2017 | SWANN ADS-440 SwannEye Indoor/Outdoor...
I am getting "Authentication Problem" with WiFi on 2 tablets - excellent signal. Accepts the security code and will hold for a minute or so.
I see three points:
1. check if the password of the router is the same you have signed in the wifi-account of your tablets - it's typical that a wrong password is prompted with no error message.
2. check if the wifi-protection of your router has the same type (WPA, WPA2) as your tablets use
3. check if the router accepts new wifi-devices, sometimes there is a checkbox "only known devices can access via wifi"
greetings, bernd-steffen
Oct 12, 2013 | Android Tablet PC
I have no internet access unless i run a phone line from the wireless connection to my laptop...tech suppport seems to think i have turned off a sqitcvh that is located somewhere,,,,,a security thing to...
NO OS STATED it came with VISA and that is a dead OS.
that PC that old year , came with many options (lan)
ive no idea at all what this means.sorry
"run a phone line from the wireless connection to my laptop." that is impossible, wireless has no wires.
NO ISP STATED (name) tech support.>? who? Comcast?
NO service stated. over 6 possible....
Dial up? (called phone line wired POTS)
Phone line DSL ? and router.
CABLE MODEM + router or all in one box>?with wifi.
FIOS MODEM (and router in all cases , do you have)
SAT MODEM
3/4G MODEM.
we have no idea at what is there.
nor what wifi options are inside this PC. ever.
if the modem you have , has ethernet jack (RJ45 called)
then use that for fasted possible wired connections
super easy.!!!
getting wifi to work takes hard work.
x10 me blind here.
step one in the laptop is.
if this pc is fitted with the BOARDCOM WLAN.
then. load this.
sp39911.exe
from HP.
here (Broadcom chip wifi driver)
https://support.hp.com/us-en/drivers/selfservice/compaq-presario-f700-notebook-pc-series/3548233/model/3548236
then run the wifi setup and set it up.
1: get the OS drivers matching your VISTA OS.
2:then load those from HP then in BIOS turn on wifi.
3:now the device manager show wifi is there.
4: then using the wifi control appl... set up your wifi matching credentials. SSID name, WEP.WPA1/2 method and then you password to your homes wifi net.
bingo connected.
Sep 17, 2017 | HP Compaq Presario F730US Notebook
I have acer laptop 5580. 3 year old. Recently i have installed Windows 7. Wireless was working nice. Now, system is identifying the wireless, but not connecting. After troubleshooting it is giving...
If your device can detect other acces point then, your wifi device is correctly installed. If not, os will tell your wifi have problem. If you try connect, and have problem with connection, it came from your acces point(wifi router expample). Maybe it have password that have not match with your pc. If that access point is yours, then you can try check the password for wifi using cable connection.
If that acces point(wifi router) is not yours(public), then you cant get the password unless you try hack using air-ng, backtrend using wifi device that can capture and monitor the network(wifi *** support a/b/g exmple) if it only support b/g, you cant get wep encryption password.
If it does not have password, and you try to connect, but it still problem, that mean, it have restrictly to MAC address in wifi router.
May 09, 2011 | Acer (BCM94318MPG) Wireless Adapter
Dear sir a client has a belkin N series router
Couldnt you just buy another wireless access point to extend the existing network?
E.g
http://www.netgear.co.uk/wireless_access_points_WPN802.php
Good luck :)
Jun 13, 2010 | Computers & Internet
USRobotics USR5461 - WiFi local network intermittently available and unable to connect
Usually this is because of radio frequency (RF)interference. Typically, if you have three devices that are working correctly for over a year then it is none of these devices...it is something else. Did you get any new electronic gadgets (Blue Tooth, portable phones, wireless anything) when this started to happen? It is probably something in the area of the router that is interferring with the WIFI input and output.
Solution: move the WIFI router away from the device that is causing the interference as far away as possible.
Also, it may be caused by a device on you...new cell phone, new Blue Tooth that is causing the interference. Try removing or turning off all these devices and see if that doesn't help.
Nov 17, 2007 | U.S. Robotics MAXg USR5461 (738168036790)...
BL-C30A Can not access via web after a few days
Your cameras are losing conncetivity because of the air link being compromised this could be due to unintentional jamming (blocking of the wifi signal)or Resetting of the beacon (beacons can be set to broadcast at intervals) They are needed for the wifi devices to know that they are still a part of the network. These are more then likely your problem
Sep 24, 2007 | Panasonic BL-C30A Network Camera
Computers & Internet Logo
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
