Question about Filter Heating & Cooling
Where do I get the new carbon filter at
I have 2 filters on each unit I have 3 units two are a iap-10-200 with a large and small filter and the other unit is a iap-10-200 with 2 small filter where do I purchase ALL filters
    Top Expert:
  • Filter Master
  • 49,215 Answers
Google search for filters by make model and size ,Or check with a local company for the items you have .many filters can be purchased at home improvement stores
Posted on May 10, 2017
Do you have a user manual for an idylis air purifier model IAP-10-200?
Idylis IAP-10-280 C & D Filter Change for Part # IAF-H-200C ...
? 2:16
Apr 16, 2014 - Uploaded by Crucial Air Replacing your Idylis IAP-10-280 C & D ... As the air filter accumulates more debris over time, the air purifier's filtration capacity lessens. ... Lowe's Idylis 10,000 BTU A/C Instructions (Model: 0146709)
Sep 17, 2015 | Air Air Purifiers
What is the secret for resetting the IAP-10-100 machine after changing the filter?
Unit should filter air after hepa filter change/carbon filter clean/reinstall, but "change filter" indicator light will still be on. Insert a small diameter rod (bent paper clip) into "reset" hole (next to indicator) and push button, and indicator light will go off.
Note: Hepa filter can be vacuumed to extend life.
Jul 18, 2014 | Idylis Hepa Tabletop Air Purifier -...
How do I reset the change carbon indicator?
On the left side there is a small access panel. Remove it and instructions for cleaning the inlet and outlet sensors. With a damp qtip. This turns the dirty indicator out.
Jul 12, 2014 | Idylis 3-Speed 310 sq ft HEPA Air Purifier...
Just replaced filters
The unit times the filter hours. You have to reset the timer.
Jun 30, 2014 | Idylis 3-Speed 310 sq ft HEPA Air Purifier...
Why does the red dirty light keeps coming on? my unit is only 3 weeks old
If it's only 3wks old, return it for replacement. DO NOT attempt to repair
Jun 29, 2014 | Idylis 3-Speed 310 sq ft HEPA Air Purifier...
Where can i buy filters
Amcor was bought out, and no longer supports this product or provides replacement parts for it. The unit has two filters:
  • Washable air filter which collects large dust particles and prevents bacteria build-up
  • An activated carbon filter to help remove odor
There is no manufacturer of filters (carbon or air) for this product, however if it were in my possession I would remove the carbon filter and take it into my local Home Depot or Lowes ( or whatever you have in your neighborhood) and see if they have something that might fit that is similar. Many filters work in more than one brand. The air filter should be washable still, if it is damaged you can probably do the same thing I suggested with the carbon filter.
May 01, 2014 | Amcor AL10000E Air Conditioner
I want to change filters. please help
Hi and welcome to DixYa, I am Kelly
The only two parts requiring any service are the activated carbon pre-filter and the HEPA filter. No tools are needed. To change either filter, disassemble the unit as shown.
1. Loosen the carrying handle by turning it counterclockwise and lift filter cage cover from unit.
2. Lift HEPA filter and activated carbon pre-filter from the base.
3. Remove the fasteners from the activated carbon pre-filter and remove it from the HEPA filter cartridge.
4. Replace filter(s) as needed, and discard used filters.
5. Wrap the activated carbon pre-filter around the HEPA filter cartridge and secure it with the fasteners provided
Pictures are here:
Thanks for choosing FixYa,
May 25, 2011 | Honeywell Enviracaire 13520 Air Purifier
Where and how can I order new filters.
You never need to ORDER new filters for your SUN AIRE purifier unit. Our pre-filter is LIFETIME/WASHABLE 0.5 micron 2-stage electro-static and NEVER needs replacement. Our pre-filter saves you about $100-200 per year in expensive replacement HEPA/charcoal/carbon filters on other units. Made in America and built to last you a lifetime- SUN AIRE purifiers!
May 04, 2010 | Sun Aire Sun-Aire Air Purifier - Stainless...
Will not ignite after replacing air filters
Clearly a problem with the new filter.
Does it have a check valve built in?
Try to get a flow through it without the nozzle attatched - and often there is a small sintered filter attatched behind the nozzle anyway. take off nozzle and try priming (without igniting obviously).
Could be air in there so needs priming. Often heaters shut down if air is present - so need to be bled of air. If you can pre-fill the filter, or bleed air at a joint just after the filter - this usually works.
Please rate at Fixya if this solves the problem. - It is free, and I improve my score if you do.
Thank you.
Feb 04, 2009 | Reddy Heater-30-55,000 BTU Variable
Heating & Cooling Logo
Top Filter Heating & Cooling Experts
Are you a Filter Heating and Cooling Expert? Answer questions, earn points and help others
