Question about Kenmore Washing Machines
Where is the pump filter located on my kenmore 80 washer?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 56 Answers
On the inside or the back where the outlet enters the machine
Posted on May 10, 2017
F21 error on Kenmore washer
The F21 drain indicates a long drain. There are several reasons for the error. The most common causes are debris in the drain pump filter or excessive suds. If you aren't using HE detergent or if you use too much detergent, the excess suds may be the cause. First, remove the clothes from the washer. Try running the washer without adding more detergent.
To check the filter, you will need to unplug the washer. Next take off the bottom panel. Locate the drain pump and the adjacent filter. Have a bucket handy to catch the water from the pump. Open the filter and remove any foreign objects. Look into the pump and check for any objects that got past the filter. Remove anything that doesn't belong. See the cabinet and pump diagrams here: http://www.searspartsdirect.com/model-number/11049972602/0583/0153200.html to help you take apart the unit and locate the pump filter. Close up the filter and try running the washer (again no clothes and no detergent). If the error does not recur, you've solved the problem.
If the F21 error repeats, then the pump or the water pressure switch could be faulty. If water has been pumped out of the washer, then check/replace the switch. You should also check the wiring between the switch and the main control board.
I hope this helps.
Jul 26, 2016 | Kenmore Washing Machines
Kenmore 80 series washer leaking water from middle of bottom
Greeings,
if its coming from front middle..its most likely a water pump as thats where its located..
The best thing to do is remove the front off of the machine,,or raise up and lean over the washer and
look at pump...usually, they will have a sign of leaking...its easy to remove. it has two clips that hold the pump on..
Feb 01, 2011 | Kenmore Washing Machines
Where is the pump/filter located on my Kenmore Front Loader Washe
It is just behind the lower panel. Remove the 3 screws from the lower panel (the panel just below the door), the screws are on the lip on the bottom of the panel facing the front of the machine. Pull down and toward you to get the panel off. The filter and clean out are in the center. Unscrew the cap to remove and clean out, but have lots of towels ready, there will be water coming out.
Apr 20, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore 80 series. doesnt pump water out; wont spin
lid switch may be bad located on top housing at hinge side of lid if you know what youre doing you could jumper swith and see if it works unplug washer while electric contacts are exposed abd plug back in to test
Nov 17, 2009 | Kenmore 24902 Top Load Washer
Need to know procedure to clean Kenmore Series 80 filter
unbolt the agitator filters should be underneath let me know how you went
Nov 11, 2009 | Kenmore 24902 Top Load Washer
Kenmore 80 Series draining problem
Check the following before replacing the timer.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Jun 01, 2009 | Kenmore Washing Machines
Kenmore washer 80 series misses spin during wash.
You may need to replace the motor coupling between the pump and motor...
Apr 07, 2009 | Kenmore Washing Machines
Pump filter on kenmore 45986
The filter screen is located in the front just above the drawer. Pull out the drawer and look under the front edge of the machine you will see 3 small screws. removing these will allow you to remove the lower front cover and access the filter.
Apr 04, 2009 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
63 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
