Are we finally starting to drain the swamp? - Heating & Cooling
  • 10,076 Answers
Looks like it.
Posted on May 10, 2017
Bosch dishwasher had debris stopping drain pump impeller. debris removed, now drain pump won't initiate without holding float up.
Is the float intact? Sounds like it got swamped. Try floating it with thin piece of styrofoam underneath. Run one fill cycle. If that works, replace float or repair it.
Feb 21, 2018 | Bosch Dishwashers
I have a 700 yamaha grizzly 4x4 and I crossed a swamp and it went head first in a 5 ft water hole and was submerged for 10 secs,then the tranny wasnt working,"the tires wouldnt spin" the fuses were ba
the belt housing is filled with water.
open the drain valve on bottom of housing, drain and let dry for 24 hours. Once the moisture is all gone the belt will stop slipping.
Sep 30, 2014 | Yamaha 2007 Grizzly 700 FI Auto 4x4...
What's the difference about swamps and marshes
A swamp is a place where the plants that make up the area covered in water are primarily woody plants or trees. Woody plants would be mangroves or cypress trees.
A marsh, on the other hand, is defined as having no woody plants. The non-woody plants would be saltmarsh grasses, reeds, or sedges. Also, marshes are typically not as deep as swamps.
credit the website below:
May 07, 2014 | Computers & Internet
We have a marquis swamp cooler don't know how old
Your blower motor, or pump motor, or belt has failed.
Jun 21, 2013 | Heating & Cooling
Need parts, pump for a ED630J adobe swamp cooler in las vegas, nevada
A swamp cooler PUMP is not really model specific. They are basically small submersible pumps. Contact ANY swamp cooler dealer in LV, tell them you have a 4500 CFM unit and need a pump.
The pump part number for this size cooler is: PN 110436 (there are several alternates)
Contact these folks and tell them what you need:
National Cooler ' Swamp Cooler
3046 Vegas Dr.Suite 1
Las Vegas, NV 89106
(702) 638-8800
If they can not help you... just look under cooling and air-conditioning in the yellow pages and find a dealer near you. This pump is common to nearly every brand in LV. You can most likely buy one at the local home depot, menards, or lowes.
There is also a Little Giant CK-5 "UTILITY"pump that is used for swamp coolers.
Thanks for choosing FixYa,
Jun 15, 2011 | AdobeAir Mobile Swamp Evaporative Air...
Air conditioning water
there is a drain tube that takes care of the condensation from the A/C, these usually exit under the car, does yours must be blocked (do you get a pool of water when you stop in a parking lot? if not there is your answer.
Aug 03, 2009 | 1995 Nissan Maxima
Swamp cooler starts up automatically after power outage
generally ther thermostat is the "brain" of the system, check the wiring diagram (if there is one) or the wiring and see if the on off swtch is inseries or parallell to the thermostat, (should usually be in series if it is I would say that the on off switch is the culprit. you cna verify with an ohmmeter to see if it is staying in the closed position.
Jul 18, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
