Question about Ovens
I'm looking for favorit element for the oven, black in colour.
I turn on oven with oven/grill switch fan and light comes on but noheat
ISOLATE THE OVEN FROM THE MAINS SUPPLY
Inspect the heating element , if there is a hole blown grey colour slightly at the hole or could be a black rim around it as if its been heated too much in one place, a tester is required if no visible signs shown, continuity through the element should be achieved , if no continuity replace it , also inspect the switch and any wiring if the wiring is burnt one of the regulators will have a problem. Parts for most ovens can be obtained from espares.co.uk
Hope this is helpful
Regards
John
Nov 01, 2014 | Ovens
Need User Manual Kuppersbusch Okotherm Double Oven
The age of the oven may make it difficult or impossible to find the information you are looking for.
Jul 08, 2014 | Kuppersbusch Ovens
Hi, I have a Neff Double Oven (U1721N0GB/02). In the process of replacing the main oven element (which was clearly visibly faulty) I think I may have casued a short-sircuit / blown an in-line fuse. I have...
Did you replace the element from inside the oven cavity? If so, you may have knock off one of the spade connections whilst pulling the bracket through. Isolate from mains, remove back panel behind oven (not in the cavity) and check you don't have a wire floating about. The wires usually look quite similar but if you look closing they should have a black or red fleck in them, the element has two prongs on each side, you need to put the two the same colour on one side and the other single different colour on the other prong. If the fan is working then you have not blown the limiter that you will see quite close to the fan, but you might have blown the thermostat or the selector switch. If the red light comes on the fascia when you select the temp then it's pretty safe to assume the thermostat is ok. Hope this helps
Mar 24, 2013 | Neff U1721 Double circotherm Electric Oven
Hi there Have recently moved into a house with a Belling 626 white, electric cooker and the grill doesn't seem to be working. It has a mian oven, top ovem and "dual grill". The main oven...
ISOLATE THE MAINS POWER BEFORE CHECKING THE APPLIANCE
Run your fingers along the grill element, in this model it is accessible, check for raised areas or small hole or roughness not food burnt, if visible, it should be Black Grey colour at the blemish, you can obtain parts from www.whitegoods.co.uk you will need the model and serial numbers.
The grill elements come out but when unsrewed sometimes the ceramic holders crack, remove element before ordering as you may have to replace the element holders.
Hope this has been helpful
john
May 31, 2011 | Belling Ovens
HI I have a Beko Electric oven (model SCC 2632). It has a combined oven and grill element which i redently had to replace. Fitted it no probelm, but when it came to attaching the coloured wiring spades...
Have a beko scc 2632 cooker. Need to know the colours of wires fom left to right of grill/oven element as it is different than the old element?
Jan 29, 2011 | Ovens
Leisure rangemaster 110 fan oven element replaced but still does not get hot
There are 3 possibilities:
Faulty thermostat
Faulty wiring
Faulty oven control switch
Thermostats fail more often in the closed position which means your oven will overheat so I'd test the wiring first. You'll need an Ohm meter to do this. TURN THE POWER OFF FIRST, expose the element and switch then trace the wires from the live and neutral terminals on the element back to the switch. If you can't trace them, make a note of their colours (at the element end) and test for continuity/resistance with wires of the same diameter and colour at the switch. You should get a reading of zero ohms if you have good continuity.
The easiest way to check the switch is visually. Make a note of the wiring colours and their positions on the switch terminals, disconnect them and remove the switch. See if anything looks broken or the
Some thermostats can be disassembled and inspected, but I don't recommend it unless you know what you're doing. The gap between the thermostat switch contacts needs to be precise or the oven wont heat to the correct temperate.
If you can establish that the wiring and switch are OK, try replacing the thermostat.
Oct 15, 2010 | Ovens
Need to know wiring for element
i removed the wires from the fan and element and cant remember which colour wire goes where is thir a pictures for baumatie oven that i can use as a guide
Feb 20, 2009 | Ovens
Oven made a loud noise, pop, and then black smoke....could heating element go out?
sounds like it blew a fuse or the heating element burnt out on it,look to see if the element is burnt in two
May 16, 2008 | Amana AEW3530DD Electric Single Oven
Neff Fan Oven Element _U1661
hi there green and yellow is allways the earth connection which is usually the middle tag, what are the colours of the remaining wires and how many are there???
Feb 08, 2008 | Neff U1661 Double circotherm super...
Ovens Logo
26 people viewed this question
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
