Question about Refrigerators
When i pressed the button, compressor went to sleep and has been resting ever since, there is no electric trip as i can see fridge lights are on. that defrost button now seems to be disabled.
SOURCE: Can I disable Sleep Button
If you are using Vista ... control panel.... system and maintenance.... Power Options. On the left there is an option for "Choose what the power buttons do" You can disable the sleep button there. C'mon Compaq... get a brain!! Who's dumb idea was it to put the sleep button there?
Posted on Apr 16, 2009
  • 159 Answers
SOURCE: caravan fridge tripping when connected to electricity
on what voltage doe it work then i can tell you exactly how to wire it
Posted on Jun 01, 2009
SOURCE: sleep button wont work and its disabled
Could you clarify what is the sleep button?:
- The home button on the front
- The power button on the top
- or the vibration disble button on the left
Probably the flex cable that connects the button to the motherboard is not working. These parts are cheap and easy to install. You can find the replacement connectors for all these buttons here:
http://www.piezas.biz/epages/wwwpiezasbiz.sf/en_GB/?ObjectPath=/Shops/demo132390/Products/%22Piezas%20Iphone%203G%22
Posted on Aug 19, 2009
Testimonial: "nice one mate, thanks."
  • 31 Answers
SOURCE: f2105 hp monitor went to sleep and cannot wake.
i cannot help you its either your moniter or the vga port at the back of you tower there the only things i can figue out
Posted on Jun 01, 2010
SOURCE: New defrost timer on fridge keeps tripping circuit breaker
The problem is the defrost timer you just replace on your refrigerator, you will need to check the ratings on the broken defrost timer to ensure it matches the ratings on the present defrost heater on your refrigerator, beside, you will need to test the continuity on your present defrost heater to see if the voltage rating is ok, because, if it can be tripping the breaker off while it kicks into defrost mode signify that the present defrost heater is not compatible with your refrigerator, it is either it is not well wired or fixed, and if it is, then, it means the defrost timer voltage rating is low compare to the former, you will need to get exact specification as the the broken one.
Take care.
Posted on Jul 10, 2010
Fridge blow fuse. What can be wrong?
There could be a lot of reason but most common reason for unit tripping breaker is bad compressor .
Disconnect compressor and turn breaker back on and if breaker didn't tripped then it's definitely the compressor. If breaker still tripped then there are other issues .Check all electrical wiring because something is grounded
Jun 01, 2017 | Refrigerators
I HAVE A JENNAIR JS42CSDBDA FRIDGE THAT WENT DEAD NO POWER,NO LIGHTS CHECKED OUTLET AND FOUND POWER GOING TO FRIDGE BUT NOTHING. IT ACTS AS IF IT'S NOT EVEN PLUGGED IN.
I am not familiar with this model BUT most fridge/freezers these days have a built-in electrical protection device [usually similar to a circuit-breaker] to protect the unit from any electrical supply surges and/or "shorts". You may find a RESET button located near the compressor housing. Press this and hopefully your problem will be rectified. Probably best to do this with the power switched OFF [although not always necessary].
Oct 20, 2014 | Jenn-Air Refrigerators
My refrigerator stopped working because I left the door open for like three hours and the electricity does not go to all the fridge parts like the lighting system is off and the freezer is off every thing...
There is no sensor like you stated. Actually, when you keep open the fridge door, the cooling all will go out and hence thermostat sensor would not cut off, as required temp not reached inside the fridge.
So, the compressor would have run for long time without cut off. Due to this the overload protector trips the compressor. Remove power for 4 to 6 hrs. And then restart the fridge. But make sure you close the fridge door. Thanks.
Mar 20, 2011 | Danby Compact Refrigerator DCR-101W
Hi, my fridge freezer keeps making the electric trip out. help!!!
Try this:
Turn your thermostat as warm as it will go, you are trying to isolate the compressor and keep it from turning on. If your fridge has an "off" position, then turn it off. Reset breaker, plug refrigerator back into the outlet. If the fridge trips while "off", then you are likely looking at a damaged cord / wiring.
If the breaker doesn't trip, unplug the fridge, and move the thermostat to the warmest position possible. Plug fridge back in, If the breaker holds, then you are on right track. Slowly move the thermostat to a cooler setting. You want to just reach the point where the compressor tries to start. If breaker holds here, then you are in good shape so far. It indicates a problem with the defrost heater (if equipped), or the ice maker (if equipped). If the breaker trips as soon as the compressor tries to start, your compressor may be damaged (bad and expensive).
Aug 17, 2010 | Refrigerators
Refrigerator won't restart after power outage.
Check all of your breakers first (if you have light, it's getting power) but if you had low AC line voltage for any length of time, the compressor may be fried.
If that proves to be the case, call your electric utility and ask them about their liability; if they have allowed a 'brown-out' to persist, it is their fault. This happened to us on a fairly new fridge and they coughed up $350 for the repair.
Feb 28, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
About 1:00 am this morning our fridge tripped the circuit breaker, it ha never done this before. I reset the breaker and it tripped 5 mins later. I left it unplugged for the rest of the night. I plugged it...
It sounds to me, either you have a bad circuit breaker (the breaker itself); or you have a bad motor or compressor in the fridge. If possible try plugging the fridge into a different outlet. (If you use an extension cord to do this, make sure it is a thick gauge, in order to not cause an increase in amps through the smaller cord.) This should tell you rather quickly if the problem is with the breaker or the fridge. If it does turn out to be the fridge, you will probably find it is cheaper to replace a fan rather than the fridge, but the compressor (including installation) would probably cost more than a new fridge. (depending on how "fancy" it is)
Hope this helps
Sep 29, 2009 | Refrigerators
Candy Frostfree Fridge freezer, model CPCA240FFK
1st of all conferm that the compressor is automatically (through Thermostate) going to ON/OFF or not, if it automatically goes OFF, i sugges its OK. and if not its no problum. (Minimum 4 hours rest is Must of a compressor, u can maunally OFF it for daily 4 hours Sleep)
Take Care
Shafky
Jun 17, 2009 | Candy CPCA240FFK Bottom Freezer...
Refrigerator compressor not working
unplug the fridge,remove the electrical cover on the compressor to see if any wires are burnt off.you may have a defective start relay,wire off or compressor seized,that age not cost wise to replace compressor
Apr 09, 2009 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Bosch KIM29473GB refrigerator lights on but no refridgeration
it sound more like the compressor is faulty siezed up
if so it will try to work then trip on the compressor overheat it will rest for about three to five minutes then try again
if this is happening it almost certainly eliminates the stat if the stat was faulty the compressor would not try to start compressor expensive to replace and time consuming would take about two hours
Good luck
Mar 10, 2009 | Bosch KIM29473GB Bottom Freezer...
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
