Question about Taylor Ice Cream Makers
For the Taylor C709-27 soft serve machine - what does it mean when someone says it wont go in the heat cycle overnight?
    Scholar:
    New Friend:
  • Taylor Expert
  • 35 Answers
The Taylor C709 is a Heat Treat machine. Most soft serve machines have to be cleaned out every 3rd night and sanitized. Heat Treatment machines heat the mix up to a high temperature that kills bacteria and allows you to disassemble and sanitize the machine much less often. I can't tell you why, but the machine you are dealing with isn't running that heat cycle.
Posted on May 24, 2017
  • Sheila Harris
    Sheila Harris May 25, 2017
    Thank you very much. It sounds like it isn't a machine I should buy. Thanks
  • www.softserveparts.com
    www.softserveparts.com May 25, 2017
    No problem.
    I don't buy that model personally. If it has to be single flavor counter top, look for a C706 or C707. Very good machines. I'm out of single flavor machines today, but I have many dual flavor units in stock. Give me a call if you're interested. 1-800-879-7839. Tex
SOURCE: Taylor 770 soft serve
press reset button very hard (the red one)
Posted on Aug 05, 2008
SOURCE: I have just bought a taylor 750 40
serial # begins with letter and followed by a numeral Y7-1977 Y IS FOR 1970
H6-1986 H IS FOR 1980
J8-1998
K1-2001
Posted on Sep 12, 2008
  • 3 Answers
SOURCE: Taylor Y754-27 Soft Serve Ice cream machine
gearbox is sealed, I've never replaced one.check belts could be too tight, does it scream when you start it. check bearing at end of barrel sharp edge means needs replacing. check temperature of product disspensed on loud side could be too cold. adjust on board or needs new probe, inexpensive but a ***** to install.
Posted on Jan 21, 2010
  • 1253 Answers
SOURCE: need to know how to clean the taylor soft serve
http://www.taylor-company.com/
go to this web site and just click on operators manuals. Then either enter your model number or you can use the drop down menu.
Posted on Aug 12, 2010
  • 91 Answers
SOURCE: we have a 2 flavor
Faulty compressor contactor,faulty power board or compressor has burnt out.
Posted on Jan 30, 2011
Why would a Taylor C713 be making darker and icier soft serve than normal?
I generally see this happen when the air to mix ratio is off. This generally happens overnight when the machine is in standby someone forgets to flip the feed tubes so that no more product is drawn into the freezing cylinder.
Your viscosity could also be set too low.
Jul 29, 2017 | Taylor Ice Cream Makers
My taylor 152 only makes about 5 ice creams then won't produce any more for about 6 minutes ... why ??
The Taylor 152 is at the low end of output when it comes to commercial soft serve equipment. It is rated for 102 3.5oz. servings per hour, but only 4 3.5oz rapid servings before it needs time to recover.
Possible remedies:
When you need to serve several cones in a row, you can pull the feed tube in the top. That will help the product fill the cylinder a little faster.
You could always consider a used Taylor machine that has the ability to keep up with your demand. Soft Serve Parts Taylor Machines
Apr 07, 2017 | Taylor Ice Cream Makers
I have a Taylor C713 Ice Cream Machine. IT has been working great until a few days ago. We had it in standby overnight and when we came back the next morning, the ice cream in one side was rotten from...
Those are symptoms of the mix refrigeration system being undercharged. You will need a refrigeration technician to add refrigerant.
In Taylor soft serve machines when the left side hopper (standing in front of the machine) is icing up and the right side hopper is not cold enough, the problem is low refrigerant in that system. It takes R134A.
Soft Serve Parts C713
Nov 11, 2013 | Taylor Frozen Yogurt C713 Soft Serve Ice...
I need pice from 339-27 ice cream mashin
Dear friend, Well if you are planning to buy an ice-cream machine.i can provide you a few links.
for 339-27 ice cream mashin 1)http://shop.ebay.com/sis.html?_nkw=TAYLOR+339+27+SOFT+SERVE+ICE+CREAM+MACHINE+AIR+COOLED
2)wvw.lucantoniblanz.tk/taylor-339-27-ice-cream-machine
3)http://www.fashioninpassion.com/index.php?jeans=simac+il+gelataio&pj=67167
Price:$2392.0 - Taylor Soft Serve Ice Cream Machine Model 339-27 for the 3rd website
the cost is ranging from $1,995.00 to $7,500.00 (cost on ebay.com)
the below link will guide you in a more better way.
http://shop.ebay.com/sis.html?_nkw=Taylor+754+33+Soft+Serve+Ice+Cream+Machine+Air+Cooled
Buy It Nowor Best Offer $7,500.00
Jul 31, 2011 | Taylor 632-27 Ice Cream Maker
I was wondering, I have two two barrel taylor soft serve machines from an old Carvels Ice cream store. The model numbers are c-712-33 and 8771-33, They were on a glycol machine, DO you have to have a...
This particular Model C712-33 goes into a heat cycle every 24 hours depending to pasturize the mix ,usually good for two weeks.Then the machine must be brushed cleaned.The timer can be disabled as to allow for regular operation.
Jan 18, 2011 | Taylor 632-27 Ice Cream Maker
754-27 Taylor soft serve machine Beater motor not running - compressor not engaging - Power to beater relay but not out of relay.
May 18, 2008 | Ice Cream Makers
Ice Cream Makers Logo
288 people viewed this question
Top Taylor Ice Cream Makers Experts
Dennis Boxerman
Andrew Taylor
Andrew Taylor
Gil Shultz
Are you a Taylor Ice Cream Maker Expert? Answer questions, earn points and help others
