Question about Tablets & eReaders
Tried the reboot ....where you hold down the power button and volume button at the same time tablet still isnt working what can I do
  • 1,830 Answers
What type of tablet is it? For instance Kindle Fire etc.
Posted on May 10, 2017
Testimonial: "Iview superpad"
I forgot my password to my Chromo Tablet & I need to know how to reset the password.
Check to see if there is a Reset button on your tablet. Usually it will be next to Power or Volume buttons. Use a small Pin to insert, press, and HOLD it for 15 seconds. Your tablet should reboot. See if it will reset your tablet and let you log into your tablet.
If that does not work, press and hold Power button until your tablet turns off completely. Press and hold Volume Down + Power at the same time for 15-20 seconds. See if the Recovery menu will comes up.
If still not working, power off again. Press and hold Volume Up + Power buttons for 15-20 seconds.
Feb 22, 2015 | Tablets & eReaders
After pressing power lock key for 15+ seconds. The screen goes dead. Almost immediately the word Google comes up followed by a pattern of colours. The Nexus will not reboot
Have you tried using the reset key sequence?
Hold down volume up or down, then push and hold Power button until it enters recover. Release buttons. Volume chooses option and power selects option.
Feb 12, 2015 | Tablets & eReaders
Get rid of dead robot
try clearing your cache partition, you can get to the android recovery with your buttons.
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the red Motorola logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up).
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons.
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections.
6. Use the volume buttons to move up and down through selection in this menu.
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option.
9. Scroll down to select "Yes, delete all user data".
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
Jan 21, 2015 | Tablets & eReaders
Help to reboot my tablet
Hi, you need to perform a factory reset, follow these instructions:
Dec 31, 2014 | Tablets & eReaders
I've had several issues but the one now is that all my tablet will do is show a pic of an android laying down with a red triangle on it bearing an exclamation mark. At the bottom of the screen it says NO...
Oct 29, 2014 | Tablets & eReaders
Nabi jr has a green android laying on it's back with red exclamation make, want do anything. How do I fix it?
Oct 27, 2014 | Tablets & eReaders
Kurio 4s need help
You can perform a reboot by holding the volume + button and power button at the same time. Release the power button after 5 seconds but keep holding the volume + button until a screen appears with options. Press the power button to select reboot. Next you will have to scroll down using the Volume + button again to highlight yes and press the power button to select. If the reboot does not work, you many have to perform a factory reset using the same steps except you have to use the volume + button to scroll down to the factory reset option. Hope this helps.
Feb 26, 2014 | Tablets & eReaders
My nexus 7 wont go past multicoloured x.. cant switch on/off. tried hard reset and nothing works
Important:Plug your device into power outlet
Step 1: Power off Nexus 7
Step 2: Power on while holding Volume Down/Up
(enter BootLoader)
Step 3: Press Volume Up to toggle to "Recovery Mode"then press power to select
Step 4: Hold The Power Button and tap Volume Up when you see "No Command"
Step 5: Press & hold Power Button & Volume Up Button Again
Step 6: Toggle with vol down and vol up / power at wipe data (all data) & reboot
Nov 20, 2013 | ASUS Google Nexus 7 8GB Tablet Unlocked...
My nexus 7 tablet wont leave the startup screen. I tried a hard reboot but it stays on that screen and wont turn off
(enter BootLoader)
Step 6: Toggle with vol down CLEAR CACHE & reboot
Nov 03, 2013 | Google Nexus 7
Tablets & eReaders Logo
52 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
