When I select a programme to record a series it is also doing the programme on the +1 channels. How do I change this?
  • 67 Answers
SOURCE: Recording HD channels
well you would need to hook up cable box to dvd recorder. the only draw back first off is one you cannot get hd onto a dvd. you can down scale and it will seem a little cleaner than standard def but of coarse it will never be high def. I'm not to familiar with the motorola boxes but if they offer dvr's in your area i would suggestgetting one you can record all channels then afterwards transfer them to a outside device. but as i said before high def cannot fit onto a dvd unless you plan to copy one movie to 6-7 disc. Just keep in mind a standard high def channelcan only fit 2 max on one freq due to the amount of data transfer as opposed to 10 to 12 standard def digital channels
Posted on May 08, 2009
SOURCE: I have purchased a Teac HDR2500T video recorder. I
The part re the other channels having no signal....I had the same problem with mine and that was because the small loop cable in the back wasnt right. I could watch all channels, press record and still watch that channel but try to watch a diff channel while its recording and they were gone. As soon as I had the loop cable in properly it solved the problem. Hope this helps....
Posted on Sep 06, 2009
  • 1340 Answers
SOURCE: my freeview digital recorder which is a twin tuner
It sounds like you simply don't have the cables hooked up corectly to allow that.Would you please tell me how it is hooked up?For instance,what the outside cable is hooked up to input etc. I need to know everything you have available,and what OUTPUT and what INPUT is connected to where,starting with the outside cable,and if there is a cable box or not.Literally everything connected for use with the TV.Greg
Posted on Dec 08, 2010
  • 209 Answers
SOURCE: hi i have a samsung
Be sure you have the right time zone selected in settings. It sounds like that may be the problem.
Posted on Apr 03, 2011
SOURCE: My Sagem DTR 6400T/6700T does not always record a
does not record programes
Posted on Aug 27, 2011
How can i record series options
From the Programme Guide select the programme you want and press OK. Then select the 'Record the Series' option. Note that this option will not appear for one-off programmes such as films.
Aug 03, 2014 | Humax PVR9300T HD DVR
I have a THS220 box and have difficulty recording programmes
Hello Joan,
To record a satellite you will need two scart leads.
Plug one end of the first scart lead into the "DVD/VCR SCART" socket on the back of the satellite receiver, then plug the other end into the "INPUT" scart on the back of the VCR. Take one end of the second scart lead and plug it into the "OUTPUT" socket on the back of the VCR and plug the other end into "SCART IN" socket on the back of the TV.
To record, select the satellite channel you want to record, then, on the VCR, select scart input, (at this point, you can record a satellite program). To watch a satellite channel or recorded satellite channel, select the scart input on the TV.
If you need anymore information, then let me know.
Kind regards,
Ron.
May 04, 2014 | Thomson Audio Players & Recorders
I have a Thomson DTI6300 which has given many years of very heavy use and still going. However, since switching to Freeview EPG the series record function is recording EVERY occurance rather than just the...
If you select all the available channels for Anytime to download from then the box divides up the available drive space in such as way as to leave you with just 16 hours' worth of space for your personal recordings. The only way to free up more room for your own recordings is to reduce the number of channels you want downloading, which rather takes away the whole point of the system to start with, and also is not actually much of a remedy. After pruning the channel download list quite ruthlessly we were still only left with 31 hours of personal space and that is still really not enough.
The Sky-like UI
This box needs a fair bit more disk space or a more fluid method of dividing up the available space, perhaps by allowing you to alter the length of time the system stores downloaded content. As it is, programmes downloaded will erase themselves after six days unless moved into the personal storage - so exit the 31 hours, stage-left, at a gallop - thereby ensuring the hard drive always has space for the following period's downloads.
Fortunately, the box is smart enought to automatically check that no programmes downloaded overnight match any of the programmes already recorded to avoid doubling up on content.
Dec 05, 2013 | Televison & Video
Can the LG 990W VHS VCR receive digital TV signal
VCR is analogue, However you can still use it to record digital programmes when connected via a digital set top box. You can only record the channel you have selected on the screen. In other words, you cannot record a channel programme while watching another channel. I use mine on a second TV and when recorded I take the tape out and put it into my main TV for viewing at a later date. I don't watch too much TV so it works fine for me for the odd programme.
Dec 05, 2010 | LG MG64 VHS VCR
Grundig GUFSDTR500HD FreeSat PVR Problem
Hi There, I've never had this problem with my Sky box, it knows which programs are repeats. I suspect its a problem with the GUFSDTR500HD. I have had two of these boxes from Costco, and both have both been as buggy as hell. They have recorded random programmes, they have missed recording programs, they often crash (black screen), series link seems to get it's knickers in a twist, and the up and down directional buttons fail to work after coming out of the guide or menu screen. To top it off, I found that the remote control also interferres with my B&Q fireplace... cycling through the colours when I change channel. Both of these boxes have gone back to Costco and I will never touch another Harvard Group (previously Alba, including Bush/Goodmans/Grundig) box again. Back to sky HD for me!
Feb 24, 2010 | Televison & Video
My Thomson Top up TV box will not record. I go to the TV guide, press the R button. It then takes me to 'Planned Recordings' list. I press R again and the programme I want to record disapperas. I get...
Sounds to me like your hard drive is full. Do you use the topup tv part of the box? If not, deselect all the topup tv channels. This will free up a significant amount of drive. Failing that, you'll have to delete some of your programs, sorry!
To deselect topup tv channels;
Go into the menu option, Customise Top Up TV Anytime, and de-activate all the selected channels
Jan 23, 2010 | Televison & Video
I have purchased a Teac HDR2500T video recorder. I can set up to record television programme through EPG or PVR. I can see in LIST that the programme is recording, however when the programme is finshed,...
Sep 06, 2009 | Televison & Video
How do i tune my philips 3590H philips dvd recorder into digital
The User Manual for your DVD Recorder is available here... http://www.p4c.philips.com/files/d/dvdr3380_05/dvdr3380_05_dfu_eng.pdf
Info related to your specific problem is as follows...
Setting your TV channel
programmes
Before the recorder can start recording
the TV channel programmes, you need to
search for the available TV channels and
store them in the recorder.
Note: Make sure you have successfully
made all the required connections to the
recorder, the TV and Satellite Receiver/
Cable Box (if any) and switched them on.
Tuner settings can only be changed
when there is no disc in the disc tray.
A Press SYSTEM-MENU on the remote
control.
�� The system menu appears on the TV.
B Use ���� keys to highlight
{ System Menu - Channel Setup }
and press ��.
Modify Channel Information
Sort Channels
Channel Search
Edit
Sort
C Use ���� keys to highlight { Channel
Search } and press OK.
�� The automatic TV channel search
starts. This process may take several
minutes. Once complete, the total
number of channels found appears on the
TV.
Automatically scan all the receivable analogue local TV
channels and store these channels on the recorder.
�� Use ���� keys to highlight { Channel Search } and press OK.
�� The automatic TV channel search starts. This process may take
several minutes. Once complete, the total number of channels found
and stored appears on the TV.
Modify Channel Adjust a stored TV channel to your preference, improve the
Information reception and the sound quality of that TV channel.
1) Use ���� keys to highlight { Modify Channel Information } and
press OK.
�� The channel menu appears.
2) Use ���� keys to select one of the options.
{ Name } – You can use the numeric keypad 0-9 to select
the channel preset number which you wish to
change.
– Use ����keys to change alphabet/ number and
use ���� keys to select different entry fi elds, then
press OK to confi rm.
{ Scan Mode } – Select TV channel search mode based on
channel allocation or frequency.
– Use ���� keys to select { Frequency },
{ Channel } or { S-Channel } (Special Channel),
then press OK to confi rm.
{ Frequency } – Shows the frequency of the current TV
channel.
– If required, use ���� keys to start the automatic
frequency search and press OK to confi rm.
{ TV System } – Set the TV system that produces the least
distortion of picture and sound.
– Use ���� keys to select a suitable sound mode,
then press OK to confi rm. (See chapter “TV
System Guide” at the back of this manual for
more information).
{ NICAM } – Turn on or off the digital sound transmission
system which improves the sound quality of the
TV channel.
– Use ���� keys to select { On } or { Off }, then
Dec 12, 2008 | Philips DVDR3380/05 DVD Recorder
Wharfedale DVDR24HD250 DVD Recorder When set up will not find any programmes on Automatic Programme Search (APS)
Products such as this will use an internal tuner to tune channels, this tuner will not detect your televisions freeview stations, to record from your television, connect scart out from tv to the scart in on the recorder, then select the scart A/V channel, use the television to select the channel you want to record, you will not be able to record 1 freeview channel and watch another freeview chanel as you only have 1 digital tuner (in the television) the recorder does not have freeview built in.. hope that helps
Mar 24, 2008 | Televison & Video
RECORDING PROBLEM
Connectivity problem. Without knowing your models and their available channels etc., it's very difficult to advise you exactly.
Broadly though ...... you need to get the input signal routing sorted.
Plug your aerial into the Freeview box. Make a connection from its RF out, (beside the aerial 'in' socket) to the aerial 'in' socket on the JVC. Run yet another co-axial connection from the JVC RF 'out' to the television.
Now - connect a scart lead between the JVC and the TV. Power off the freeview. Switch your TV to accept A/V - to show the JVC on screen. Read/go through the 'Set up' procedure on the JVC to scan in the available broadcast channels. When done - connect using a scart between the Freeview box and the JVC. This will be located on either the L1 or L2 channel selection.
IF as it seems you are using the freeview to watch all your programmes - and record in then you are simply watching and recording 'live' change the Freeview programme and the JVC gets that same one arriving in (and sending to the TV)
Unless you need to record Freeview only output - always record from the aerial input. You select via the television remote (and 'TV' selected) and the appropriate channel.
Complex to explain - hope it helps. The one thing to remember - is to make one set of changes at a time - check the result is okay, before moving to the next.
Jan 07, 2008 | JVC DRMH20 DVD Recorder
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
