Question about Epson Office Equipment & Supplies
Epson 4020 not printing. It is not responding to the computer even after restarting both. Also, I have attempted the driver update, which appears to not be functioning either.
Also, when I attempt to view the printer series (right-mouse click ยป Epson WP 4020 Series) nothing happens afterwards. Lastly, when I try to get the driver update, it tells me, "To check for updates, make sure that the printer is turned on and that there are not outstanding print jobs. Before beginning, make sure that your computer is connected to the Net." Yep, check positive for that one... Attempting to print via Wi-Fi; however, I am absolutely clueless on how to accomplish that. Does anyone have any suggestions, please?
  • 12 Answers
SOURCE: hp 2700 series all in one printer scanning issues
Hi .
Let me first explain that the scanning softwareis seperately loaded into the computer which is called as Digital Imaging. Try the step below:
1. try scanning from scanners and cameras - 2 errors might pop up if it does not scan - an error occurred communiating with the scanning device / no HP device detected.
2. start - programs - locate for a software loaded called HP Solution Centre / HP Director.Open the software if loaed and try to scan from there. If its not loaded then insert th installation cd and click on Install more software - full.
3. In HP solution Centre / Director click setting - scan settings - scan to ..... setup - see that both the columns of front panel and available destination list should be having some icons into it (you can add and delete from any column as desired - but none should be empty)
Click the link below to ssist you with relevant troubleshooting -
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?rule=40990&lc=en&cc=us&dlc=en&product=420428&lang=en
If none of the above work then try uninstalling and re-installing the printer software all over again
Posted on Apr 13, 2008
SOURCE: Cannot print on shared printer
I had the same problem with HP 1018 printer, when I had two computers connected to a domain and had Windows XP SP3 on them and when I shared the printer on one of them - I could only print from the network if the user belonged to the Local Administrators group on the host/server computer. Once the network user is removed from Administrators - the print jobs are stuck in print queue. I used the "HP LaserJet Host Based Print Driver Package" that is on HP web site for HP laserjet 1018 printer.
Then I tried to use a different driver for that printer and was successful with driver for HP LaserJet 1020. After forcing that printer to use the 1020 drivers, the regular users were able to print to that printer.
Posted on Jan 28, 2009
RoryMRP
  • 111 Answers
SOURCE: Zebra printer 140Xi, firmware 16.4.1, Labelview software 8.0. Click print a label which works on another computer and zebra printer and nothing happens
Try and reflash it again.
Posted on Jul 10, 2009
  • 66 Answers
SOURCE: New Epson Stylus sx105 not communicating with computer
If you have meticulously followed the installation instructions for installing the printer (it does matter the order in which the installation steps re accomplished), then the problem may lie in how the printer is connected to the computer (serial/USB/bluetooth/wireless). If USB, try using a different USB cable (rare, but one of the wires within the cable itself may not have continuity). If you've ruled out the cable, you could try looking for an updated driver on the Epson website. That could be the problem also.
Posted on Aug 12, 2009
  • 161 Answers
SOURCE: HP PSC 1200 - Error blicking for Check Print Cartridges
replace ink.
Posted on Sep 26, 2009
Why won't my printer print more than 1 Page at a time?
Please go to your printer preferences and select page setup choose default setting and customize other page setup then click apply and restart your PC. If not done then follow the instruction.
1. uninstall your present printer driver.
2. Restart your pc.
3. Install your printer driver again.
4. Restart your pc.
Hope it will solve it.
Thanks
Apr 07, 2016 | Epson Stylus Photo R3000 Inkjet Printer
Will not respond when I send to print
You might have to uninstall the printer restart your computer then reinstall your printer
click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port
you might see a yellow question / exclamation ? ! mark or a red X this will mean you need to install a new driver for this device right click to update driver
select properties again you will have the similar options also you can troubleshoot the device
you might have many prints backed up ((make sure you have the printer turned off)) otherwise it might print another page
if you have multiple prints in the queue you will have to open a file that you are about to print click ok a page will open with a
display print queue tab you can see all prints right click on the ones you don't need select cancel
hope this helps
Jun 06, 2012 | HP Photosmart C3100 series
Unable to install Epson TM-U220B[U220 with UB-U02III usb interface] on Windows 7 AND XP!
Hi!
Are you using a third party USB adapter or a USB interface? On the self test page that you printed does it say USB connection or something that will say about USB? or does it say parallel or serial connection? try to check the dip switches setting if its configured properly. visit epsonexperts.com site for more info.
Dec 24, 2011 | Epson TM-U220 Matrix Printer
I am running Mac OS 10.5.8 connected to an Epson Stylus Photo R340. Recently I tried to use Print CD and repeatedly get an error telling me theCD Print Driver is not installed, I have tried to reinstall...
we have same mac os, delete the software that was been installed then go to LIBRARY then go to RECEIPTS then delete the epson names you have in that folder then empty the trash then restart your mac install the software again then click the update after you finish installing then after updating online finish reboot and use.
Aug 27, 2010 | Epson Computers & Internet
My Epson RX 620 will not print anything from the computer with Vista
Have you tried running a print test page? Have you gone to epson.com website to see if they have printer driver available for your printer...
www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=44341&infoType=Downloads -
Jun 16, 2009 | Epson Stylus Photo RX620 All-In-One InkJet...
Epson Stylus CX9400 Fax
From your Win Vista Computer;
1.) Try to uninstall ( epson scan ) in the Control Panel / Programs and Features ones it is removed.,
2.) Download TWAIN Driver and EPSON Scan Utility v3.20A > epson12384.exe
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=90753&prodoid=63070382&infoType=Downloads&platform=Windows
3.) Ones it is downloaded and installed to your computer., try to launch epson scan ( if same issue persist )
>> On the Device Manager (Vista) if the Epson Scanner is listed under "Other Devices" -- with a yellow " ! " < right click on it and click on update driver., make sure that the option selected is " Install the software automatically (Recommended) and then press next > ..... you may need to restart your computer after this procedure..
>> Then try to scan again
Note >> if a pop on your computer for ( New hardware Found ) just ignore it / close it., after the scanner driver is installed it will go away.....
Jan 31, 2009 | Epson Stylus CX9400 Photo Printer
Mac OS 10.5 Leopard
I had the same problem with an Epson R340 printer and Epson Print CD software after installing Leopard.  Here's what I did.  Go to System Preferences.  Select Print & Fax.  Select the "+" box on the lower left part of the screen.  Select Epson Printer  -- USB and click "Add" and "continue" in the box that comes up (if it does). Now see if Epson Print CD will print to a CD.  If it does, great.  You can now actually go back to System Preferences and Print & Fax and delete the printer you just added by clicking on the "-" box and Epson Print CD will still work.  Now I found another problem with printing. The CD printing is now off center to the right and down, so in Epson Print CD program you have to click on print and from the print screen click on "Position Adjustment" in the bottom left corner.  I've found the perfect position is 3.5 mm up and 3.5 mm left to make everything print perfectly.  Good luck.
Nov 08, 2007 | Epson Stylus Photo R340 InkJet Printer
46 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
