Sony Playstation 3 (PS3) Console Logo
Posted on Jul 25, 2009
Having the same problem but your solution does not work.
I have a Sanyo HD TV and my Playstation 2 has the red white and yellow jacks but when I plug them in I get no color. If I move them to the bottom red jack and the top green and blue jacks it works but only in black and white with poor picture.
A
Anonymous
Did you verify if your tv is set to work with PAL or NTSC?
if your PS System is European, you must set your tv on PAL
if it's American, you must set your tv on NTSC
and it will not work if you try to plug the cables in component video as you did.
How do you connect a ps3 to a Emerson 32" TV, with yellow, white, and red cords
your yellow is the video in, white audio left, red audio right.
Have sanyo 25in color tv with no manual and want to hook up a wiisystem it is currently hooked up to dishtv model ds25320 and family group vc8b
Connect the yellow rca plug from the wii to yellow jack on the tv marked AV1 and the red and white rca jacks from the wii to red and white rca jacks of the AV1 hookup. Simple.
HOW DO I CONNECT TO TV
There are many methods to do this.
If your cable are ONLY RED,WHITE,YELLOW
1 Plug the red white and yellow cables to there corrosponding jacks on your DVD player
2 Plug the red white and yellow cables to jacks labled video IN, Audio IN. They will be colored on the back of your Tv
3 Plug in the power cable.
4 Turn it on and flip through the inputs on your tv until you see the picture
IF your cables are RED, GREEN, BLUE, RED, AND WHITE
1 Your are using what is called conponent video. This is a high definition video.
2 Three of your plugs are for video. They are Red(Cr) Green(Y) and Blue(Cb)
3 Plug the GREEN into the Y jack
4 Plug the RED into the Cr jack
5 Plug the BLUE into the Cb jack
6 Plug your power cable int o the wall if you havent alredy done so
7 Plug the other red cable into the audio right jack
8 Plug the white cable into the audio left jack
9 Turn it on and surf through the input until you find it
If you have a BLACK, RED and WHITE
Do the same as RED WHITE and YELLOW but
1 Put the black cable into the s-video slot
2 Surf through the inputs until you find the picture
If you have ONE BLACK CABLE
1 This is called HDMI(High-definition multimedia interface)
2 Plug one end into the tv and the other inte you dvd
Thank you for your time, Good luck and I hope this works
No sound on tv and black & white
The red, blue, and green are the component cable hookups. What you have w/ red, white, and yellow is called composite or on most TV's (AV) See if the TV has a side port for like a camcorder, etc. It will not work by hooking into the red/blue/green as they are different signals.
It is possible that your yellow jack may be separate from the red/white audio left/right jacks.
2answers
How do i connect the playstation 3 to tv, it was connected to hd tv then we have tryed to connect to normal tv and nothing. please help
You have to connect the wire that has 3 separate wires at the end into your television according to the color. Plug the red wire into the red slot, yellow in the yellow and white in the white. You will then have to take the other end of the wire and plug it into the back of your playstation. Also, make sure to plug your playstation into the electrical outlet.
I am trying to connect a play station 2 to our Akira TV. I plug in the yellow Playstation plug to the green socker and then connect the sound. I don't get any colour in the picture. What could be the...
You shouldn't connect the yellow into the green socket. The Red/Green/White sockets are for HD and therefore won't work correctly with your usually RCA cables. Your TV should have Red/Yellow/White RCA input somewhere. If not you may have to use a VCR or DVD player to connect your system to your TV.
2answers
Cant get my tv to display my dvd player.when i hook the jacks to tv it doesnt work,the jacks are red,white and yellow
look at the point where you are trying to put the plugs into the tv are you matching colours if so are you sure its an input .?? ..... the easiest way is to use the inputs at the front of the tv(if it has one) and change it through your AV channels (hopefully you knew to chage to av?
1helpful
I have a Sanyo HD TV and my Playstation 2 has the red white and yellow jacks but when I plug them in I get no color. If I move them to the bottom red jack and the top green and blue jacks it works but...
the red and the white cables are the left and right sound
the yellow one is the only one sending a picture signal
plug it into the video in...which should be yellow on that tv, the green and blue jacks are for another type of video connection
Game
It depends if you are using RCA jacks or coax . now RCA is the best way to go . its the wires that plug in to the back of the TV colored red ,yellow and white (yellow is video) (red and white is right and left audio). Now to get to the Question at hand. Either channel down on the rc600d. to the channels below 02 should find
(av )channel if not then look on the rc600d for the tv/video button and try this. make sure the ps2 is on. a blue light on the front of it will mean it is operating .
PLAYSTATION HOOK-UP
i have a tv that only has the audio out put and video out put as well . and my playstation 2 works on it. just plug the white and yellow ends in to your tv and it will still work without you unplugging any cables. hope this helps.
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
