Question about Philips Magnavox DVD/VCR Dual Player
Would like to record from my tv to my magnavox dvd/vcr combo box
I have a magnavox ZV427MG9 dvd/vcr combo box. I do not have a cable or satellite box, but I do have a cable-in coax connection. How can I hook it up so that I can record from my tv set?
Ge a regular antenna hooked up first to the converter box then take
the cable and connect to the vcr/dvd then the tv you will need two
coax type wires
IF the dvd/vcr works like my vcr, make sure the unit is set to channel 4 or 3 whichever isn't a a real channel in your area. If you previously before the switch over, watched channel 4 news etc then set the switch in back to 3. The most common is 3, that's what they come out of the box set to. However, in my area in Arizona channel 4 is the unused channel. You shouldn't need a digital vcr/dvd receiver, just a good antenna, even with a bad antenna you should get something. Like I said to record with a vcr make sure the unit, with its remote is set to channel 3 or 4 it MUST match what the converter box is set to. OK, THEN you CHANGE channels ONLY with the Converter box remote ONLY. ONLY that remote, that the way it works for the VCR. Follow the directions about hooking up the antenna to the box first, then to the DVD combo THEN to the tv that's the last connection. NOT hard just sounds like it. next time I will post pics.
Posted on Jul 29, 2009
    Sergeant:
  • 227 Answers
If I understand your request right, You do not have cable or satellite box.
You can not record from your TV. You use the TV as a monitor from the dvd/vcr combo box. What the box receives is what shows on the TV. So you will have to have a digital convertor hooked to the (antenna in) dvd/vcr combo box, (antenna out to the tv antenna in) Depending on the antenna you are using that is on the other end of your cable-in coax connection this will hook to your antenna in on the digital convertor box. If your cable is hooked up and operating correctly and directly to the tv that is digital ready you probabbly have a good picture. When the vhf/uhf signal was transmitted you could go from the dvd/vcr to the tv with no problem. But now that the signal is digital and the tv is set for digital the dvd/vcr will not pass a digital signal to the tv. Best suggestion, you have to get a digital dvd/vcr receiver. If you have more question please contact me.
Mike
Posted on Jul 25, 2009
Why does neither the co-axial cable from my DVR Cable box nor the one from my TV fit into the coaxial plug on the Magnavox ZV427MG9 DVD Recorder/VCR Combo ?
Check the coaxial cable connector type. There are two kinds--one that look like the RCA connector that you can just push in.
The other kind has a nut that you have tighten over the coaxial cable connector on the DVD recorder.
Dec 05, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
How to use without remote
UPC 961613194763 053818570722
  • HDMI Output (rear), Remote control, Plays DVD Video, DVD_R/RW (VR format), DVD-R/RW (Video format), CD-R/RW, Audio CD, MP3)
  • MAGNAVOX ZV427MG9 DVD Recorder / VCR Combo LINE-IN RECORDING (NO TUNER)
  • 1080 Up-Conversion, Progressive Scan Video Out
  • Five Speed for up to 6-Hours Recording, Dolby Digital Stream Out
  • 2-Way Dubbing (VCR > DVD, DVD > VCR), Satellite Link Recording, S-Video Input / Output
  • Dec 02, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
    How to hook up a vcr/dvd player to a cable box
    Cable box RF output to Combo antenna input. Then use menu in combo to search for cable stations.
    Jan 26, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
    Vcr tape . does not record to dvd-r disc Using hdmi cable from TV to recorder.
    It is a HDMI OUT on the DVD/VCR Recorder.
    You can only record to a DVD/VCR from the External DVD/VCR Input (Connected to a Freeview, Cable or Satellite Box etc) or from one to the other.
    Jun 09, 2011 | Magnavox ZV427MG9 DVD Recorder VCR
    I have a Magnavox ZV427MG9 DVD Recorder VCR Combo. Do I need a separate tuner? If so what kind? Thanks
    Hello
    Ofcourse you need an external tuner to receive any RF signals. Your Magnavox is not equipped with internal tuner with it. OK.
    Apr 21, 2011 | Magnavox ZV427MG9 DVD Recorder VCR
    I have a Magnavox DVD Recorder/VCR ZV427MG9, but I don't have an instruction manual to go with it, at least on how to record from VHS to a DVD, could you tell me where, via internet I would be able to get...
    You can probably download the pdf of the manual for this model from the following site:
    http://tv.manualsonline.com/manuals/mfg/magnavox/zv427mg9.html
    The document should feature a picture of the unit. This is for the ZV427MG9 model ONLY.
    I hope this helps somewhat.
    Mar 15, 2011 | Philips DVDR90 DVD Recorder / VCR Combo
    Hook up of magnavox zv427mg9
    I have a magnavox dvd recorder/vcr combo (ZV427MG9A) connected to my Sharp hdtv via hdmi cord, Can anyone tell me simple setup steps to make it record and play on either sides. I have read instruction book over and over and it is still not recording to disc or tapes. I also have Charter Cable connected. Can you tell me what do i need to do to make it work. H-E-L-P!!!!
    Nov 17, 2009 | Philips Magnavox DVD+R/+RW Recorder/VCR
    Is there a remote control code for model zv427mg9?
    For my direct tv remote, 20675 worked for me :) magnavox zv427mg9 combo vcr, dvd
    Sep 27, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
    Philips Magnavox DVD/VCR Dual Player Logo
    724 people viewed this question
    Top Philips Televison & Video Experts
    matt martin
    matt martin
    Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
