Question about Car Audio & Video
Wedge radio/cd has no volume but all functions appear to work, just no sound.
SOURCE: No sound
I had the exact same problem. I disconnected the radio from the power cord in the back, waited several minutes, reconnected the power cord and my radio had sound!!
Posted on Nov 16, 2008
SOURCE: 2004 Chevy Trailblazer radio and CD player works, but no sound
if you have installed a new cd player in there then the propblem could be that your speaker wires and either touching each other or grounding them selfs out.. pull of the cd player and check to make sure all the speaker wires are covered properly and no bare wires are exposed.. if you still have a factory cd player in it then you will probably need to take it to a dealership to have it checked out..
Posted on Feb 23, 2009
techprogrami
  • 57 Answers
SOURCE: No sound comming from the left side speakers in my 04 Envoy XUV.
first> road vibrations can cause cable connections to come loose so you can start by taking out your radio and making sure all of the questions in the back are connected as they should be.
Second> if this doesnt seem to work then the next step is to check the wires going to the speakers that arnt working (this will b quite a job, but if you can do it, it will save u quite a bit of money) .. checking the wires your checking for >bad connection to the speakers >cuts in the wire or if any part of the wire is touchin any other metal object
Was This Helpful ?
Posted on May 29, 2009
sodeep
  • 3267 Answers
SOURCE: CD player has no sound - Bose wave radio/cd player
Amplifier chip/circuit is kaput. Unless you are familiar in fixing electronic equipments better to give it for repairs................sodeep
PS. Buying a new one will not be cost effetive unless you need a change!
Posted on Jun 28, 2009
SOURCE: No sound coming from XM radio/cd player/local radio
Posting this in hopes of saving others from the same problem. Simply pull the premium amplifier fuse out and put it back in. You will find the fuse on page 5-96 of your owner's manual, it's in the underhood fuse block. It is labeled "PREM AUD". This resets the premium audio amplifier. Worked for us and saved us hundreds on replacement radio and installation.
Posted on Apr 05, 2010
2001 honda odyssey...my radio works fine, but the CD player wont accept any discs!
If its a 6 disk cd system the cd tray is wedge causing the cd option to not work. Most of the time one of the cd slipped out of its position causing it to wedge
May 19, 2015 | 2001 Honda Odyssey
How does the display on my CD/radio work?
Sorry to hear the display is blank even though the cd radio appears to function. The display is usually an LCD with back panel lights that makes the characters visible. Most likely the small rice globes behind the panel are blown. Usually needs some sort of desoldering and resoldering to replace. If you can take the player out from the dashboard and take it to the local audio repair shop you will save quite a bit of money to get this fixed.
I am assuming your CD radio looks something like this.
http://www.beckerautosound.com/pdf_guides/om43-4462.pdf
Jul 30, 2014 | Porsche Boxster Cars & Trucks
Replaced Car battery, now stereo not working properly
Have you tried resetting the microprocessor?
Remove the detachable face. There is a small pinhole on the front of the radio about two inches from the left side near the bottom. Press this in lightly with a fine point pin or paper clip. Hold about 3 seconds, then release.
Replace the face and try it. Let me know.
Dec 16, 2013 | Sony Xplod CD Player w/MP3 Playback...
I have a 2008 hyundai elantra...when listening to the radio or cd it sounds like someone is messing with the volume, turning it up and down.
If the issue you are describing follows this pattern (when slowing down, the radio turns down in volume, and when speeding up it turns up in volume), then your vehicle is equiped with an automatic volume control. This function was to allow the operator not to have to touch the volume control while driving. The volume increases to compensate for road noise. You should have a function control button that will allow you to turn this function off. Hope this helps.
Aug 20, 2011 | Car Audio & Video
My volkswagon jetta car radio is frozen on a particular station and no sound is coming from the speakers. The display lights up and the volume control moves, but no sound and no other functionality. I...
Could be the radio need to be reset, some digital radios freeze some times , to reset disconnect the current (12v)to the device "car radio"and then connect it back again , If you dont find the 12v cabel to the radio, option 2 is to disconnect the battery on the car itself.
Aug 06, 2017 | Volkswagen Car Audio & Video
2007 Saturn Ion radio will not turn on. At first, no volume so I shut the vehicle off and back on and it appeared okay. The radio never turned on the next time I started the vehicle. I checked all three...
I have a 2006 saturn ion and the radio wont turn on...there is a picture of a phone on my radio display and when you turn the vol up to 20 or so there is a buzzing sound any ideas
Oct 25, 2009 | 2007 Saturn ION-2 Quad Coupe
Clarion radio sound flickers
make sure your wirings are rated to handle the current needed by your radio. You might have a large voltage drop when it is at high volume level because it will draw lots of current. You might need to change the size of your wires to your Clarion. Check the voltage near the radio when it starts to flicker if it goes below the source voltage of 12V. hope this helps
Aug 17, 2009 | Clarion M475 CD Player
CD's won't play in Jensen VR185
Do you have it set on mp3
Aug 11, 2009 | Car Audio & Video
Everything works except the radio. It appears
If have factory amp you have to find the turn ou wre for the amp and hook it up to the amp turn on wire from the radio(bootleg way sound might cut in & out) or go to local sound shop and get a bypass for the amp
Aug 07, 2009 | Jensen's VM9312 Car DVD Player
Car Audio & Video Logo
37 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
