Question about Tablets & eReaders
If you're encountering the exact same error and typically aren't able aptoide app one as you will not wager the app in your default app store.
Why i have no ability to down load from google play store?
you need to download this Aptoide Android Apps Store
or find google play store fix apk. i used this three weeks ago and worked for me on 5 year old samsung phone.
Apr 21, 2016 | Tablets & eReaders
New Samsung nook using android. Was told I could get kindle app and add my kindle subscriptions to the nook
You can get the kindle app from aptoid, or google play, or you can try to get the app directly from Amazon apps. You may have to download those apps to access them. Hope this helps
Jun 09, 2015 | Samsung Tablets & eReaders
Need to download adobe flash player on tablet
download and install aptoide from aptoide.com
search adoble flash player and install it
Mar 01, 2015 | Tablets & eReaders
This tablet has 2 lots of memory,one called endeavour which has 4.83gb,and one called internal which has 142mb free.I want to update a few apps but it tells ,e I haven't got enough room! How can I upd
not exactly sure - but some tablets designate internal stg for the operating system and built-in apps and data such as address book or contacts, the settings app, etc. the endeavor stg may be the remaining available for your apps, data and media. Some updaters require extra working room to update an app - look in your settings and see if you set a default location for the apps and media you install. Another thing you can try is to delete the app and then reinstall it from the play store, the reinstall should grab the latest version. It also looks like you can add memory via SD card - probably a micro SD - 16gb is fairly inexpensive. Insert the card then mount it - look in your settings to see if you can set it as your default location or if it is offered as a choice when attempt to install an app. Some operating systems only allow media such as music, photos and videos to be stored on SD card memory - if possible, do a google search for your tablet model to find a manual.
Dec 10, 2014 | Tablets & eReaders
How can I play Simpsons tapped out it plays on another one I have
If you are referring to being able to download it from the Play Store then you might be out of luck. Each tablet reports its specifications to the Play Store and the Play Store will only show apps that your device is deemed able to run.
In this case you could try searching for and installing an apk file which is the installation file for the game and install it manually. There is a chance that these files downloaded from the Internet could carry a virus or other malware so beware. You also need to go into Settings/System/Security and check "Unknown sources" to install an apk. That's a safety step to try to stop you from installing malware.
The other option is to try a different app store - you could go into Google Play, install Aptoide and install the game from there (may or may not work).
Dec 04, 2014 | Irulu 7" 4gb Mid Google Android 2.3...
How to transfer files from pc to kurio 7
download aptoid store.
file manager app
move content to micro sd
copy to kurio.
Jan 08, 2013 | Techno Source Kurio Kids Tablet With...
Files from pc to kurio 7
download aptoid store true the browser and then file manager app. or tru an Micro SD card
No recent application
I get apps for mine from "Aptoide" and Appslib".
Updating the fimlware helps too, you can get it from the archos site.
Apr 27, 2012 | Archos 7 home tablet
How do i register so i can go to the android market
I don't think they recognise the archos 7 home tablet.
There's Aptoide and Appslib for getting apps.
Upgrade your filmware at archos as well.
Dec 28, 2011 | Archos 7 home tablet
Where can i buy an e-reader app for my archos 7 home tablet?
Try Aptoide and Appslib, you can get one free there, might have to test a few to get a good one.
Update your filmware also.
Aug 26, 2011 | Archos 7 home tablet
Tablets & eReaders Logo
47 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
