Question about Refrigerators
I had a power surge and now my refrigerator control panel shows freezer temp 5y and refrigerator temp CF. what does that mean? Model #FPUS2698LF
Brand Frigidaire
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 56 Answers
Switch it of and remove the wall plug for ten minutes then replug and see if it has resets
Posted on May 10, 2017
My Frigidaire refrigerator that is in our cold garage has an error code of 5Y on the freezer side and EF on the frige side. What does this mean?
5Y ef means evaporator fan issue. Could be wiring to the evap fan as well.
From the site: "I had a 5y ef error and it ended up being the control board."
Here's a link to a really good video:
https://www.youtube.com/watch?v=gCRKLkk9HmA
Hope this helps:)
Jan 01, 2018 | Frigidaire Refrigerators
After a power outage my maytag model MFI2569DEQ1 fridge display panel won't light up. Pushing any button lights up everything and 88888 across fridge and freezer temps...
Unplug it for a couple of minutes, Try again. It may have been hit with a surge. IF that is the case, you are looking at main control board and some money. Contact your homeowners insurance if a surge has damaged it.
Jul 31, 2017 | Maytag Refrigerators
How to fix error code H1
Frigidaire Refrigerator Error Code = SY CE
Condition = Communications error at power up
Repair or Check = Check wiring between control board and user interface
Parts Needed = Control board or User interface
Frigidaire Refrigerator Error Code = 4
Condition = Fridge and the control board goes through cycles but does not detect a damper connection
Repair or Check = Check air damper
Parts Needed = Air damper
Frigidaire Refrigerator Error Code = 5Y EF
Condition = Evaporator fan circuit failure
Repair or Check = Check wiring between evaporator fan and control board
Parts Needed = Evaporator fan or control board
Frigidaire Refrigerator Error Code = EF
Frigidaire Refrigerator Error Code = dF
Condition = No defrost circuit
Repair or Check = Check wiring between defrost circuit and control board
Parts Needed = Main control board or Wiring harness
Frigidaire Refrigerator Error Code = H1
Condition = Freezer sensor shorted in freezer display
Repair or Check = Check wiring between thermistor and board. If correct, replace thermistor
Parts Needed = Thermistor (temp sensor)
Frigidaire Refrigerator Error Code = 5y CF
Condition = Communications failure at power up
Parts Needed = Control board or user interface
Sep 28, 2016 | Refrigerators
I have a Frigidaire gallery refrigerator with a error code 5y cf I put in new ice maker and a new control board still have same code anybody got any sugstions plase
hello jon;
my name is peter. i am a retired field service refrigeration technician.
cf= cooling fan. is your freezer fan running? is the back wall of your freezer section iced up? is your fresh food section cold?
send me your model number. it is on a label, on the inside wall of your fresh food section near the top.
Jan 21, 2015 | Frigidaire Refrigerators
I have a Frigidaire Gallery refrigerator model no, FGHS2679KE0 on the temperature control panel the display reads 5Y CE and the alarm is on what does this mean
Hey friend, thank you for your inquiry!
Based off the information you have provided your Frigidaire refrigerator is displaying "5Y CE". I have researched that code and believe it is an error code of "SY CE" which means a communication error after power up. I would recommend resetting your refrigerator and you can do that by disconnecting power from your appliance for ten minutes.
If that does not help correct the issue it could be a faulty main control board or user interface board. I would consult with a technician to come out and provide an accurate diagnosis. I hope this information is helpful. -Matt
Oct 17, 2014 | Frigidaire Refrigerators
Temp display on door is giving wrong display
this is a fault code.. take a picture of the panel and post it here also picture of the model and serial tag.....I can find the fault codes with the info asked for............ ken
Sep 30, 2014 | Refrigerators
My side by side on the temp door reads 5y CE. I unplug and replug and it is ok for awhile
Thank you for your question, Friend.
Typically error code SY CE, is commonly referred to an issue between the main control board and the user interface (the control on the Freezer door). A tech would typically check the communication wiring wires between both parts to determine the cause of the error code. If the wiring is correct, then more than likely you are looking at a faulty main control board or user interface. Regrettably, this is not a simple DIY job. I would highly recommend reaching out to an expert technician to ensure the appropriate replacement part is ordered and is installed correctly to prevent future issues. I hope this information helps to some degree - thanks for your question, and please do not hesitate to reconnect. - Z
Sep 14, 2014 | Frigidaire Refrigerators
My frigidaire is displaying SY CF
Hello Angela Clark - Typically error code SY CF indicates that the refrigerator has detected a communication failure after power up. Contact a professional to move forward accurately. The wiring between the main control board and user interface board will need to be check and diagnose. Depending on the diagnoses the main control board may need replacing.
Dec 05, 2012 | Frigidaire FGHB2844L
Freezer high temp light is on. So is fast freeze. It's been plugged in at least 24 hours but not freezing.
FREEZER HIGH TEMPERATURE WARNING LIGHT DOESN'T GO OUT.HOW TO CANCEL OR RESET?FOR HOTPOINT FFA74.THANK YOU
Mar 11, 2011 | Hotpoint FFA70 Bottom Freezer Refrigerator
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
