Question about Sewing Machines
Can you tell me when the 132K6 was made? I have a very old industrial one that does not even turn that I found on a junk heap and put lots of oil and such but did not work. It does say Singer.
  • Sewing Machines Master
  • 12,063 Answers
Unless the machine is rusted, liquid Tri-Flow Synthetic Lube and heat from a handheld hairdryer (or setting in the hot sun) will most likely loosen things.
Posted on May 10, 2017
  • Moyra Joyce
    Moyra Joyce May 10, 2017
    Thanks my husband has tried all sorts of things but I think it is just too badly damaged inside. Would like to know when it was made. Thanks
How much oil do I need to put into an industrial Ovelocker Brother EF4 B531?
All industrial machines have a sight glass to determine oil level. Most have two red lines--lower is lowest amount of oil to run. Upper is highest amount to run. Some machines show level of oil but some have a vertical rod. The end of the rod is the oil level. It will raise as you pour oil in.
Apr 17, 2015 | Brother Sewing Machines
How do I thread the singer 132k6 including the bobbin. is there a diagram i may see
Hope this sight will help if not you may have to contact the manufacturing company for owners manuaql
Jan 09, 2015 | Singer Sewing Machines
SINGER 132K6 sewing backwards only
Yes the wiring is backwards so the motor runs the opposite way.
May 18, 2013 | Sewing Machines
Operating manual for Singer Sewing Machine 132K6
- Go to: http://www.matparts.com/manuals.php
- Scroll down to the Newlong DD-5
- Download instructions/"View Manual"
- This is supposed to be the same (made in Japan) machine as the Singer 132K6
Aug 11, 2012 | Singer Sewing Machines
Industrial serger needs oil drained
That might be a good question for the manufacturer. They are still in business.
http://www.pegasusofamerica.com/index.html
Jul 20, 2012 | Sewing Machines
How long before changing oil for a Juki DDL5550N-7?
just add oil and clean junk off take up pump filter. no need to change oil there no combustion like a gas engine.
Feb 26, 2012 | Juki Sewing Machines
Can I use synthetic motor oil for a very old industrial sewing machine which has a oil tank
Probably but you have to be careful that the weight of the oil is appropriate - hopefully it says what weight oil to add. Adding oil that is too thin may cause leakage/dripping onto your projects. Adding oil that it too thick may cause the unit to run loudly and not get proper lube.
Also, some synthetic oils do not blend well with common oils and may form an emulsion (like mayo). If it is very old, using cheaper common oil won't hurt it. I would stick with the common oil unless you clean out the old oil from the tank.
Good luck and please rate me.
Mar 15, 2010 | Singer Sewing Machines
Singer 132K6 industrial machine
Make sure that the thread is under the tension spring then thread it throgh the hole in the spoolcase,push the spoolcase retainer over to hold it in then turn the balance wheel towards you to pick up the thread through the hole in the needle plate, pull both threads back and sew away. I can supply a manual for this machine if you want one.
Robert
Aug 25, 2008 | Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
