Question about Samsung Televison & Video
I have a Samsung 46" TV. The picture goes dim regardless of room lighting. I have tried all of the solutions with settings and the TV still goes dark.
  • 197 Answers
SOURCE: Samsung 46" LCD picture dark at one side of the screen
bad panel
Posted on Jun 07, 2009
  • 197 Answers
SOURCE: sony bravia 46 lcd The picture dims and
set has a light sensor. go in menu and turn light sensor off
Posted on Jul 02, 2009
SOURCE: When I trun on TV (Samsung LN-T4661F 46 In), it
Samsung made a bad TV, the new part is $1200 I have the same issue. it is a blurred picture from left to right after about 10 min it goes away. (18 month old tv) it is only going to get worse.
Posted on Jun 29, 2010
SOURCE: Picture on tv JVC 27" AV-27530 is getting to dark
I have the AV-27S33 model and in the rear to the right of the inputs are two slits and inside these slits are two screws. The top screw is the focus,the bottom the brightness.Your tv is a different model but it may have this same adjustment,if it does try turning the bottom screw to the right to increase the brightness.
Posted on Jul 11, 2010
  • 8457 Answers
SOURCE: I have a Samsung 46
No,this problems it the T-CON decoders board problems.This board sit right in the middle bottom of the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decoders board for the replacement.
Posted on Oct 16, 2010
Our samsung smart tv screen goes dark at nightfall. We have to open the blinds to let light in to get the screen normal again. Is there some kind of setting I can set to stop this from happening?
It is there. Designed to have a brighter picture during the day and dim it in the evening. Have different names for the feature.
Check your manual out for it.
Sep 30, 2016 | Samsung "UN46D6000 46"" LED ""SMART"" TV "
Should I fix my TV or buy anew one?
Before you buy a new TV go through all the TV menu options to see if it has automatic dimming depending on the amount of light in the room. If it does it may be malfunctioning and turning that feature off may fix the problem.
May 29, 2016 | Samsung 6030 Series UN46FH6030 46" LED TV...
I have a Samsung 55in curved TV. It has auto dimming. In the evening with the lights out it dims to where it is difficult to see the picture. Can I get rid of the auto dimming?
If the brightness on your TV changes automatically (randomly dims and brightens), you may need to adjust the:
  • Eco Sensor function.
  • - And / Or -
    • Energy Saving function.
    The Eco Sensor and Energy Saving functions adjust the brightness of the TV to reduce power consumption.
    • When you set the Energy Saving function to Auto, the TV changes its brightness automatically depending on what you are watching on the TV.
    • When you set the Eco Sensor to On, the TV changes its brightness automatically depending on the brightness of the room.
Oct 18, 2015 | Samsung Televison & Video
46 rca model 46la45rq comes on for just a second then the screen goes black and it only plays sound! what needs to be replaced
Sounds like you have a backlight problem. To verify this, turn on the set and dim the lights in the room. Take a bright flashlight and shine it on the screen. Do you see a faint picture?
Jan 14, 2013 | RCA 46 46LA45RQ LCD TV
I have a 46" Samsung LCD tv that won't turn on. When I press the power button you can hear the chime sound it usually makes and you can hear the relay click and the screen flashes quickly then goes bl
sounds like you have a back light problem. To verify this, turn on the set, dim the lights in the room, and shine a bright flash light on the screen. If you see the faint picture on the screen, you have a back light problem. You could either have a shorted inverter that is pulling down the 24vdc line, a blown CCFL back lamp, a high voltage short (arcing) from one of the inverter outputs, or a faulty 24vdc power supply
Dec 09, 2012 | Televison & Video
I have a 46 inch lcd samsung flat screen. the picture will flicker.
when it flickers is it lines that go up and down or across the screen or is it flickering bewteen lighter and darker?
Aug 05, 2012 | Samsung LN46C650 46 Series 6 LCD 1080p...
My Samsung DLP TV's pictures are flickering on the regular screen, but pictures are fine in PIP mode. How do you explain that phenom?
Set uses two tuners, one for regular and one for PIP. If normal with DVD OR SOMETHING INTO REAR INPUTS, MAIN TUNER IS PROBLEM
sd tech
Aug 21, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Sony bravia 46 lcd The picture dims and
Jul 01, 2009 | Sony Televison & Video
Sony Bravia KDL 46", no picture, standby light blinks 4 times
Since the TV is still receiving power, the problem is going to be with the TV's mainboard.  After you unplugged the TV and plugged it back in, you said the power light went out again, so I assume the standby light wasn't flashing again?  The flashing standby light is indicating an error code so my suggestion is to contact Sony for service options regardless if there is a warranty or not because service is the only solution to this situation.  Don't forget to provide them the error code or 4 flashes repeating.
Mar 25, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Televison & Video Logo
32 people viewed this question
Jerry Greenberg
Jerry Greenberg
