SOURCE: Printer R300
make sure you have the paper where it hits the part that sucks in the page to be printed (you can see the gray stucture by removing the paper and looking into where the paper is put) this might cause your papers, if you have a small amount, to bend to where the dip of the curve is facing the front of the printer. *Also the best way to prevent this is by having a LOT of paper where its fed (if the bending thing doesn't work.* Also the clicking noise is the sucking part not getting a piece of paper. This is because the paper not inserted correctly means that the pronter detects that paper is in the pronter but it can't get it.
SOURCE: saying paper jam dcp-135c brother printer
Hello there,If the paper is lodged too far into the printer and can't be removed: Press the power button to turn the printer off.
Pull firmly on the paper to remove it. If you can't reach the paper because it is too far in, raise the front cover and remove the paper from the front of the printer.
Close the front cover.
Press the power button to turn the printer back on.
Resend your document to print.
Ensure that:
The paper is a recommended paper for Laser printers.
You do not force the paper down into the printer when you load it. For example, if you are loading letter or A4 size paper, the top edge of the paper should extend above the top of the sheet feeder.
The printer is on a flat, level surface.
The left paper guide is against the side of the paper.
You do not load too much paper in the sheet feeder. Depending on the thickness of your paper, the sheet feeder can hold up to 100 sheets of paper.
The left paper guide does not cause the paper to bend in the sheet feeder.
Your printer feeds regular paper as expected. If regular paper feeds without causing problems, load the envelopes vertically against the right side of the sheet feeder. Make sure the paper guide is against the side of the envelopes.
Envelopes or the appropriate specialty papers are selected in the printer driver.
You are using a paper or envelope size supported by your printer.
do not forget to rate this solution....good luck
thanks for using FixYa
SOURCE: HP Officejet 5610xi All-in-One displays carriage jam
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab92
SOURCE: why is my hp photosmart 3110 printer making funny
your printer need servicing ask any local repairing center to service your printer or you able to do this do it your self
Thanks please keep updated. please do rate the solution positively .Thank you for using Fixya
Regards
Manish
SOURCE: Washer made a funny noise, stopped working. I shut
Here is a tip that will help you with the not spinning or agitating problems....
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
heatman101
