Question about Canon Office Equipment & Supplies
How to check the ink level on canon MX366 - Canon Office Equipment & Supplies
3 Suggested Answers
MUKHTAR
  • 2022 Answers
SOURCE: CHECKING THE INK LEVELS
just remove all the cartridges and you can see the level of ink .or you can go to printer service and maintenance option there also it show but that will not actual . So just remove and see the level..
Have a nice day and do not forget to rate please...!
Posted on Feb 06, 2010
Pixma 2200 series all in one
Don't use refill kits, they are no good in quality printers. Also the cartridges in the newer models have a chip in them that knows when the cartridge is empty. When it becomes empty, the chip has to be reset, and this is what those mall cartridge fillers do.
E, 1, 3 The ink may have run out. The function for detecting the remaining ink level will be disabled since the ink level cannot be correctly detected. If you want to continue printing without this function, press the machine's Stop (Reset) button for at least 5 seconds. Canon recommends to use new genuine Canon cartridges in order to obtain optimum qualities. Please be advised that Canon shall not be liable for any malfunction or trouble caused by continuation of printing under the ink out condition. Checking the Ink Status Checking the Ink Status with the Ink Lamps on the Operation Panel The ink level detector is mounted on the machine to detect the remaining ink level. The machine considers as ink is full when a new FINE cartridge is installed, and then starts to detect a remaining ink level. If you install a used FINE cartridge, the indicated ink level of it may not be correct. In such case, refer to the ink level information only as a guide. When remaining ink cautions or errors occur, the error code will be displayed on the LED (Light Emitting Diode) to inform you of the error. Check the error code and take appropriate action. -> [ An Error Code Is Displayed on the LED ] See[Checking the Ink Status ]
Oct 27, 2015 | Canon PIXMA Office Equipment & Supplies
Printer canon mx 366 saya. error 5B00. tidak bisa berpungsi ketika di hidupkan muncul error 5B00. sudah dilakukan reset manual tapi tak ada hasi. masuk ke menu tidak bisa. mhn petujuk untuk masalah ini....
I have best solution for reset error 5b00 Canon MX366 about waste ink absorber full :
1. Fisrt step : entering service mode, using this method (dont use other method!) press & hold "stop" button and than press "power" button, release "stop" button and still hold "power" button and than press "stop" button about 5 times ( 1, 2, 3 , 4, 5) and release "power" & "Stop" button.
2. Printer will be entering to Service Mode with indicators " Printer LCD to become full drak and CPU detecting new hardware (dont do anything).
3. Download Servicetool V 1074 for Canon IP2770, download and entering to this Sofware.
4. prepare paper on the printer and Clik "MAIN" on the Menu Servicetool V1074, if success canon MX366 printing "D=000.0
5. turn off Canon MX366 and remove power cord, wait about 60 second, reinsert power cord and turn on your printer,....... o la la la your printer was normal,..... ( ngono ae kok mumet)
6. if you have any qustion, send your email to : alfa_centrino@yahoo.co.id, thanks God bless U
May 15, 2012 | Office Equipment & Supplies
Pixma mx366 check ink u053
By Holding Stop, for about 10 second. The problem is solved.
Sepeda motor injeksi irit harga terbaik cuma Honda
Apr 26, 2012 | Canon PIXMA MX310 All-In-One Printer
Resetter canon mx366
reinstal reseat cables flush out virus check psu go for check points onmother board to book ideas repare
Feb 16, 2012 | Canon Pixma MX360 Printer
Mx366 waste tank is almost full
When my xerox says that I order a new waste tank and when it quits working install it. It sounds like you missed the replacement part.
May 17, 2017 | Canon Office Equipment & Supplies
I can't restart the canon MX366
My canon mx366 cannot import a scanned file...... whenever i scan i always get a dialog box saying "error in importing the file. and i have to choose between try again, skip the file or skip all error importing file" can somebody help me to fix it...
Oct 22, 2011 | Canon Pixma MX360 Printer
My pixma mx366 magenta color cant print
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels. If the levels are low then the cartridges must be changed.Use only the recommended type.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts.
Thank you for using FIxya
Sep 09, 2011 | Canon Pixma MX360 Printer
Hi, How do i check ink levels of canon pixma mp780? How to know when to change cartridges ? thanks in advance. Amit Bhatt Voguemagnet.com
Your Canon MP780 will have the ink levels displayed on the screen.
Also, while printing on the Canon printers you would usually get a window on the screen showing you the level of ink in the printer.
And here is a link on how to replace the ink cartridges on your printer http://support-au.canon.com.au/contents/AU/EN/8000117601.html
Dec 16, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Feb 06, 2010 | Canon BubbleJet i9950 InkJet Photo Printer
23 people viewed this question
old marine
old marine
