Question about Maytag MSD2756G Side by Side Refrigerator
Light on freezer door stays on dim until door open
If you push the light button on the panel it will get brighter how to turn it off without removing bulb
maytag plus side by side
    Champion:
  • 363 Answers
Did you try pushing the light button several times. It might be the dimmer type
Posted on Jul 26, 2009
How do I replace the lights in my freezer
Turn off the power to the refrigerator/freezer by flipping the appropriate switch in your breaker panel. Alternatively, unplug the refrigerator from the wall outlet.
Open the freezer door. Remove any items from the shelf directly under the light shield, then remove the shelf.
Press down on the top, front edge of the light shield until the locking tabs slip out of the slots. Swivel the light shield downward slightly to release it. Pull the shield out of the freezer compartment and set it aside.
Turn the light bulb counterclockwise to remove it. Insert the GE replacement bulb into the light socket and twist it clockwise.
5
Reattach the light shield by sliding it into place. Gently push the tabs into the original slots.
6
Insert the shelf into the freezer and reload it with the frozen food removed earlier.
7
Close the freezer door. Restore power to the refrigerator by flipping on the breaker or plugging it into the wall outlet.
Jul 25, 2017 | Freezers
No alarm sounding but red light is flashing?
Warning light (red)
If the temperature warning light (4) lights up, it
indicates that the temperature within the freezer has
reached a level where the safe food storage is no
longer ensured. When the freezer is first switched on, the warning light will stay on until the temperature has dropped to
a safe level for the storage of frozen food.
Temperature acoustic alarm
This appliance incorporates an alarm which gives off
an audible signal whenever the warning light comes
on. This signal can be temporarily stopped by
depressing the push button for fast-freezing (6).
The fast-freezing push button can be released as
soon as the warning light is off.
Open door acoustic alarm
This appliance also incorporates an alarm which
sounds if the door is left open for more than 60
seconds. The signal will be stopped when the door is
closed again.
Dado
Sep 02, 2014 | Zanussi 3.53 cu. ft. / 100 liter Upright...
The interior lights stay on when the doors are shut and sometimes go off when you open the doors.
I have the same issue! It seems to me that the lights stay on until the bulbs get to hot and thats when they turn off on their own until they cool down enough to turn on. That leads me to believe that the little buttons that the doors push in (at the top hinge side of each door) are no longer turning the lights off when doors close. A wiring issue, or something. I litterally just took the bulbs out of the refrigerator. The freezer switch/lights work fine. I hope to find an answedr, if i do, I'll let you know!!
Aug 25, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
Frigidaire frs26r4a after opening and closing freezer door all panel lights are on - both cube and crushed ice panel indicators, and the light that illuminates the water and ice dispenser remains on until...
The only thing that I can see that would cause that is a broken freezer door light switch and possibly the power going through the adaptive defrost. Broken or fused to cause the power to come on when the door is closed...Click Here=> FRS26R4A I blieve i can help you with this if you are willing to work and communicate with me, Thanks Sea Breeze
Dec 25, 2010 | Frigidaire FRS26R4A Side by Side...
The interior lights stay on and the door ajar light is on when driving. the interior lights stay on when you shut off the car thus running the battery down. It happens about 70 percent of the time and when...
Find the lamp push button on each door.
Open one door, and only one door (or tailgate).
Push the lamp button IN at that door. If light goes out, then that particular push switch needs adjustment or replacement.
Cl;ose door and open another door. Push button IN.
Keep doing this until you find faulty door push button.
Which door was it?
Sep 24, 2009 | 1998 Lincoln Navigator
Dome light and doors open light stay on when driving.
check you door switch buttons to see if they will each turn off the lights. Open one door at a time, push the door push button by hand and see if the lights go out. If they do, that is your probelm switch or the door is not closing tight enough to psuh the pluger button all the way in.
Apr 25, 2009 | 1999 Ford Taurus
2005 Ford Expedition XLT, major electrical problems
You have a wiring harness problem
Take it to the dealer directly.......
Nov 18, 2008 | 2005 Ford Expedition
Change oil light remains on after oil change and light over license plate does not work after bulb change
To reset the Change Oil Light: Open driver's door and open fuse access panel
Turn ignition key to on (don't crank the starter) Push reset button located in fuse panel When Change Oil Light starts to flash Press and hold reset button until it beeps and light goes off Repace panel
Jul 17, 2008 | 2003 Oldsmobile Alero
Outside door light won't turn off
Please post the model number so I can pull up a schematic. Some models have a "night light" mode that may have been activated so check the owners manual, other than that the control board could be bad, providing a slight "leakage" of power to the lamp (depending on the type of lamp control circuit).
Dec 27, 2006 | Maytag 22.6 cu. ft. Side-By-Side...
Maytag MSD2756G Side by Side Refrigerator Logo
128 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
