Question about Green Cameras
Sceen is black but green light is on camera - Green Cameras
  • Green Master
  • 5,357 Answers
Why do you keep asking the same question, without supplying the information requested ?
Posted on May 10, 2017
Screen won't light up
I'va seen this trouble on a panasonic lumix Lx 7 a while. The fault was the backlight of the screen that was "burned" (?) with moisture and rust. IMHO your camera is gone if you can't found the right sceen replacement. Not too hard to replace but need skill and tools.
Nov 30, 2013 | Panasonic Lumix DMC-TZ3 Digital Camera
Horizontal white lines 27A43.
You have some bad capacitors. They are located very near and next to your vertical IC. I would guess you would have to replace maybe four of these! Thanks for asking!
Jun 12, 2010 | Toshiba 27A43 27" TV
Screen goes black, but power light is on (not blinking)
The problem is not with your screen. Its the problem of Video Card of your system which is unable to send Video Signals to the Screen.
Apr 23, 2009 | Daewoo L700C 17" Flat Panel LCD Monitor
Black screen
Assumed that LCD screen is black and what about Eye piece viewfinder? Does it show picture to you?
If LCD Screen is black, it means it has no back-light. check any button to turn back light on & off at LCD portion.
There can be an other reason of black LCD. a flexible cable which connects LCD and Camera circuits and it can be broken/ cracked/ out of order.
May 30, 2008 | Sony Handycam DCR-HC14E Mini DV Digital...
Turn on camera but the lcd sceen is black
I tried all the solutions offered on the net and none worked except one. It simply said "hit the camera with the palm of your hand" (when it is on) and the screen will return. I thought, well I have nothing to lose and so I hit it on the side and sure enough the LCD is again working !!! Contacted Canon prior to this and they had no idea but suggested I send it in to be repaired at a cose of $163.50 Australian. Pleasant staff they have, but no help in solving what looks like a common problem of Canon cameras. I will have second thoughts purchasing Canon from here on in.
Mar 23, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Laptop
Most laptops will run without the batteries, its only a few that won't however I do not know for your specific laptop. So its a possibility. Although, the two lights mean that the unit has power so its likely that it doesn't need a battery and the laptop won't boot.
Do you know what the green flashing lights represent?
Jan 16, 2008 | Compaq Armada 1700 Notebook
Have you checked the display mode you're in? If you have the display set to off (to save power) and also the picture review time set to off, then you'll just see a black screen. Try pressing the 'Disp.' button below the screen when the camera is on - it should cycle through different settings with each press: Off, On, On with picture info. Similarly, in the playback mode this will show you more or less info about the picture you are viewing.
Even if the display is switched off, if you have your 'review' option in the menu set to anything other than Off (i.e. 2 seconds), then you should see the picture you've taken appear on the screen straight after taking it.
If it's not that, then I don't know the answer....
Oct 17, 2007 | Canon PowerShot S500 IXUS 500 Digital...
Seeing green du42px12x
I don't have a solution, but have a similar problem, when sceens change, red and green pixels form and create a burn in effect from the privious sceen. It happens after the TV has been on for at least an hour. I notice it most when goinf from a light to dark sceen. Any help would be great
Dec 24, 2006 | LG 42PX5D 42 in. Plasma HDTV
Black LCD screen on camera
Just had the same problem (black display). I moved my hand in front of it and took pictures of things but nothing happened. Then my girlfriend tried to point it to a lamp, and all-of-a-sudden it kinda woke up from a screensaver or something. So weird, but it worked. Perhaps it needs enough light in order to start using the display and lens. I couldn't take any pictures when the LCD was black. So, try pointing it towards a strong light source before you break your camera.
Aug 30, 2005 | Pentax Optio 330GS Digital Camera
Cameras Logo
43 people viewed this question
Top Green Cameras Experts
NOEL
NOEL
Are you a Green Camera Expert? Answer questions, earn points and help others
