Question about AOC Televison & Video
Hi, I have an AOC remote lcd Tv, The remote is a RMC10700 when I push any buttons a light appears next to the power button, flashing red, the green power light on the tv flashes but no action.
Changed Batteries and purchased 2 new remote but the same thing any help please
  • 308 Answers
SOURCE: red light on power button flashes, but no picture....blank screen
I would suspect a problem in either the backlight assembly, or the power supply that drives it. If it's the power supply, the part may be over $100.
Posted on Jan 18, 2007
SOURCE: Power button Flashes
Bad Convergence circuit , replace 2 STK392-110 & fuse will take care the problem
Posted on Jul 18, 2007
  • 3130 Answers
SOURCE: tv won't turn on
Your problem could be the Convergence board is loading down the power supplies and will not let the TV set come on, or the power/deflection board, part number AA94-08574A, or the STR type regulator IC, part number AA13-00105A. If you locate the convergence board, unplug the connectors, and see if the set will come on. if the set does come on, replace both of the STK convergence IC's at once. The part numbers for those IC's are STK392-40. You can get the original replacement IC's from MCM electronics for about 15 to 16 bucks a piece. Do not use the less expensive STK IC's as they are not the same. the replacement IC's should have the name of SANYO printed right on the face of the IC's. Good Luck
Posted on Jul 22, 2007
  • 5 Answers
SOURCE: My magnavox 37mf321d 37 LCD tv
This is a bad power supply and an easy fix. Their are several electrolytic capacitors on the power supply. If one is bad it will have a bulge on the top. Mine had a bad 2200uF and a bad 1200uF capacitor. About $7 worth of parts at Radio Shack. Radio Shack had the 2200uF but it was axial leads instead of radial. (leads come out of each end instead of one end) but It will still fit. They only had a 1000uf capacitor so I combined that with a 220uF capacitor and wired them in parallel. Make sure you put them in with the correct polarity.
Posted on Dec 06, 2008
SOURCE: remote control
I had the same problem.  The problem is strange and seems to be with the receiver in the TV and not the remote control.  The reason I say this is that when this first happened my Samsung brand DVD could actually control the TV.  This then also failed, but still works fine with the DVD player.
Anyway there is an even more bizarre fix to all this......
- Remove the batteries from your TV remote. - Press and hold the red (ON/OFF) button for at least 1 min. - Replace the batteries and hey presto!!
I know seems far fetched but I found it on the Samsung website and it does work.
Posted on Mar 30, 2009
My 40 inch S400A Series Full HD BRAVIA LCD TV does not turn on. When i plug it in, the green light (next to the Red power light) blinks. If i try to power on via remote, the red power light turns on and...
this again sounds like the power supply,.if you hear a click when you push the power button, this means your main board is reading good so replace the power supply,.
Apr 06, 2014 | Sony BRAVIA KDL-40S2010 40 in. LCD...
AOC L26W861 LCD TV : 1. When TV is turned on using remote, it just recycles through all the pre-programmed channels 2. Unplugged the power chord several times but is still does the same 3. Power button on...
Try a factory reset:
1. Press and hold "Menu" and "Channel+" on the TV. (do not use the remote)
2. Using the other hand, press the Power button.
3. A small screen should appear in the top left part of the screen.
4. Using the remote, select "Memory Recall" and Enter.
5. Power off and reboot the TV and Computer.
6. Run channel auto-scan to regain the picture.
Nov 06, 2011 | AOC L26W861 26 in. LCD TV
Hi I have a vizio tv control with the key board and it all just stopped working so I thought it was the batteries changed them still not working ????? Help Please
Test ur tv remote control first see,if it is working,malfuctions or completely dead?U have a Digital Camer wright?Yes.Digital Camera can read Infer Red signal Output by the tv remote.Yes?Turn the Digital Camera on and take the tv remote point it at the Digital camer and pushes all the remote buttons the Infer Red signal will read all buttons Infer Red signal flashes u can see on Digital Camer viewing screen.Pushes all remote buttons see flashes of white lights.Mean the tv remote control it it good or not.Take some cottons ball soak it with some rubbing alchachol clean the tv Infered Red sensor on the tv frame near the power LED incation light.Might be dirty,Still not reading the Infer Red signal.If 100% it is the tv remote control is the cause,it CPU is dead.Try website like to buy another the tv original remote.
Jul 29, 2011 | Vizio VO47L 47 in. LCD TV
Flashing green button
Where are you located? If you don't want this Sharp 35VX-H2000 anymore, I will take it, even if it's broken. Thanks.
Jun 29, 2010 | Sharp 35VX-H2000 35 in. TV/VCR Combo
No picture
Put new batteries in remote control.
Sep 14, 2009 | ViewSonic N2750w 27 in. HD-Ready LCD...
Sony bravia tv not working
Hi Elaine!
Please follow the steps mentioned below to troubleshoot the issue:
If the TV standby light is blinking for five times then you may perform the steps given below:
(i) Turn off the TV then disconnect all the cables from the TV.
(ii) Next, reconnect all the cables after two minutes.
(iii) Please make sure that the power cable from the TV is directly connected to a functional wall outlet.
(iv) Next, you may try resetting the TV to the original factory settings.
Please follow the steps that are mentioned below to reset the TV to the original factory settings:
(a) Turn ON the TV.
(b) Press and hold the Power button on the Remote Control supplied with the TV, then press the Power button on the TV front panel.
(c) Release the Power button. The TV will turn itself off, then back ON again.
(d) Next, release the Reset button on the Remote control.
If the standby light still blinks then the issue may be with the projection lamp in the TV and requires replacement.
Jul 12, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Turning on the monitor
Could the batteries in the remote be dying. Did you try changing them?
May 31, 2009 | Soyo DYLT032D 32 in. LCD Television
Sony bravia tv
Solution is simple....
First, unplug power cable from the back of your TV. You will notice the flashing light is still flashing. Don't worry, go to the Second step.
Second, keep pressing on the POWER button, located on the panel at the top of your TV, to shut off your TV. This will stop the flashing light from appearing.
Third, Plug the power cable back onto your TV
Fourth, press the POWER botton ONCE, using the same button used in the Second step to turn your TV back on.
Fifth, you will see the POWER light comes on, as normal.
Sixth, using your remote control, press the green button to turn on. Your TV should work as normal.
Jun 08, 2008 | Televison & Video
Televison & Video Logo
Top AOC Televison & Video Experts
Raj Patel
Are you an AOC Televison and Video Expert? Answer questions, earn points and help others
