Question about Toshiba Televison & Video
Toshiba LED tv 50L 1400U lower half of screen dark shading and increasing day by day.
Toshiba 50L1400U Lower half of screen dark shading. Can see menu. Help needed to isolate to board or LED strip. Thanks
  • Toshiba Master
  • 2,604 Answers
According to the service manual this set has 2 separate power supply voltages for the LED's and it sounds like there is at least one bad lamp in the panel, if you have a volt meter test the 2 and see if one is at a lower voltage than the other...one other possibility would be if you have Tcon board issues
Posted on Nov 17, 2017
  • 67 Answers
SOURCE: Samsung PS42S5hX - Bottom half of screen flashing black sometimes permanent, does not do this all the time.
might be y drive board bottom half it connects to the y sus board usually on the left side if your looking at the set with the back off
Posted on Jul 05, 2007
dofsqaa
  • 169 Answers
SOURCE: no menu & calendar written on lower screen
Sound like the phones software might be corrupted, you can reinstall the whole system, read on...
You can hard reset the phone (Factory Settings)
This will reinstall the operating system inside the phone back to how it first was.
(internal memory gets formatted then the rom reloads the os back)
(Solves all kinds of problems.)
Switch the phone "OFF"
Hold "3" (button) + "Green Call" (button) + "*" (star button)
Switch the phone "ON" while holding the above three buttons.
Continue holding for about 20 seconds then let go.
Please note this will format all the saved information stored in phone memory. including phonebook numbers (if not stored on SIM card).
Try to make backups first.
You have been "Warned".
Best of Luck.
Posted on Jun 25, 2008
Ecollier2012
  • 3459 Answers
SOURCE: Convergence on lower half of the screen is off, green arc appears
Your TV most likely has a Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
Posted on May 14, 2009
  • 80 Answers
SOURCE: Screen lower half goes black/blank
The lower "Y Buffer" board is defective. Best repaired by a technician, or contact Phillips support for the part if you think you are able to replace a small circuit board on your own.
Posted on May 21, 2009
SOURCE: TWO DARK SPOTS IN THE SCREEN
My tv set as the same problem. By doing some research on the internet found out it is the optical block. Very expensive to fix if you do not have extended warranty coverage. Apparently, it is not an isolated case and many many many owners of this set are experiencing discoloration after owning it for a few years. Sony will tell you they don't know anything about it. Visit this web link for detailed information. http://sites.google.com/site/sonylcdrptvproblems/sonyrearprojectionlcdtv-opticalblock
There's a lawsuit pending. Sony apparently knew about these defects and they continued selling them. No more Sony for me. I feel betrayed. Whta is worst, when you call Sony they play dumb and treat you like you are an ignorant person. Normal tear and wear they say. Only 4 yrs with this unit and paid more than $3k. Normal? Unacceptable.
Posted on Jan 28, 2010
I have a 50L-1400U flat screen Toshiba Led TV, i have had it 15 months and the screen blinks like a turn signal on a car, it has sound and a good picture when it isn't blacked out
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Oct 06, 2016 | Toshiba Televison & Video
The brightness on my Toshiba TV is down, i still get a picture but can barely see anything on the screen. Now I'm not sure should I replace the main board or should i replace the power supply.
Hard to say since you didn't say what model of tv you have but I would say probably neither. If it is a CRT tube you are out of luck...you can try to turn the brightness up. If it is an LCD, it could be the backlight or the power supply to the backlight that is failing
Good luck
Mar 28, 2016 | Toshiba 50L1400U 50" Class 1080p LED TV
Top half of tv is white it started with just a line from side to side and has become worst
half the picture on my tv screen turned completely white. ' IGN ...
www.ign.com > Boards > Community Central > The Vestibule
IGN
May 3, 2014 - 7 posts - ‎4 authors
what half? down the middle or every line of pixels? did you google the issue with your tvmodel? my samsung has issues with bad capacitors ...
samsung led ua40d5000 tv half screen turning white - Forums - CNET
www.cnet.com > Forums > Samsung
CNETMay 16, 2013 - samsung led ua40d5000 tv half screen turning white ... Interestingly after half an hour if i push back the TV from top left corner then problem ... Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Dark shade appears in the below half of the LED TV screen
Oct 23, 2014
LED Samsung Smart TV half screen lose in colour
Sep 11, 2013
Runco PL-61cx plasma tv, top half goes black
Jan 13, 2010
More results from www.cnet.com
LCD TV Samsung LN32C450 top half screen problem ...
? 3:58
https://www.youtube.com/watch?v=SawMHKpsYOA
Jun 8, 2015 - Uploaded by Vladimir P.
This is for my Samsung LN32C450E1DXZA that is having major image issues with the top half of the screen ...
Samsung ScreenTartan/Plaid Pattern on top half of screen ...
? 1:22
https://www.youtube.com/watch?v=ue9IQwj7CVM
Feb 03, 2016 | Televison & Video
Vizio 55" Inconsistant Dark Screen
you have to open the back cover to check weather the screen back light need replacement. usually if the lamp is almost black in color it needs replacement. the backlight is covered with metal shield installed at the upper portion and lower portion of the panel of the tv.
Nov 01, 2012 | Vizio VF Televison & Video
I have a Mitsubishi 60"
there may be dust behind the screen & also on the reflecting glass. u will see that upper back portion cover is removable. remove it & see that glass there is glass on inner side of cover. clean it, also clean the screen. u will see there are 3 picture tubes faces on bottom side, clean all of them.
if it does not work then u can increase brightness of tv by increasing "screen" control of tv which is on the lower back portion of tv. this can be done by any tv repair expert only.
Sep 05, 2011 | Philips Magnavox 51MP392H Rear Projection...
Funny colores and shades on my Toshiba projection TV
the convergence tube is the faulty part in this case a new convergence tubes replacing is required.
Jan 30, 2009 | Toshiba 42H81 42" Rear Projection...
Brightness on my tv quit workin
open your tv.At the back you see a plyback,it is big parts of tv with a wire attached to the picture tube,that is plyback At the buttom you wiil see a two knob, the lower knob is for the screen and the upper knob is for the focus.Adjust the lower knob or screen .
Nov 16, 2008 | Toshiba 36A42 36" TV
Televison & Video Logo
199 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
