Question about Toshiba Computers & Internet
I would like to know why by battery on my new lap does not lasttoo much longer than 30 minutes. I would think that this is a very short time.
  • 30 Answers
HI there,
30 minutes is not long. I've got a few questions for you:
1. When you first booted up your computer, did you leave your battery connected for at least 24 hours? If not, please do so as these type of batteries tend to have a cell memory even though they say on the retail box that it does not.
2. Do you leave the power supply connected to your laptop more than 5 hours when you use it? If the battery is fully charged and still connected, the cells will stay active and end up dying faster than usual. When your battery is fully charged, do not connect your power supply to your computer.
3. What kind of programs do you run on your computer? The standard last time listed on the package is usually when using your computer for business type operations (Microsoft Office, etc.). If you use your computer for gaming, the battery will not last as long. If your alpha is also maxed out, your battery will not last long. The tip I have for this is to go in your User Control Panel and to go click on the Battery Icon. Select the recommended power usage and click apply. This will help keep your battery alive longer.
Hope this helps,
Regards
Posted on Jul 25, 2009
HP Lap top touch pad locked. How to correct please
By now you probably figured out you have to remove the power cord and battery to turn off the laptop. Let it cool down, 30 minutes or so, and then replace the battery and restart the laptop.
Feb 17, 2014 | Computers & Internet
HP lap top Charger light blinks six times?
if it's a new laptop it could indicate that the battery needs to charge for 30 minutes before use. if it's not a new laptop it could mean that the bios configuration is corrupt. if that's the case go to the hp support website and download the latest bios update and reflash your bios.
Jul 02, 2012 | HP EliteBook 8530p Notebook
Why does my phone loose battery power so quickly?
Android phones usually have a lot of junk running in the background. HTC is no exception. You can go into your settings, applications, and kill off some of the ones you don't want running. Some of them you can uninstall too. Check your other settings for the display to make sure it is shutting off after a short time. This should help some, but you should have longer battery life than a 1/2 hour. Look into a "new" battery or an extended battery. This is a longer life battery you can get on ebay or other sites. Make sure you get one that comes with a new back cover to fit over the larger battery. If none of this helps, you might have an issue with the phone & I would consider checking with your carrier for a replacement.
Feb 07, 2012 | HTC Hero Smartphone
I just bought a combo 18V Ryobi blower P2102 and trimmer P2002 which also came with a charger P113 and Ryobi lithium battery. I charged the 18V lithium P104 battery 48WH till light turned solid green on...
The battery will power your equipment for 30 to 45 minutes, that is normal. What you're thinking of is the lifespan of a lithium battery. It with your battery will last 10 times longer than a regular NiCad battery. So you will be able to charge the battery and use it Hundreds of times before the Battery Life is depleted. Sounds like it's working as designed
May 05, 2017 | Ryobi Two 18V Lithium-Ion Batteries +...
The hour/minute/second hands on my Timex Ironman not moving
It could have 2 batteries! 1.5 volt for analog and lithium for digital! Take it to a reputable watch repair business and let them check! :-)
Jan 09, 2010 | Timex Ironman Triathlon 50 Lap Digital...
Oven shows F2 fault several times a week. The oven is less than a year old and we keep it very clean.
F2 EO Shorted keypad/
key stuck
1. Disconnect power from oven for longer than 30 seconds.
2. Reapply power and observe for longer than 1 minute.
3. If failure remains, disconnect power, replace control, then go back to step 2.
F2 E1 Keytail unplugged 1. Verify that keypad is plugged into the connector on back of control.
2. Disconnect power from oven for longer than 30 seconds.
3. If failure remains, disconnect power, replace control, then go back to step 3.
Nov 19, 2009 | Whirlpool Ovens
How long to charge battery?
bateries have their own specifications.You can read it on the label.But,most of all it must be charge from 12-15 hrs. on its very first charging ( for a new battery) and later on or for the second time and so on, you may charge it 2 to 4 hrs.,sometimes 8 hrs..Leting you know,a battery can be charge even a short span of time,for example is 30 minutes only.In that 30 minutes try to measure its stored volt using a volt meter or a multi-tester,and the result is laready 12 volts (if your batery is 12 volts.)do you believe that? YES.! because a battery is so easy to store power.But,the problem is that its so easy to drain its stored power.You know why?because the current or amper of the baterry is still weak that the given specification.,.So,for short explanation,the longer time you charge your batery equals the longer time to drain the power.For example: when you charge the batery within 4 hours,thus the batery will be drained after 4 hours.
Oct 31, 2009 | Black & Decker 8 Inch 12 Volt Cordless...
What is the battery back up time for the Lenova R61 series lap to
The bottom of the creen shows a tak bar, unless of couse you have been fiddling with settings. It should show you the batterystate, I would sugest you wait until your battery is 100% fully chaged and time it. Cos I do not know as to how you use your mechine.
Feb 10, 2009 | Lenovo Thinkpad R61i Notebook PC
My Compaq Presario C500T lap top won't start
Generally speaking, an orange power light indicates problems with the power. You also described to a "T" how a bad battery behaves. To test this theory, take out the battery and plug in the laptop. It should power up and run. If so, it's time to invest in a new battery.
To be doubly sure, if you have anyone with the same laptop as yourself, plug in their battery to your laptop. It should work if their battery is good.
Thanks for using fixya.com. Please rate this tip accordingly if it provides the information you needed.
Jan 13, 2009 | HP Compaq Presario C500t Notebook
Computers & Internet Logo
43 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
