Boot manager compressed
Boot manager is compressed
Trouble shooting when boot manager is compressed
Insert your windows system disc in the dvd drive and boot from it choosing repair.
Aug 18, 2015 | Acer Computers & Internet
Boot manager compressed dell inspiron e1505
you may have trouble sorting this with out the disc.Here are the steps to replace the BOOTMGR:
  1. Boot from the Windows install disc.
  2. Click on Repair your computer after selecting proper language, time and keyboard input.
  3. Select the Windows installation drive, which is usually C:\ , and click Next.
  4. Choose "Command Prompt" when the System Recovery Options box appears.
More items...
BOOTMGR is compressed: Press Ctrl+Alt+Del to restart
https://neosmart.net/wiki/bootmgr-is-compressed/.....or try this link.. boot manager is compressed press ctrl alt del to restart Google Search
Oct 14, 2017 | Dell Inspiron E1505 Notebook
It will not reboot the message 'boot manager is compressed' is displayed and will not move past it
Check points for fixing compressed boot-manager:
  • Boot into Windows Recovery Environment (usually the install DVD or Create a Windows Vista/7 Recovery disk on an USB stick) and perform a "Startup Repair".
  • If the above doesn't solve the problem then boot into WinRE again, but when selecting the Vista-installation, then press "Load Drivers" (Instead of "Next") and use the mini Windows Explorer to right-click the boot-drive and deselect "Compress this Drive" and choose Apply to sub-folders and files.
  • If that also fails then boot into WinRE again, and go to the "Command Prompt" and execute these commands:
    • compact /U C:\bootmgr
    • compact /U C:\ntldr
  • If you for some strange reason have lost your Vista DVD, then you can also use a Windows 2000 / XP install CD and enter the recovery console instead and execute the following commands:
    • attrib -c c:\bootmgr
    • attrib -c c:\ntldr
May 05, 2011 | Advent 4211c Notebook
Boot manager compreessed
Sadly the startup repair option or any other repair option in windows 7 startup recovery failed to solve this problem. this can be solved by
reboot your pc
select the repair your computer option
command prompt
at the prompt type notepad (since the recovery option boots from a seperate wim image it has notepad built into it )
press ctrl + o which invokes the open file dialog
go to the open file field (ALT+N) and type c:\boot and also see for the c:\bootmgr
file. right click it and deselect the option of "compress files to save disk space"
when we apply the boot manager is again decompressed. also if someone finds this harder we can directly deselect the compression option by reversing the process used to compress the drive
thats it . we are done
Apr 16, 2011 | Computers & Internet
Boot mgr is missing
Boot Manager is missing If the boot partition no longer can be found, then Vista will display the following error: BOOTMGR is missing. Press Ctrl+Alt+Del to restart
The Windows Boot Configuration Data file is missing required information
More Info MS KB 919529 More Info MS KB 927391 Check points for fixing missing boot-manager: Check that your boot device is configured properly Boot into Windows Recovery Environment (WinRE) and perform a "Startup Repair". Boot Manager is compressed If by accident having compressed the entire boot partition, then Vista will display the following error: BOOTMGR is compressed. Press Ctrl+Alt+Del to restart OR maybe try this first. Check points for fixing compressed boot-manager: Boot into Windows Recovery Environment (WinRE) and perform a "Startup Repair". If the above doesn't solve the problem then boot into WinRE again, but when selecting the Vista-installation, then press "Load Drivers" (Instead of "Next") and use the mini Windows Explorer to right-click the boot-drive and deselect "Compress this Drive" and choose Apply to sub-folders and files. If that also fails then boot into WinRE again, and go to the "Command Prompt" and execute these commands: compact /U C:\bootmgr compact /U C:\ntldr If you for some strange reason have lost your Vista DVD, then you can also use a Windows 2000 / XP install CD and enter the recovery console instead and execute the following commands: attrib -c c:\bootmgr attrib -c c:\ntldr
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Feb 21, 2010 | Acer Aspire 8920-6048 Notebook
Boot Manager is compressed???
here are two solution:
1.
"BOOTMGR is compressed. Press Ctrl+Alt+Del to restart"
compact /U C:\ntldr
attrib -c c:\ntldr
2.if the above solution did not work for you try this easy way:
reboot, push open the dvd drive, load OS Vista CD/DVD, before the ridiculed bootmgr compressed shows, shutdown, boot from the dvd, let the installer do it’s job.
when reach choice “install now” choose “repair the pc” instead.
In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next.
click Startup Repair.
Just click “load drives”since you know the answer about “repair”….nothing wrong..)=:
see that??, you’re inside your HD!! I assuming that from here everybody knows what to do, if not, that what follow:
Browse for your “C” Drive, right click properties and fellas, reverse what you did, exit, reboot.
Feb 05, 2010 | HP Mini 1000 Notebook
Compressed boot manager
Windows Vista includes a new Boot Manager (BootMgr) that replaces the old NT Loader (Ntldr).
This can usually be solved by checking the boot devices, and if no problems found then use Windows Recovery Environment (WinRE) and perform a "Startup Repair".
This can usually be solved by using Windows Recovery Environment (WinRE) and perform a "Startup Repair". If that fails then use WinRE to enter the "Command Prompt" and execute these commands:
Aug 28, 2008 | Computers & Internet
You are stupid!!! of course there is another way!!!!
http://answers.yahoo.com/question
/index?qid=20080612115923AAgIovt
Guru my ***!!!!
May 04, 2008 | Computers & Internet
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
