Question about Lands Phones
Where is ringer switch on model 29265 Trimline phone
4 Suggested Answers
SOURCE: model 29265 trimline phone handset falls from cradle
push the handset hook up and out with your thumb,turn it 180 degrees,and replace it in the slot on the base. Bridrijo D. Howell,Bermuda
Posted on Mar 14, 2009
SOURCE: GE Model 29265 Trimline Memory Phone
I just purchased the Trimline Model 29265 phone and in the instructions it says that it can be wall mounted if you reverse the handset hook in the base? Where is the handset hook and how do you reverse it. Nothing in the instructions tells you where it is nor how to fix it.
Posted on May 07, 2009
consultel1
  • 860 Answers
SOURCE: Caller ID in another language can't find manual to
1. Press the option button. SET 5 OR 6 appears in the display.
2. Press the 5 (+) button until CID LANGUAGE appears in the display.
3. Press the option button to show the current language setting. The default is English.
4. Press the 5 (+) or 6 (-) button to change the language.
5. Press the option button to store the language and return to the CID LANGUAGE display.
also here's a link for the manual:
http://www.home-electronics.net/USER-GUIDES/29265_DOM_ES_CD_IB.pdf
Posted on Nov 08, 2009
Testimonial: "Thanks again this is what I* needed!"
How do I turn off the ringer on my Panasonic Telephone base?
It would help if you add a comment with the model number of your phone. For the KX-TG6572R, to set the ringer to off on the base, press and hold the Down button on the base until the phone beeps when the phone is in standby mode. Note: if the phone has an intercom mode, the ringer for the intercom is never silenced.
I hope this helps. If this procedure doesn't work for your phone, please add a comment with your phone's model number. Then, I will try to find additional information about the ringer volume control for you. (I know some phones have a physical switch on the base for the ringer volume.)
Jul 08, 2015 | Panasonic Lands Phones
Phone ringer off
It a little bit older cordless phone, I CAN'T find the model number, there's a menu/elect button on the face but I can't turn the ringer off. The base has a ringer that I turned off but the phone still rings. There are no switches on the phone or base for turning it off.
Nov 14, 2013 | Northwestern Bell 36028-2 2.4 GHz Twin...
Is their anyway I can increase the volume of the incoming call? Thank you! Jen
Hi
have you had a look on the back of the handset for the handset volume adjustment? You should see it there along with the ringer option. I have pasted a section from the manual that may help you.
1u5qierku+aaaaaelftksuqmcc
ikku6kufkpaaaaaelftksuqmcc
Hope this helps you.
Jun 13, 2011 | Curtis Trimline TID582 Corded Phone
Clarity C210 single line trimline phone - ho do
you can change it on the settings... goodluck...
Jun 06, 2010 | Clarity C210 Corded Phone
Ringer Switched off
http://www.uniden.com.au/RESOURCES_MAIN/pdfs/WDSS5335_1_OM.pdf
Click on the above for your manual , you had a problem with the ringer, if you go to P35 that is the start of the ringer.
Hope it helps!
Jan 05, 2010 | Uniden Cordless Phone
Lost manual
Without the exact model it is difficult to find the manual.
Here the manual for 900 series/996:Uniden EZI996.
I also quote from manual:
Selecting the Ringer Tone and Volume
Base ringer on/off
The ringer switch allows you to set the base ringer on or
off. If you set the switch to off, you never hear the base
ringer tone.
Base ringer tone
Press the ringer tone button in standby mode to select one of 7 ringer tones.
Base ringer volume
Slide the ringer volume adjuster to set the base ringer volume.
Handset ringer tone and volume
Press the volume up key or volume down key (labeled as the volume/ /+ or volume/ /- key) in standby mode to select one of five ringer tones and volume combinations
Apr 17, 2009 | Uniden Cordless Phone
Model 29265 trimline phone handset falls from cradle
Dec 27, 2008 | Thomson 26943GE1 Cordless Expansion...
Mar 19, 2008 | Thomson 26943GE1 Cordless Expansion...
Ge phone
its on the right hand side of the base, its a very small, half-circular sliding switch. The switch has three positions 0, 1, and 2, slide it to 0 in order to turn the ringer off.
Nov 04, 2007 | GE 29273GE2 Phone
Unable to dial out, check voice mail and see call display
Hi at the back of the phone you will see a selectable Hi/Lo/Off switch. Slide the (Ringer) switch to High position or Low position to turn the ringer on. Hi for high volume Lo for low volume.
To prevent hearing any ringing of incoming calls slide the (ringer) switch to the off position but when you ready to accept incoming calls again remember to slide the switch back to either Hi or Low setting. Hope this made sense and helped.
Oct 24, 2007 | Curtis Trimline TID582 Corded Phone
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
