How can you increase receiver volume on Contour 50 payphone. The volume button doesn't do anything at all.
SOURCE: Hi, Ive got a BT Contour
You need to dismantle phone and replace Varta CR1/2AA 3Volt lithium battery. Dismantling is easy enough but you MUST lay out the screws etc so they go back in the right place, particularly the one with the two nylon washers underneath the head.
Posted on Jun 15, 2009
  • 3 Answers
SOURCE: The button for volume increase is not working. Nor
ye you need to purchasde one of these then get it fixed by someone. i had same problem! thats all the buttons covered even the side buttons and walkman button tooo
http://cgi.ebay.co.uk/Keypad-Keyboard-Membrane-For-Sony-Ericsson-W902-W902I_W0QQitemZ370104985825QQcmdZViewItemQQptZPDA_Accessories?hash=item562bf9e8e1
hope thats been of any help to you
thanks
Posted on Nov 11, 2009
shafykp750
  • 1070 Answers
SOURCE: we need instructions for a contour 100 payphone
Welcome to FixYa
Dear User,
Here is the Instruction Manual for you{it may take few minutes to load depends on Connection speed} Click here and Save it..Read carefully to get all details of your product...
It is necessary to Know Old Pin to Change your PIN.Contact the Person who sold the Product to you...He can give PIN Number...And Make Change it...
.If you for got PIN contact Helpdesk
  • Changing your PIn:Page 34
  • Contact Help Desk Details on Page 2 Right side
Hope you got an idea... If this Helps-DONT FORGET to RATE ME......Thanks for Contacting FixYa....
Posted on Jul 03, 2010
SOURCE: How easy is it to
HI,
I have just replaced the battery on a similar phone today (not a BT one, but a "Payphone Link 20", its belgian counterpart).
It was a bit tricky as the battery is soldered on both sides of the circuit board, but the battery was replaced in a matter of minutes and the phone works fine now.
I wouldn't recommend this to the novice however. You need good soldering skills + equipment, and basic knowledge of how to handle a circuit board without damaging it (i.e. short circuit or electro-static discharge).
If you're not sure, I would advise you to get it done by someone familiar with electronics repair. Otherwise there are several companies that could fix it for you : you send them the front of the phone by mail, they replace the battery, clean and check the phone, and send it back to you.
Posted on Sep 28, 2011
  • 1632 Answers
SOURCE: Everything is working except the
check your hearing at the medical center
Posted on May 15, 2012
Trouble dialling out - swamped by 'please insert coins on answer' message
inform the network provider
someone has hacked in and using to make free calls
let the network providers reset ontheir system
Nov 27, 2014 | British Telecom Contour 50 Corded Phone...
Porsche cdr22 volume increases and button will not dcrease
Most of these things use an IC to control things like volume etc. Chances are that will have failed.
Feb 25, 2013 | Pyramid Cdr22kit Am-fm Receiver Cd Player...
My Dell Latitude E5500 speaker is too low, how to increase volume?
If you have volume control in the system tray (bottom right corner), double-click it. In Windows XP you will see all the sound controls. Increase all to the maximum level (except microphone).
Use the buttons close to the screen to increase the volume.
There is a volume control in the player you are using. Increase it to the maximum.
If it doesn't help, please let us know.
Sep 10, 2011 | Dell Latitude E5500 Laptop
How easy is it to to replace battery in a Contour 50 payphone? One site says the soldering will blow the chips. Terry
HI,
Jul 28, 2011 | British Telecom Contour 50 Corded Phone...
Low ringer and receiver volumes
sir you can increase the receiver volume by when you are answering the call press the volume button to increase the reciver sound...............
Dec 26, 2010 | Nokia 3100
Fitting a new battery to a bt contour payphone
I have a bt contour 100 that had the same problem no dial tone and nothing on the screen this is easily fixed by soldering in a new battery or soldering in a battery holder / battery back that takes 3 aaa batteries in place of the old battery you may have to solder two separate wires into the positive side and one wire into the neutral side after the old battery has been removed once you have soldered two wires into the positive thoes two wires need to be connected to the positive side of the battery holder and the other single wire into the neutral side of the battery holder once done correctly when you have inserted 3 AAA batteries and reset the payphone it will start working again bare in mind when you reset the payphone the pin number will go back to its default setting you may have to contact bt payphone help desk to get the default pin if you don't already have it there is a company offering to convert the bt contour payphone to run on regular alkaline batteries which are easily replaced but getting it professionally converted would come at a cost you can easily do it yourself giving some basic knowledge of electrical wiring and some common sense. The payphone runs on a 3v dc lithium battery that costs £9.99 on some sites on the Internet I believe that you can also get it to work on a 3v DC adapter but I have not tested or tried running my payphone on a power adapter as converting it to run on aaa batteries is easier and quicker to replace
Nov 03, 2009 | Lands Phones
How to increase ringing volume and hearing volume
When you are receiving a call use the up/down or left/right rocker (the squarish thingy around the circular button in the middle) to increase/decrease the volume. This also works for the speaker volume if you have the speaker on.
HTH
JB
Jun 27, 2009 | Sony Ericsson T303 Mobile Phone (Shadow...
Im looking for the best avr reciever..for the money...i have a bigger room with sloped ceilings and the room echoes a little...its the liv room, kitchen,dinning room all rolled into one...about 20x20...
Only receiver that is better is one that has features that you want and need and do not currently have! Period. Unless you are an alien you cannot hear frequency response differences nor distortion on pure harmonic waves unless it exceeds 6%. My old stuff is still better than anything currently available - may not look as pretty but .........Other than that, the only really valid reason for another receiver is that you need more power because you like to blast and also add bass. (Every time you increase bass by 3 db you are making receiver put out twice the power at that frequency! 6 db is 4x, etc.) But spend your money - you are not going to get anything any better than your Denon - And if you want more power doubling the output in rms only increases the volume by 3 DB, the smallest difference that the human ear can detect. So if your receiver is rated 50 watts you get one with 300 or more to get any real increase in volume. Capiche?
Aug 26, 2017 | Onkyo Audio Players & Recorders
Hi, Ive got a BT Contour 100 Payphone, but there is no dial tone or display. Cheers
Apr 23, 2008 | Lands Phones
 Grubhead
Grubhead
