Question about The Office Equipment & Supplies
How to check ink level on the fax device? - The Office Equipment & Supplies
2 Suggested Answers
jackboy
  • 2985 Answers
SOURCE: Brother 5440cn print ink level device will not show on pc
nice to know what your ink levels are isn't it But these gadgets no matter which make of printer are software glitches that do a compute on the numbers pages printed its not like a fuel gauge in you car with a float in the tank. So don't worry too much about it.
Posted on Sep 11, 2007
Printer not detecting ink cartridge
Clean contacts, check level. Is it OEM or a refill cartridge???
Oct 10, 2013 | Brother MFC-J825DW Wireless All-in-One...
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Nov 20, 2012 | Canon PIXMA MX340 Wireless Office...
Check ink cartridge level
Click Start and then go to Printers and Faxes (XP), Printers(Vista), Devices and Printers(Win 7)
1. Right Click on your printer Icon 2. Go to Printing Preferences 3. Click the Features Tab 4. At the bottom of the window you will see Printer Services or Device Services. Click on it. 5. Choose Estimated Ink Levels
Feb 07, 2011 | HEWLETT-PACKARD Office Equipment &...
Error ##331 of cannon fax B120
the error code ##331, means that the ink level can not be detected it can be a problem of ink level detector; you need to resave your ink level. to resave the ink level: look at this link: http://www.fixya.com/support/r6643185-waste_ink_tank_full_fax_b120_b140_b820 if you need a clarification you have to add a comment to this solution.
Dec 30, 2010 | Canon FAX-B840 Plain Paper Bubblejet
Checking ink levels on my printer
  1. Make sure that the product is turned on and connected to the computer.
  2. Click Start and click Control Panel .
  3. Double-click the Printer and Faxes folder.
  4. Right-click the icon for the product and click Preferences .
  5. Click the Services tab, and then click Service this Device .
  6. The printer Toolbox opens. Click the Estimated Ink Level tab. A graphic showing the estimated ink levels appears. The graphic shows both the color and black ink cartridge with the ink level indicated by the fill inside the cartridge diagram.
Apr 04, 2010 | HP Office Equipment & Supplies
When we do a fax test, we get clear print; when we try to print documents nothing appears, altho it goes thru all the right sound motions
Sounds like your colour cartridge is empty. Fax test will pull from black only but documents sometimes use a combination of colours in order to print out black. I suggest checking your ink levels - instructions for windows;
Check ink levels
NOTE: If you have installed a refilled or remanufactured print cartridge, or a cartridge that has been used in another printer, the ink level indicator will be inaccurate or unavailable.
  1. Open the Printer Toolbox . There are two ways to do this:
    • Open HP Director , select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
    • Open Printers and Faxes in the Windows Control Panel , then right-click your printer icon and choose Properties . Click Printing Preferences . Click the Services tab, then the Service This Device icon.
  2. The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge may be running out of ink even if the graphic shows ink remaining (see the note at the start of this section). Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low Check ink levels
Mar 05, 2010 | HP Officejet 5610 All-In-One InkJet...
My fax won't print, neither faxes nor copies. The paper goes through & it makes sounds like it is printing but nothing on the paper. The machine says the ink level is 6/8. I "aligned" and...
Though the ink level it said was "6 / 8", when I removed the cartridge to examine it looked bone dry empty to me. I replaced the ink cartridge. It works fine, and reports the ink level as "8 / 8".
Sep 09, 2009 | HP 1040 Plain Paper Inkjet Fax
Hp office jet 4215xi how to check ink level
HI
you may get the ink levels in several ways,
1) printing a test page.
2)if you got HP solution Center with the software cd of the printer ans it is installed in the computer,you can easily check the ink levels there.
3)sometimes ink levels option is available in the priner drivers in the printers and faxes in the control panel.
4)right clik the printer icon and then goto properties and then you will find tabs to check the ink levels,it might be in the service this device under the maintenance tab.
Feel free to contact me if there's any query.
Aug 03, 2009 | HP OfficeJet 4215 All-In-One InkJet...
How do you check ink levels
Introduction This describes how to check the estimated ink level in the cartridge. NOTE: Ink level warnings and indicators provide estimates for planning purposes only. When an indicator shows low ink levels, keep a replacement ink cartridge available to avoid possible printing delays. Ink cartridges do not need to be replaced until print quality becomes unacceptable. Checking ink levels Perform the following steps to check the estimated ink levels: NOTE: If you have installed a refilled or remanufactured print cartridge, or a cartridge that has been used in another printer, the ink level indicator will be inaccurate or unavailable.
    • Click Start and select HP Solution Center . Select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
    • In your printing application, click File , click Print , and click Properties . Click the Services tab, then the Service This Device icon.
  2. The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge may be running out of ink even if the graphic shows ink remaining (see the note at the start of this section). Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink. Figure 1: Estimated ink levels
Nov 23, 2008 | Office Equipment & Supplies
ERROR ##331
The level of ink cartridge , can not be detected Solution :
  1. resave the detection level Ink by entering the service mode
  2. replace the ink detector
Jan 11, 2008 | Canon FAX-B840 Plain Paper Bubblejet
Top The Office Equipment & Supplies Experts
thetraveler
Level 1 Expert
Folusho Adeyanju
Folusho Adeyanju
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
