Question about Seiko Watches
I have a Seiko watch serial number on back is 8D4447 and on the band it has the numbers 32Y7-A-E
  • 8 Answers
SOURCE: seiko watch band
very tightly
Posted on Jan 02, 2008
  • 29 Answers
SOURCE: Convert Military Time Setting to Standard
If its the watch I think it is try holding in the top right button on the watch. That should change it back to 12 hour time
Posted on Mar 08, 2008
SOURCE: Casio watch band adjustment
Check the Citizen web site: http://www.citizenwatch.com/Technical/English/Service/pin1tube.pdf
You can skip the part about removing the split tube. Instead of their pin pushing tool, I used a short piece of straight pin held with long-nose pliers while I squeezed using medium sized channel-lock pliers. A helper to hold the watch would've been good.
Posted on Dec 26, 2008
escapement
  • 2334 Answers
SOURCE: Adjust watch band for Seiko 7T94 Stanless Steel Band
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Apr 04, 2009
  • 110 Answers
SOURCE: How do you remove a back off a old seiko watch
If you see the indentations on the case back to accomodate a tool, then you need that tool and unscrew counter clockwise. If you don't see those indentations then the case back then you should be able to pry by using the proper tool. You might be able to use a small bladed tool, like a knife, but be very careful that you dont slip and cut yourself. Go between the case and one of the band posts to get leverage.
Posted on Nov 10, 2009
Need help identifying watch
Take it to a local jeweler and they will tell you all about it for free.
Search Results
How to tell when your Seiko watch was made (Part 1)
quartzimodo.com/how-to-tell-when-your-seiko-watch-was-made-part-1/ Sep 21, 2010 - If you can't see the serial number on the glass, then look for them on the caseback ... Every Seiko watch manufactured is given a 6-digit serial number. ...... Your old Seiko watch is likely to be from the Seiko Sportsmatic or the ...
WatchSleuth - Seiko Date Finder
www.watchsleuth.com/seikodatefinder/ Seiko Date Finder - Find out when your Seiko watch was made. ... In the example images the serial number is highlighted in blue. Every watch has a unique combination of reference ... the watch was made. Looking at the example images:.
Watch Finder ' Seiko
www.seiko.com.au/collections/seiko-watch-finder Watch Finder. Seiko Watch Finder ยท Seiko Clock Finder. Search by Model Number. Collection. - Any -, Grand Seiko, Astron, Prospex Platinum, Prospex, Presage
images below
older seiko watch with dubai australia chicago on bezel Google Search
Jul 31, 2017 | Seiko Watches
My kenetic battery ( i think) operated watch ,N0, on the back plate-
First, does it say "Kinetic" on the face of the watch? If not, it is not a Seiko Kinetic. (You did not mention if it was a Kinetic or not.)
Second, the Serial number is not like any Seiko Kinetic I know, which is 2 4 digit numbers.
Third: The number you gave itself may indicate the type of button battery you need.
Good luck.
Mar 02, 2013 | Seiko Kinetic watch
The ease of repairing Seiko watches.
No. First off no watchmaker has a "parts account" with Seiko. Seiko only sells watchbands to watchmakers. All other Seiko parts are sold through supply houses.
Seiko parts are not hard to find most times. The very old Seikos will have parts issues and some of the current styles of Japan only Seikos will not have parts available.
Case tubes for all Seiko watches are not available at all.
Finding parts for Seiko watches requires the use of the watches model number which is on the case back of the watch. The number listed in the title is not a model number. The SKA098 is a retailers number so the retailers can reorder the watch. It does not cross reference for parts.
There are many watchmakers that don't want to service Seiko watches so they can and do make up all kinds of stories as to why it is impossible to repair them and so on.
Actually Seiko is much better about parts supply than any of the Swiss watch companies.
Hope this helps.
Ken
Yellowstone Watch Inc.
Oct 01, 2009 | Seiko SKA098 Wrist Watch
I traying to find a band for my watch is metal but i do not know it model it call seiko kinetic SQ 100 it is golden all around with white back ground and it has a calender
You can try Seiko for the band. That band is pretty common in both Seiko current models and after market brands such is Speidel.
There is a 18mm metal band that is almost exact from Bariloche available in some watch repair and accessory stores. You can also check Speidel.
Sep 17, 2009 | Watches
I have broken my wrist band for my watch.....
You should be able to purchase a replacement band at any local watch dealer. They will need to measure the width of the band where it connects to the watch, and then can offer you a variety of styles to choose from for a nominal cost.
Mar 25, 2007 | Vanceur Royal Castle CG35S Wrist Watch
Watches Logo
24 people viewed this question
Top Seiko Watches Experts
Jerry Greenberg
Jerry Greenberg
just-ice
Are you a Seiko Watch Expert? Answer questions, earn points and help others
