Question about The Office Equipment & Supplies
HOW TO REPLACE THE WEB ROLLER IN IR 400 - VIDEO PLS
3 Suggested Answers
  • 11 Answers
SOURCE: web roller is loose
u remove u r heater unit and remove web rollar unit then remove web guard plate u get two side rollar type web first fix big size web (u look one iron plate. prees down this plate and fix u r web ) then fix another small size rollar. it fix gear side then u see opposite of gear. one screw is there u tight it web cloth is tight then fix u r web unit in heater unit
Posted on Sep 18, 2008
  • 39 Answers
SOURCE: CANON IR 400 WEB ROLLER HOW IT IS FIXING.I WANT VIDEO FILE
That is a little question with a big answer. You first need to buy a web ($10-$30) and then replace the old one with it. This requires tools and if that appeals to you then I'll write the rest of this response, but it's a dirty job. The only tool you really need is a Phillips #2 screw driver. Else if this doesn't appeal to you then call a copier tech to do the job. Good luck either way.
Posted on Dec 17, 2009
Testimonial: "how to fixing the ir 400 web roller "
What is the problem when my canon ir-2016 says out of tonner
magnet roller poor contact on roller bush connector... other wise roller blade ya roller stick clean properly Nd cheek board connector.. otherwise the magnet roller is damaged... clean the full toner unit...
Aug 01, 2014 | Canon iR 2016i Black and White Copier
Powder spray in first copy only
clean gently the charging roller with cloth or better to replace the charging roller
Sep 18, 2012 | Canon imageRUNNER 400S Copier
Erreur e 014 pour ir 400
Fixing unit roller is stuck up. Check the cleaning web roller or the lower pressure bearing. You can spray the bearing with penetrating oil to loosen the rotation of the roller.
Jan 25, 2011 | Canon imageRUNNER 400S Copier
My IR 400 canon xerox machine's copy is white
clean the toner unit and clean the scanner ,replace the drum and charger roller (p.c.r) and solve the problem.
and my name is gm prathap kumar guntakal,09573910647
Jan 06, 2011 | Canon iR330-400 PS Ver 1.0
Ir 400 ada kode e064
A Error code E064 deals with the transfer roller unit. I would look to see if the roller feel out of place or I would replace the unit.... Good Luck
Sep 19, 2010 | Canon imageRUNNER 400S Copier
Dec 17, 2009 | Canon imageRUNNER 400S Copier
E005
Hello
Ok, reset cleaning belt /web roller counter.
Just follow these steps and you should be a happy printer once again.
* (with head)
2 and 8 (simultaneously)
* (with head)
on lcd press COPIER>Counter>Misc.Fixweb press (C)lear button Fix web counter must be 0000000
Switch power off and on the machine
Kind regards
Andrea
Dec 16, 2009 | Xerox DocuColor 12 Printer
Plz send me (detail) feachar of cannon 6050 & cannon 400s on this address CHECHANI TELECOM & PHOTO COPIERS C-278, R.K.COLONY,NEAR CHOTI PULIYA, BHILWARA,(RAJ)311001 +919829045797 +919413824797
CANON IR 6050 IS AN ANALOG COPIER.
CANON IR 400 IS A DIGITAL COPIER.IR 400 IS SINGLE SCAN & MULTI PRINTS ,STACKLESS DUPLEX & ITS CAN BE USE PRINTER & FAX ALSO.
FOR MORE DETAILS VISIT WWW.CANON.COM
Mar 15, 2009 | Canon imageRUNNER 400S Copier
Web roller is loose
you will need to take the fuser out and remove the top part of the fuser where the web is.
there is a gear in there that fails to advance the web, it may need to be replaced
Dec 11, 2007 | Canon imageRUNNER 400S Copier
24 people viewed this question
Top The Office Equipment & Supplies Experts
James Cagle
James Cagle
Gareth Cockram
Gareth Cockram
Peter March
Peter March
Level 1 Expert
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
