Question about Keurig Coffee Makers & Espresso Machines
What happens when the Keurig just pours out water even when it's turned off ?
3 Suggested Answers
  • 60 Answers
SOURCE: The Keurig is heating up the water, yet is does
Descale, Clean out the needles with an unfolded paper clip, Take out the K cup holder and clean it out
Posted on Mar 23, 2010
  • 40 Answers
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
Posted on Oct 07, 2010
Keurig won't brew, only 2 months old, not a descaling problem
If it's only 2 months old you should contact Keurig directly. They have awesome customer service and will probably replace your unit. I have read numerous postings that they will do it even if you did not register your machine.
http://www.keurig.com/contact-us
Dec 31, 2013 | Keurig Coffee Makers & Espresso Machines
Cannot prime
I have the same unit. You need to descale it. Get a bottle of white vinegar (not the small bottle, the next size up). Unplug your Keurig. Empty out the water receptacle and flip your unit over in the sink to remove any residual water in your unit (I even shake mine a little to loosen up whatever is stopping it from priming. Fill the water receptacle to the top with white vinegar. Plug in the Keurig and turn it on. Cycle the unit (lift the lever, close it, push the button) and fill a cup with heated vinegar. Pour the cup out and continue until all the vinegar is gone, then fill the receptacle and keep doing this (I do it until the receptacle has emptied itself at least 3 times). If your Keurig will not allow you to cycle through this then the problem is internal with the pump. Call Keurig. If you are in your warranty period they will replace.
Dec 10, 2013 | Keurig B60 Coffee Maker
Water runs continuously
shut off valve is dysfunctional or dirt is trapped inside the exit tube.
Feb 21, 2013 | Keurig B155 Small/Medium Office Brewer
I ran a cycle of vinegar through special edition brewer and it continues to say de-scale after doing scaling. it won't pour water sometimes and has to be turned on and off to get it to pour water. ...
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Jun 14, 2011 | Keurig Platinum B70 Coffee Maker
Does not fill a full cup when I select the large cup. Water is pouring back into reservoir through the overflow line. What causes this to happen.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Jun 01, 2011 | Keurig B60 Coffee Maker
My keurig coffee maker is flashing the words DE SCALE. What does that mean and how do I fix it?
"Scale" is deposits of minerals, etc. normally found in water. Boiling a container of water (in a pot, or coffee maker in this case), leaves small amounts or "deposits" of these minerals on and near the actual heat source. If not removed, they can slow brewing time and more importantly, adversely affect the taste of coffee.
Descaling should be done at regular intervals to prevent this from happening. Your machine lets you know when to perform the descaling task. There are a number of products sold in your supermarket that will do this for you - but one of the least expensive; and just as effective - is to use white vinegar. Here's how to do it:
1) Drain your Keurig coffee machine over a sink.
2) Fill the machine with undiluted white vinegar.
3) Run the brew process at least four times, pouring the cups of vinegar back into the coffee maker.
4) Optionally, let your Keurig coffee maker sit for a few hours, then run the brew cycles again. Pour the vinegar into the sink and drain any remaining vinegar.
5) Fill your coffee maker with fresh water. Run multiple brew cycles with fresh water each time to thoroughly rinse the machine before returning to normal use.
That's it!
I know this will help & good luck. Please rate my reply - thanks!
Feb 06, 2011 | Keurig Ultra B50 1-Cup Coffee Maker
Keurig B70 won't stop cycling water. it just keeps draining the resevoir. Water is cold, not heated.
heatman101
Feb 02, 2011 | Keurig B70 Coffee Maker
Water puoring back into tank
I contacted Keurig about this same problem. They said it was because I must have a sediment clog. I descaled it several times, as outlined in the manual, but it still didn't work. Even though I was a few months out of warranty, they still replaced it for me. Try the descaling. It may work for you.
Feb 14, 2008 | Keurig B50 Coffee Maker
Coffee Makers & Espresso Machines Logo
144 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
