Question about Bryant Heating & Cooling
HOW MANY TON IS A bryant furnace FA4CNF030? - Bryant Heating & Cooling
    Problem Solver:
  • 12 Answers
2.5 tons , it is 30000 btu
Posted on Jul 16, 2017
  • 1,277 Answers
030÷ 12 = 2.5
Posted on May 10, 2017
Model 393 Bryant furnace fan or motor makes noise when first starting. Then it's quiet.
https://www.repairclinic.com/PartDetail/Bryant-Furnace-Dual-Run-Capacitor/P2914553RS/2386586?ss=a36b380&mr=0
That part is probably going bad. The motor uses it to get moving and when it fails then the motor wont start, makes buzzing or humming noise due to phase loss.
Jan 28, 2017 | Bryant Heating & Cooling
WIRING DIAGRAM FOR BRYANT 127ANA036-A
The blue wire from the Ac goes to the y2 on the board for the furnace the yellow and brown goes to c on the board for the furnace and the last wire goes to y1 on the board for the furnace
Jun 16, 2014 | Bryant 462AJC021BA Air Conditioner
Will goodman outdoor ac work with bryant indoor unit
This is true as long as it is not a heat pump. Make sure they replace the piston (metering device to match the outdoor units required piston size. Or if the indoor coil is metered via TXV, it will automatically meter the refrigerant flow. If you are mismatching a system, make sure an acid test is performed on the old refrigerant and take appropriate measures with the new system if the test shows positive acid. They need to definitely install a liquid line drier.
Apr 12, 2013 | Bryant 462AJC021BA Air Conditioner
Bryant FA4ANF04200 Operation is intermittent. Some of the time it will go on when set to heat or cool. Other times, it will not turn on. Replaced thermostat. Problem continues. Sounds like defective...
Is this a heatpump system or a gas furnace /a/c system,you have a 3 1/2 ton a/c unit,if it is over 5 yrs old it could be a board problem,look for any spliced wiring where they used little wire nuts to join wires,these can make bad connections,?does the blower turn on,is the outside unit running but no airflow,if you have a gas furnace it may have a window,a little clear lens to look in at the furnace control board,it will blink a failure code if there is a problem,need more info :)
Mar 08, 2013 | Heating & Cooling
Why is my furnace filter dirty after 3 days
depends on what you are calling dirty which is relative to each person
Are they so dirty they are clogged or do they just have dust on them
IF they are just dusty then that is normal and it is being pulled from inside the house
If you have a pet door that will cause a lot of dust
The only other way is if there is a hole in the attic or your return air somewhere
Feb 26, 2013 | Bryant Gas Furnace Legacy-310AAV Plus 80...
Have a bryant 3.5 ton outside can I change to a bryant 4.0 ton and still use the same inside equipment
This is true as long as it is not a heat pump. Make sure they replace the piston (metering device to match the outdoor units required piston size. Or if the indoor coil is metered via TXV, it will automatically meter the refrigerant flow. If you are mismatching a system, make sure an acid test is performed on the old refrigerant and take appropriate measures with the new system if the test shows positive acid. They need to definitely install a liquid line drier. Hope this helps.
Jan 28, 2013 | Bryant 3.5 Ton R22 12 Seer Condenser Only/...
I have a Bryant Plus 90i furnace and a Bryant2.5 A/C
go mid.range....cfm dont go to hi spd or no cooling pick up
Aug 18, 2009 | Bryant Heating & Cooling
Bryant 561cj024-d cooling specification for 1452 square feet
Your bryant 56cj024-d is a 2 ton unit, which cools an even 1000 square feet of space. you need a 2 1/2 ton unit, which cools 1500 square feet.
Aug 05, 2009 | Heating & Cooling
Heating & Cooling Logo
60 people viewed this question
Top Bryant Heating & Cooling Experts
christian nielsen
Dan Webster
Dan Webster
Bill Long
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
