Question about Siemens Computers & Internet
I have an old Siemens Lady Plus dishwasher and I need to change the drain hose. I can't find where the end of the drain hose is located within the machine. Please can someone help?
Siemens Lady Plus 256 SN25602EU/12
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 56 Answers
It goes normally from the back right through to the front and is connected there
Posted on May 10, 2017
Testimonial: "Thank you very much. That was really helpful."
Siemens lady 130 dishwasher overfilling at start of wash cycle
There is a float at the bottom of the washer. See if it is stuck. It should move up and down freely. This activates the water shutoff when it reaches the proper level. If it is sticking it could allow the washer to overfill . If that is not the problem then I would look at the valve it activates itself.
Dec 31, 2014 | Siemens Dishwashers
Replacing ram (1 x 512mb and 1 x 256) with 2 x 1gb. PC boots ok (slowly) then seems to freeze (nothing shown on taskbar) - desktop icons take ages to appear then seem to randomly refresh. The new ram is...
Try re-installing the two new sticks two or three times. Sometimes there is a little build up of oxides on the contacts on the motherboard and keeps the bios from properly recognizing them.
Sep 18, 2013 | Fujitsu Siemens SCENIC P300 PC Desktop
Water is not draining from the dishwasher.
Unplugthe power cord to your dishwasher. You can do this by manually removing thedishwasher from the wall and unplugging it, or you can flip the power switch toyour kitchen at the circuit breaker (although you will need light to drain thedishwasher hose). 2 Put on your gloves,and, using your screwdriver, unscrew the screws from the kick plate of yourdishwasher. The kick plate is the panel just below the door of your dishwasher.3 Place your bucket on the floor in front of the dishwasher. 4 Unhook the drainhose by pinching the ends of the clamp and sliding it down the hose. Remove theother end from the pump. There will be two hoses in your dishwasher. The drainhose is the one that leads from the pump to the underneath of your kitchensink. 5 Point the hose into your bucket to drain any debris. Twist and scrunchthe hose to help remove the waste. 6 Test the hose by running water through it,and then reattach your hose in the same manner in which you detached it fromyour dishwasher.
May 13, 2011 | Siemens 24 in. SE25A266 ExtraKlasse...
Possiedo una lavastoviglie siemens lady 530. ultimamente durante ii ciclo di lavaggio indicato con una spazzola fa saltare il contatore, indicando supero di potenza , più del 30 percento. e'...
Salve.
Il consumo cosi alto e' probabilmente il risultato di un malfunzionamento. Un corto circuito o una parte diffettosa puo infatti causare un assorbimento di gran lunga fuori dal normale. Problemi che possono risultare in ecessivo assorbimento sono:
Modulo elettronico diffettoso.
Pompa diffettosa.
Motore ventola diffettoso (se presente in questo modello).
Corto circuito (questo fa saltare subito il contatore sempre nella stessa parte del ciclo).
I suggerisco di telefonare al numero Siemens disponibile nel manuale d'uso riportando il problema.
Cordiali saluti.
Ginko.
Jan 08, 2011 | Siemens Washing Machines
My Siemens Hydrosensor dishwasher seems to go through the entire cycle but at the end mainly the top rack of dishes, sometimes the bottom rack is completely covered with a film of junk. It ends the...
It is obvious the drain or pump out is not working. There is a blockage in the outlet. Check the drain under the sink nby removing the hose and making sure the hole is not blocked. The pump in the dishwasher may be blocked. fixing this may not be within your field of expertise and a technician may be needed. Good luck
Jul 31, 2010 | Siemens 24 in. SE53200 Built-In Dishwasher
Siemens lady dishwasher is getting stuck on
I removed the dishwasher and put fill hose on mains pressure. (30 to 45psi or 2 to 3 bar). Working ok now. May be issue with water pressure switch ?
Mar 23, 2010 | Siemens 24 in. SL84A305UC Built-in...
Is the siemens lady 45 dishwasher still in production. i live in rented accommodation and an old lady 45 slimline dishwasher has been installed. i am concerned that it appears to be so old that it may be...
you can try siemens company which is the same company as bosch and thermador and gaggenau. go to thermador.com and callthem to find out how old your unit is . i think they use the serial # to show production date.
Mar 02, 2010 | Dishwashers
Aquastopper.
have a look at your other problem question, which seems to be the same. ;)
Jan 18, 2010 | Siemens Dishwashers
Computers & Internet Logo
97 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
