Back to:
Tags:
IBM ATI RADEON 9200 Pro 64MB Video Card Graphic Card
Freezing
posted by dh456 on Nov 21, 2007
Virtually any game I try to play freezes/unfreezes every couple of seconds when any real action starts during the game(and sometimes without any real action going on). And while surfing the web it takes several minutes to load a page, even though I have sympatico high speed running at 100.0 Mbps.
My video card is a Radeon 9250 - 128AGP, and my processor is an Intel Celeron 1700 PM8M-V. Mainboard is a MicroStar International (ms-7104).
And 768 MB of DDR - SDRAM - PC2100 @ 133MHz
I don't have a lot of money, so is there anything I can do to make things a little better without having to buy any new components? And if there is no way, what would be the least expensive upgrade I would have to make in order to play games like: Age of Empires 3, Pacific Fighters, Stonghold Legends, Star Trek Legacy, and Glory of the Roman Empire?
P.S. My pc freezes even while play games as old as Age of Empires 2.
Thanks.
D.H.
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Nov 26, 2007
Not Rated (0)
Megahurts
Rank:Apprentice Apprentice
Rating: 85%, 2 votes
Spec's look decent but many things can cause this problem, a lot of them fall under 'settings' and 'drivers'. Making sure ALL BIOS settings are set correctly is foremost. Clear the ESCD in BIOS after any hardware change. Make sure frequency and timing settings don't cause excessive wait-states for BUS x-fers. After BIOS is checked, ensure MoBo 'chipset' drivers are installed - full AGP functionality may not be possible without them even though Windows installs 'generic' drivers. All hardware mfg. drivers should be installed and settings checked. Make sure not infected with badware. Disconnect any hardware not needed for gaming, or disable drivers like multimedia enhanced keyboards and any system processes or background tasks that are not essential so there are less things causing IRQ requests.
Make sure DMA is enabled for HDD and CDROM's if supported by them. Error-scan, defrag and check S.M.A.R.T. status of HDD's. Use a sys info tool like 'Everest' or 'PC Wizard' to check if settings in BIOS and OS are allowing full hardware functionality.
Some hardware (and software) just don't play well with certain others lol, so if all that fails, borrow another video card with similar features and see if it works better before spending money on a new one. Check if your MoBo chipset has known issues with any of the different graphics chip mfg's.
Good luck and hope it turns out to be something simple ;)
R.M.T.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on freezing:
I don't want to Accept this solution
Can you Help with these Graphics Cards problems?
Graphics Cards
HI, I have a intel DG31PR mainboard, 2.2ghz core2duo, 2gig...
Graphics Cards
Is there a way to make a Matrox Millenium G450 Dual Head...
Graphics Cards
the unit of my lop top is dyna satellite...plz. help me...
Graphics Cards
Hello, I need to get my tv tuner working on vista home...
Graphics Cards
hi I installed a GeForce6200 256Mb(64bit) AGP on a compaq...
Loading problems.
Repair Service
Find Graphics Card Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
