Question about DeLonghi EAM3400 Espresso Machine
Water ends up in the tray
When attempting to make a coffee, the machine goes through the routine as it should, however the water is diverted to the tray instead of through the infuser. When trying to steam I get a small amount of steam.I stripped the machine down and cleand the infuser and the water pump solenoid. I also pulled out the drain piping where the water enters the tray. I suspect water is being diverted because a either solenoid or valve is not functioning correctly, or the PCB that drives it is faulty.
Can anyone help.....???????..... I really need a coffee !!
    President:
  • 1,618 Answers
Have you checked the brew group screen? I am assuming that this is a super automatic machine, and by pressing a button it grinds and brews? If yes then the only other problem would be in the brew unit.
Posted on Jul 27, 2009
Water goes to drip tray
See if you can edit make and model into your question, you'll never get a proper answer without that info.
Sep 20, 2015 | Coffee Makers & Espresso Machines
Not enough water running when making coffe
is the water ending up in the tray?
Jan 21, 2013 | Nespresso Le Cube
Water goes into bottom tray
One possible problem is to try to clean the group shower which it can be ansrew by one center screw and if you can you can open the machine and remove to clean also the coffee group solenoid valve. Both the valve and shower can be full of dry coffee that can blocked the way of water coming to the grounded coffee.
One other posibble problem is the vibrating water pump. It might be full of scale and it can not create any pressure or it is completetly damage and need to be replaced.
First we sugest to perform a descaling of the machine and try again.
Second you should try to reduce by little the quantity of the grounded coffee used. Aprox you should use 7 to7.5 gr of coffee. If you try to use about 6 to 6.5 and you have the coffee runing out from the machine like in 25 sec you have about 30 cc of water.
If you manage to clean everything above and the machine work ok so from now on in order to avoid the problem again try to flush water from the group many times without any coffee. With this is like you wash the group shower and valve from any remai coffee.
Good luck
May 16, 2010 | Krups XP2070 10 cup Coffee Maker/15 bar...
Water not coming out of dispensing area, goes to drip tray instead Water comming out in drip tray instead of regular way
Try this, if the machine has a pregrind door(usually on the top front) then use the button to tell it you are using pre grind coffee, if water comes out the spout this way then the grind on the grinder is too fine, if it goes out the drain then the coffee passage is blocked, remove the brew unit and check/clear tubes, also clean the spouts on the door of the unit.
May 30, 2009 | DeLonghi Esclusivo Magnifica ESAM3300...
Water problem with Saeco Incanto Rondo sClass
Check the nozzle at the end of the steam wand it might be blocked.
Apr 25, 2009 | Saeco Incanto Rondo Fully Automatic Coffee...
We have an Saeco Incanto Rondo sClass. When brew coffee, only about half of the water goes through the brew group and the rest goes into the drip tray. When we try to run steam or water through the wand,...
My SAECO coffee machine is a real disappiontment. We frothed the milk a few times and then the machine started to only warm the milk and provide a small amount of froth. Now the company is trying to tell me it's something I am doing! Not so. It is the expensive machine not working.
Saeco Talea Giro no steam or water from spout
I have the same problem as well, talked to a repair shop and it's definitely a "send in" or warranty repair. I was told it's an o-ring issue. I have no water coming out of the steam wand and it goes into the dispense tray instead.
Apr 11, 2009 | Saeco Talea Giro Espresso Machine
Estro magic delux (now saeco i think) water leaks below brew unit
There is a small metal plate with holes below the square funnel shape on the brew unit. This plate has a pink rubber seal and a stem that goes up into the brew unit. The stem is knurled with ridges and is attached to a screw on the plate. The screw has become loose and the plate is not held tight against the seal. Turn the knurled knob clockwise until it tightes the plate against the bottom of the unit. Make sure the plate is centered as I believe there is a slight lip that it recesses into. Should stop the water in the grounds collector. Of course the seal must be in good condition. Paul
Feb 02, 2009 | Saeco Magic De Luxe Espresso Machine
No coffee, water going to the drip tray
OK, so this is a problem with your brew unit. The unit is not cycling correctly to tell the water to come through.
We had another problem like this just this week.
The wat we fixed it was 1) Give the Brew Unit a really good clean. 2)Make sure the Brew Unit can complete a cycle - manually rotate the brew unit components through a cycle 3) Lubricate the Brew Units moving parts if necessary using some Saeco or Other Food Grade Lubricant
Then try watch a complete coffee cycle by leaving the side door of your machine open, and tricking the micro switches into thinking the door is closed by engaging them with some card or something similar.
Let us know if this does not resolve your issue.
Paul from Coffee Shrine
Saeco Coffee Machines
Aug 20, 2008 | Saeco Royal Professional Espresso Machine
Hi, we have aa Saecco Cafe Grande an automatic Espresso Coffee machine. We purchased over 1 year ago from Future Shop. The machine only recentlly started to leak from the bottom, I did some...
Possible areas are the steam valve leaking or the boiler valve housing is leaking. I suggest Contact Saeco USA Inc. to located a Service Center near you at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Apr 05, 2008 | Saeco Vienna SuperAutomatica Coffee...
Open Questions:
See all DeLonghi EAM3400 Espresso Machine Questions
DeLonghi EAM3400 Espresso Machine Logo
266 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
