Question about Dryers
Change thermal switch - Dryers
Why does the thermal fuse continue to blow.
The thermal switch is trying to tell you that something is getting too hot. Maybe you need to clean out the dryer exhaust duct from within the dryer all the way to the outside.
Feb 05, 2015 | Dryers
In the barcode printer showing ribbon out. I change the print method from " THERMAL TRANSFER TO DIRECT TO DIRECT THERMAL " and saved. Again come the same problem RIBBON OUT. How I solve the problem....
You need to change the print method from thermal transfer to direct thermal. There are three places to do this:
- on the printer itself - in the printer driver (this will override the setting in the printer and be the default setting for any new labels crested) - in the print properties of a specific label (this will override the two settings previously listed) The last option works best if you are switching label stock or ribbon in and out for different labels.
Sep 21, 2010 | Zebra 105SL Thermal Label Printer
The high limit thermal switch on heater burns out.
There are two thermostats, a 'limit' or 'operating' thermostat which turns the heating element on and off, and a 'high limit' or 'safety' thermostat which oversees the 'operating' thermostat by opening and removing power to the heating element when the upper limit temperature is reached. Basically, the only difference between these two are the temperature ratings. The 'high limit' is higher than the 'operating' thermostat. The thermal fuse is the last resort protection.
First and foremost, you must know that every inch of your exhaust vent pipe is clean.
Usually, a bimetallic limit switch will degenerate in the direction of too low of a temperature range because as the parts wear out inside, the mechanical tolerance widens (the tiny rod that pushes the contacts together gets shorter).
The high limit thermostat is by the thermal fuse. The operating thermostat is in the blower housing.
Check the fan impeller for broken vanes and lint. The impeller is directly coupled to the motor and should not turn without the motor. The fan housing and ducting should be free of excess lint.
Good luck.
May 02, 2010 | Samsung DV316LES Electric Dryer
No heat, checked high limit and thermal fuse?
well john henry can you relish changing the starter switch on the motor? cause thats where your little ole problem is with that unit LOL
Jan 13, 2010 | Dryers
Thermal Fuse
the thermal fuse or the hi-limit switches are both easy to change out once the dryer top and front cover and drum is out unless you can access the element from the rear of unit
Aug 29, 2009 | Maytag MDG2706A Gas Dryer
Clothes dryer not heating
I eventually changed the thermal cutoff switch and the high limit thermostat as suggested in one of your replies to another consumer and now the dryer is working fine. Thanks.
Nov 13, 2008 | Zanussi TC7114W Electric Dryer
No heat
No Blower in Floor Mode
A customer arrives with a 1983 to 1995 Full Size Ford, Lincoln, or Mercury
automobile with automatic temperature control. If the complaint is no blower operation when
the floor mode is selected, the vehicle may have a problem with the thermal blower lockout
switch also referred to as the CELO (cold engine lock out switch).
The thermal blower lock out switch is located in the heater core intake hose. The two
wire switch has a thermal element with a small set of contacts, the contacts are open when the
coolant is below 120°F and closed when the coolant is above 120°F. The thermal blower lock
out switch also contains a vacuum switch, which applies vacuum to the outside/recirculate
valve when the system is in the floor position. When the engine coolant is below 120 degrees
and the selector is set to floor position, the thermal blower lock out prevents blower from
turning on and closes off the outside air during engine warm-up. When the coolant
temperature is above 120 degrees, and the selector is set to the floor position, the thermal
blower lock out switch allows the blower to operate and opens the outside air door.
In order to diagnose this problem, test the thermal blower lockout switch with the
engine at normal operating temperature (above 120°F). Unplug the wire harness connector
from the thermal blower lockout switch. Using a 15-amp fused wire, jumper the harness
terminals to test the switch. If the blower comes on, the thermal blower lock out switch is
faulty. If the blower doesn’t come on, look for an open between the control head selector and
thermal blower lock out switch.
In some cases the blower may continually run even when the engine temperature is
below 120 degrees. Unplug the thermal blower lock out switch and if the blower motor turns
off, the thermal blower lock out switch is faulty. If the motor continues to run, look for a
short to power between the control head selector and thermal blower lock out switch
Nov 04, 2008 | 1988 Lincoln Town Car
How to make Epson thermal printer print darker?
Change the dip switches settings to
Apr 25, 2008 | Epson TM-T88III Thermal Printer
there are 4 electrical parts
1 switch
2 thermal switch (keeps heater at around boiling temperature)
3 thermal fuse (will break if thermal switch gets stuck on, to prevent fire)
4 heating element (the hotplate and surrounding tube that boils water)
since the switch lights and hot plate is not hot then it is #2,3 or 4 that is not working.
it is most likeley the thermal switch which is not too expensive to replace.
check the thermal switch by disconnecting it from the wires. at room temperature the thermal switch should be closed. test with a meter set on resistance.
if it is not that check the thermal fuse in the same way, it should also be closed.
if those test ok and the heating element is bad (doubtful) then get another machine and save this for parts
Mar 21, 2008 | Braun Aromaster KF 400 Coffee Maker
Dryers Logo
Top Dryers Experts
