Question about The Computers & Internet
What is the problem of koppel split type aircon enverter ERROR P4
  • 400 Answers
SOURCE: WATER LEAKING FROM MY SPLIT TYPE LG AIRCON
1. Do not set the aircon too low temperature in overcast weather, this will cause ice ups and water dripping. Optimal comfort zone temperature is 24c.
2. You need to open the grill cover on the front of the aircon which unclips either end left and right with a finger pressure. You will find two filters which can slide out and should be cleaned. First tap them together to remove dust, then you can wash them with mild soap and cold water.
3. There is the third possibility that an insect has made a nest in the drainpipe. You should look on the outside of the building and locate a plastic drainpipe. You can either blow into this pipe with your mouth or get a blower. This will unblock any restriction in the drainpipe.
Goodluck and ratemeplease.
Posted on Mar 19, 2009
  • 3600 Answers
SOURCE: my split type aircon wont work properly, water
try cleaning the port for the drain plug, when the air is damp outside it will condence a large amount of water. Aslo make sure unit is level so it will drain properly.
Posted on Jul 19, 2009
SOURCE: my split-type aircon is contantly
there isa circuit problem in ur ac
Posted on Nov 09, 2010
  • 57 Answers
SOURCE: how to install split type aircon?
Plan the location of your outdoor and indoor unit. Make openings for the pipes and wiring's that should be accessible for repairs or maintenance. Never place the condenser near the walls, and follow the allowable clearance from the walls. Same thing follows for the indoor unit make allowance from the ceiling and it should be tilted to drain the water from the drain pan. Make the piping and wiring connection following the suppliers recommendations. Drain pipe should be lower than the wiring installation. Do not use seal tape for threaded connection, only apply refrigerant oil and tighten all nuts. Leak test or vacuum the lines from the valve fittings outside the condenser to the evaporator( in and out of the evaporator ). If vacuum or pressure stays unchanged for an hour, there is no leakage. If you applied vacuum, just fully open the service valves. If you pressure test the line with Nitrogen, release Nitrogen gas by loosening a little the bigger pipe nut from the condenser until no pressure comes out.Then open the small service valve from the condenser a little until pure freon comes out of the loosen big nut and then tighten it. Full open all service valves and unit is now available for operation with power supply.
Posted on Sep 03, 2011
Nomadfeet
  • 59 Answers
SOURCE: how to charge a refrigerant of split type aircon.
Assuming you have the proper equipment to service the unit the best option is to weigh in the charge- superheat/subcooling calculations fly out of the window on mini-splits and the frustration and time spent trying to achieve proper refrigerant balance is more pricy than recovering the charge and reweighing it into the system. If you are not experienced in this field attempting to do so can cause major damage to very expensive equipment.
Posted on Sep 22, 2011
The brand name is koppel split type airconditioner.model num.1ku536P7A.no remote control.i use the universal remote control chunghop.but not functioning.no code are listing..can you help me?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
Jun 08, 2016 | Universal Remote Control Televison & Video
I have a koppel split type airconditioner.my remote was deffective can i use a universal remote control chunghop.what is the code?
There is probably no code built into the Chunghop. If the Chunghop has a "Learn" function then you can teach it the commands using an original remote (hopefully you can borrow one).
Whats the problem of vrf koppel aircon if P3 appeared in the display
Search online for "error code *** +your make and model".
Jul 17, 2015 | Heating & Cooling
Koppel super inverter displays P4
Wrong category, try Air Conditioner category. A AC expert may can help you. This is a PC Laptop category.
Apr 07, 2013 | Computers & Internet
What does malfunction code E6 mean in a koppel super inverter airconditioner
WHAT IS THE MEANING OF E4 code in koppel inverter split type
May 01, 2012 | Heating & Cooling
Hi i need to know what size window air con for a room 30sq meters cooling onjy and what model
Hello there.. :) your room 30 sq. meters needs 2 - 2hp window type aircon as computed. But you can consider the purpose of putting up the aircon and how many occupants will stay.. :0
For the model:
NATIONAL, 2HP, Model CW-1808VPH 2HP LG Window Type Aircon Manual 2HP Koppel Aircon w/ remote model: KWR-18R1
or check the internet for other models that you want.. :)
Feb 03, 2011 | Heating & Cooling
I have a Fedders Koppel Split system aircon. My remote control unit is broken and i wonder to where i can get another. My local Rep is useless and just told me there are no units available. My Split...
The first thing that can be done is to get your old remote into action. so try to repair the remote with tips from this link.
http://www.fixya.com/support/r6178946-tips_repair_remote_controller
You have to check your local store for a universal type that will match , ask for demo to confirm.
Oct 05, 2010 | Refrigerators
Computers & Internet Logo
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
