Question about Refrigerators
Unlock water and ice dispenser - Refrigerators
Buffalo12980
  • 625 Answers
SOURCE: Water dispenser
the slide switch ice - water may not be making up. the paddle inside the door operates a common microswitch to either dispense ice or operates the water solenoid. check out the selector switch.
Posted on Aug 22, 2007
fanny
  • 146 Answers
SOURCE: Kenmore elite (106.53606202) ice maker will not dispense ice
When you push the ice dispensing lever, you should be able to hear the micro-switch clicking. If no click, the switch is faulty. The auger motor which is activated by the lever could also be faulty. This is the motor that causes the auger in the ice bucket to rotate one way for crushed ice and the other way for cubes. The auger could also be jammed. Try switching between crushed and cubes to unjam the auger. Empty the ice bucket and start again.
Posted on Nov 03, 2007
SOURCE: Can't unlock my ice dispenser
press the lock button three times in a row
Posted on Apr 06, 2009
  • 36 Answers
SOURCE: Kenmore Elite refrigerator ice and water dispensers not working
check for a child lockout button it will look like a tiny padlock ,press and hold for 3 sec.(could be the freezer door light switch)
Posted on Jul 24, 2009
SOURCE: My maytag MSD2556ae side by side refrigerator water/ice dispenser
I have a Maytag model 2556 AE refridgerator. The ice maker works but the ice and water dispenser, the light and everything else on the front of the unit doesn't work. Is there a fuse that operates this or is there other problems? Thank you Bob
Posted on Mar 11, 2010
My maytag MSD2556ae side by side refrigerator water/ice dispenser may be locked. Is there a method or code to unlock. The water dispenser started shooting water out with no warning and the dispenser light...
Jun 10, 2009 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
Kenmore Refrig. door water disapenser
check the switch on the water despensor , solinoid valve or the water supply to the fridge
Apr 13, 2009 | Refrigerators
NO ICE
Check this first,
Your dispenser can be turned off for easy cleaning or to prevent
unintentional dispensing by small children and pets.
NOTE: The lock feature does not shut off power to the product, to
the ice maker, or to the dispenser light. It simply deactivates the
ice and water dispensers. To turn off the ice maker, see “Ice
Maker & Storage Bin.”
 Press and hold LOCKOUT for 3 seconds to lock the
dispenser.
 Press and hold LOCKOUT a second time to unlock the dispenser.
Let me know if this helped, Sea Breeze
Mar 22, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Feb 10, 2009 | Maytag MSD2756G Side by Side Refrigerator
Kenmore Elite Fregirator
i have the same fridge, you have to press and hold the Lock button and it will unlock the ice/water for you.
Sep 15, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice maker not getting water after changing filter
Check the following:
 Is the freezer door closed completely?
 Is the ice storage bin installed correctly?
 Is there ice in the storage bin?
 Has the ice frozen in the storage bin?
 Is ice stuck in the delivery chute?
 Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
 Has the ice melted around the auger (metal spiral) in the
ice bucket?
Dump the ice cubes and clean the ice storage
bin.
 Is the ice dispenser stalling while dispensing “crushed”
ice?
Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
 Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
The ON/OFF switch is located on the top right side of the freezer
compartment.
To turn the ice maker on, slide the control to the ON (left) position.
To manually turn the ice maker off, slide the control to the OFF
(right) position.
NOTE: Your ice maker has an automatic shutoff. The ice maker
sensors will automatically stop ice production, but the control will
remain in the ON (left) position
REMEMBER:
 Allow 24 hours to produce the first batch of ice. Discard the
first three batches of ice produced.
 The quality of your ice will be only as good as the quality of the
water supplied to your ice maker. Avoid connecting the ice
maker to a softened water supply. Water softener chemicals
(such as salt) can damage parts of the ice maker and lead to
poor quality ice. If a softened water supply cannot be avoided,
make sure the water softener is operating properly and is well
maintained
The Dispenser Lock (on some models)
dispenser levers. The ice and water dispensers will not work.
Style 1: Press the LOCK BUTTON to lock the dispenser. Press the
UNLOCK button to unlock the dispenser.
Style 2: Press and hold the LOCK OUT button to lock the
dispenser. Press and hold the LOCK OUT button a second time to
http://www.ajmadison.com/ajmadison/itemdocs/2261717.pdf
May 15, 2008 | Whirlpool GS5SHAXN Side by Side...
Water Dispenser Not Working
the water spout on the dispensor unscrews this is a clog issue take it off and then run water becarful this does have a spray effect all over but it allows water to flow
also there is the problem of the water tube up the door has kinked when closed this is a big deal with front fridge water the ice dispensors tube goes up the back
May 13, 2008 | Samsung RS2630SH Side by Side Refrigerator
Ice and water dispenser
Has someone pressed the lock button on the front of the fridge just above the dispenser, next to the crushed & not crushed ice button, if so there is also an unlock button next to it.
Jan 04, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
