Question about The Kitchen Appliances - Others
Hi my breadmaker started making a grating sound while kneading the dough. when it makes this noise the paddle on the inside doesnt turn. please help.thanks. Issie
  • 25 Answers
SOURCE: West Bend breadmaker 41030 needs knead bar
try here maybe measure your part then maybe a sub will work if someone can send you the specs.
http://www.nelsonappliance.com/search_results.asp?txtsearchParamTxt=paddle&iLevel=1&txtsearchParamCat=ALL&txtsearchParamMan=ALL&txtsearchParamVen=ALL&txtsearchParamType=ALL&txtFromSearch=fromSearch
Posted on Jul 24, 2008
SOURCE: missing kneading blade for reagl breadmaker
My Regal breadmachine bit the dust, but I have the mixing paddle for model # k6761 if anyone needs it. Louise
Posted on Oct 30, 2008
SOURCE: makes a bad loose sound when mixing dough
My Breadmakers Hearth was making the same sound, so after taking it apart I found that it was only the Bread Pans "under paddle" that the machine reaches up and connects to to drive the Paddle. I wears loose and wobbles and starts to slip making that banging sound. You can either replace the Bread Pan or like I did INVERT the under paddle (requires removing the C-clamp washer) to extend the life of the Pan and use of the Hearth. Hope this helps you.
Posted on Jan 03, 2009
SOURCE: Breville BR1 breadmaker kneading blade replacement
Our BR1 has just expired (the seal on the pan died). I contacted Breville and they don't do spares any more for this machine. I had replaced the pan in 2004, and so we had a spare undamaged paddle. E-mail me on br1.5.lera@spamgourmet.com if you would like me to post it to you.
Posted on Jan 20, 2009
Testimonial: "Thank you for your reply and offer of the br1 paddle - I didnt get a message to my email address so I hadnt realised I had any replies. Thanks. "
SOURCE: Need a paddle for a Cookworks Breadmaker
Had the same problem. Phoned Argos' customer servies and have just bought one through them for £7.50 (incl p&p).
Hope that helps.
Posted on Aug 13, 2009
Kneading Paddle
All bread machines have a final "punch down" of the dough that lasts a few seconds before the final rise stage. When "punch down" is over that is when you can remove the dough ball, remove the paddle, set it aside and place the dough ball back in the pan. It usually helps to have your hands dusted with a little bit of flour.
Apr 21, 2013 | Morphy Richards Kitchen Appliances -...
How can I buy 1 spare swan SB1020 breadmaker kneading paddle (sb1020/02 ) online without phoning and how much are they?
Use your make + your model + your model number (omitting any dashes, slashes, or spaces) + the words KNEADING BLADE DOUGH PADDLE as your Internet search.
Example: For the Fredericks Home Bakery model KHB-178 enter your search as
FREDERICKS HOME BAKERY KHB178 KNEADING BLADE DOUGH PADDLE
Happy Hunting!
Note: Breadmakers model numbers are usually located on the backside or bottom of the unit, either on a printed decal or raised plastic embossment, and usually followed by abbreviations such as mdl, mdl no, model, model no, type, style, art, art no, article no, cat, cat no or catalog no.
Jun 22, 2011 | Kitchen Appliances - Others
I sent a 2lb digital breadmaker(black) to my daughter, SGT Katie Herndon at FOB Bostick in Afganistan. She has misplaced the kneading paddle so i need to get replacement. Katie only gave me the lot...
Unfortunately the lot number is not going to help you get the kneading paddle you desire.
Once you find it, use your make + your model + your model number (omitting any dashes, slashes, or spaces) + the words KNEADING BLADE DOUGH PADDLE as your Internet search. Google Search is better. Google Product Search is best.
Example: If you owned the Fredericks Home Bakery model KHB-178 you would enter your search as
Happy Hunting!
Jun 16, 2011 | Cook's Essentials Kitchen Appliances -...
While the machine is kneading it makes an awful grinding sound.It sounds like the paddle is not moving.If you lift the dough up the paddle moves freely.
It sounds like your belt is slipping. All bread machine operate off of an electric motor and drive belt and they do wear out.
Feb 16, 2011 | Toastmaster 1142 Bread Maker
I bought my Cuisinart Bread Maker in February 2007 and it worked well until now. Yesterday I started to make Dough cycle. First 2 minutes machine kneaded the dough correctly as usual but suddenly...
check the underside of the basket. I have had problems with the lock washer, causing the wing nut to slip and not providing any turn to the shaft and paddle.
Sep 22, 2010 | Cuisinart CBK-200 Bread Maker
Why did the kneading paddle on my 1148X bread machine quit working. This happened the third time it was used. It did the initial mixing and resting. When it started the kneading process again, the blade...
Hi, If this is the third time using it, it could be defective. Return it for service. If not under warranty, try a few things. 1) Make sure the pan is inserted in the machine correctly. 2) Make sure that the paddle is not sticking, or the sealed bearing on the bottom of the bread pan is not broken or frozen. (Take pan out and see if you can turn the paddle freely by hand). Or finally, the belt may be loose and slipping, especially when it takes more power to knead the dough the second time. Good luck...Hank
Jun 12, 2010 | Toastmaster 1148X FastBake Bread Maker
First time use. set machine to dough and pressed
Hi, Keep the bread pan out of the machine and start a kneading cycle. Look through the lid window and see if the motor shaft is turning. If no...then the belt fell off. If the motor spins, check to make sure the paddle spins freely. Keep pan out and turn paddle by hand. If no then the bearing is frozen. If that's ok..make sure you inserted the pan correctly into machine. If everything checks out then it's a faulty machine. Before you do anything send it out for warranty service. Usually it's warranted for a year. Hank
May 12, 2010 | Black & Decker B2250 Bread Machine
Our rarely-used Black and Decker B1650 bread maker has started making a really loud clunking noise when the paddle is kneading the dough ball It does not make the noise when not under load ... I ran the...
It could be the belt is slipping or a loose gear. Take a look at the gear & belt assembly in the base of the machine. Also, make sure the sealed bearing in the bottom of the bread pan is not sticking. It should turn free by hand Hank
Feb 16, 2010 | Kitchen Appliances - Others
Can the kneading paddle be removed before baking?
Yes you can remove the paddle before baking. The cuizinart has a buzzer that sounds when to take the paddle out
If you want to take the paddle out you should make sure your machine has a pause feature so you don't lose any rising time.
Take pan out of machine, empty dough into a bowl, remove paddle, squirt the shaft in the bread pan lightly with veg oil (prevents sticking) then return the dough after final kneading time and before final rise.
Hank
Aug 26, 2009 | Kitchen Appliances - Others
Kneading paddle having problem kneading
Sounds like you might need a new belt. If it works ok with nothing in it but wont when the dough is in there
Feb 13, 2009 | Breadman TR875 Bread Maker
Kitchen Appliances - Others Logo
27 people viewed this question
Top Kitchen Appliances - Others Experts
Brenda Landram-Pope
Bilral
Level 1 Expert
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
