Question about Sony Televison & Video
I would like to know how to shrink my Sony bravo tv screen on Firestick please
How to connect firestick to vizio smart tv e50x
Plug the fire TV stick into a HDMI port on the TV. Plug in power for firestick. Change the INPUT to that HDMI port Main firestick screen should appear after 10-20 seconds
Dec 31, 2017 | Vizio Televison & Video
How do I get an amazon fire stick to work on my Panasonic plasma tv model TH-37PX70BA
  1. Plug your Firestick into one of the HDMI ports on your TV. Plug the USB power cable into your Firestick and into the wall or a USB outlet on your TV (if there is one)
  2. Turn on your TV and set the INPUT device to the correct HDMI port. There should be a splash screen or setup screen on your TV at that point.
  3. Using your Firestick remote, navigate to network settings and scan for your WI-FI router, Then enter the Wi-Fi password for your router (the same one you use for your smart phone or laptop).
You should be able to fully use your Amazon Firestick, and if you have Amazon Prime, be able to access all prime and free offerings from Amazon.
Dec 28, 2017 | Panasonic Computers & Internet
How do i get the firestick on my tv screen..set on hdm1 or hdm2 or ? I don't know how to bring it up on the screen?
The TV remote has a button for that. Input Select or Source or SEL. However simply turning off anything except the firestick should make it work. I presume the firestick came with a remote. Simply turning it off and on from that should do it. Make sure you can see the firestick when you press the buttons.
Oct 21, 2017 | Televison & Video
Can you explain in simple terms that if I buy a fire stick with kodi, does that means it automatically streams various films and music from Amazon or Netflix foc. Does it needs to be jail broken
Why would you buy kodi installed FireStick when you can do it yourself in a few minutes? I mean, OK, you don't have any problem to spend some additional money in buying Kodi preinstalled Fire Stick but what if you get problems later? It is always better to know how to install Kodi on Firestick as it will help you in future too. How to Install Kodi on FireStick
Jul 03, 2017 | Televison & Video
There is no signal on my tv from my firestick
Make sure your firestick is plugged into an outlet. Make sure you change the input settings on your TV to access the firestick output.
May 06, 2017 | Televison & Video
I downloaded kodi on my FireStick but it won't install it, how can i fix it
Hey, there are couple of ways to download as well as installing Kodi on Firestick. I am not sure which method you used to download Kodi. I would suggest you download Kodi using ES File Explorer and then it will show install button as soon as download completes.
You can also check this guide - https://www.firesticktricks.com/install-kodi-on-fire-stick.html
If any further issues, please let me know.
Mar 06, 2017 | Televison & Video
I have a Sony tv that I have my new firestick attached to currently. But my xfinity x-1 box is plugged into my marantz system where my speakers are connected and controlled.
You should have an optical audio output jack on your tv that you can connect to your receiver to output audio through your speaker system.
Dec 26, 2015 | Sony Audio Players & Recorders
How do i find my TV's pairing code?
It's either in your TV settings or you could try some of the generic codes such as 0000 1234 9999
Aug 10, 2014 | Sony Bravo 7011Vi34 Core2Duo 2.2GHz 2GB...
Sony trinitron KV27V22
Solder any / bad connects horiz,vert and power supply then
try again....................T.
Please rate this solution.........................
Nov 15, 2007 | Sony KV-27V22 TV
Televison & Video Logo
32 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
