Question about Retail Supplies
Can one print an extra cash slip afterwards (2nd one)
How do i program extra sales receipt?
How do you mean? like a stub slip or an external. Please provide the model or a photo will do.
Apr 05, 2015 | Retail Supplies
Generic code p0700
Go to . sign up or register for free and you'll have access to forums, techs etc and may have better luck there with all the experienced mopar/dodge/chyrsler owners and mechanics on that site.
Apr 08, 2014 | 2004 Dodge Intrepid
How to prints two receipts on a casio pcr-t500 cash register
Hi. Yes, it needs the setting for extra receipts turned on in advanced programming.
It is called "Allow to issue post receipt even when original one has been issued". Find that in your manual and there is an example showing how to program these settings.
If you have lost the manual, one of the users has a PCRT500 programming manual here:
Apr 05, 2014 | Casio Cash Register
Sharp era420 not printing on left side
If its feeding paper but not printing, make sure that you are using the correct thermal paper and that there is no extra bits of paper stuck under the printing head. Otherwise it might need a replacement printing head. If its not feeding the paper at all, then make sure that the receipt is turned on.
Mar 18, 2014 | Sharp Retail Supplies
Casio qt 2100 programming I/O for epson tm-t88III
I haven't worked on the 2100 for years but I know you can't use a TMT88 series as a slip printer. The TMT88 is for receipts or kitchen. If you want to print special slips, you would need to get a dot matrix slip printer. This model is compatible with the SA-3015 and SP-1300 Slip printers.
Feb 21, 2013 | Casio Parts Cash Register PC Desktop
Error light blinking Citizen -S300 printer
  • High-speed (200 mm/s) printing
  • Longer cutter life (2 million cuts) delivers lower maintenance costs
  • Greater reliability delivers longer life & lower maintenance costs
  • Wider paper width allows printing of additional information & larger fonts
  • Interchangeable interfaces
  • 2D barcode (QR-code and PDF417) support allows wider applications
  • Built in buzzer provides audible alert without adding extra cost devices
  • Built in power supply eliminates unsightly "brick" and frees up space
  • Cash drawer kick-out external device port supports 2 cash drawers
  • 2-color printing supported (when specified paper uused)
Aug 16, 2011 | Citizen CT-S300 Printer
Hello I bought the Texas Instruments BA 2 plus,how to change 2 fin mode?there is no mode button.
The calculator has different worksheets.
To access TVM worksheet, press [2nd] and any TVM key : N, I/Y, PV, PMT or FV
To enter Amortization worksheet, press [2nd][AMORT]
To access Cash Flow (problem with unequal cash flows) Press CF, or NPV, or CPT or IRR
To access BOND worksheets press [2nd][BND]
For depreciation worksheets press [2nd][DPR]
For statistics, use [2nd][DATA], or [2nd][STAT].
There are other worksheets [2nd][Delta%], [2nd][DATE], [2nd][PROFIT], [2nd][BRKEVN],[2nd][MEMory].
These shortcuts will not get you anywhere if you do not consult the manual.
Jun 19, 2011 | Texas Instruments BA-II Plus Calculator
Netbook memory upgradablity
The motherboard in this Netbook only supports upto 1GB per slot and as there is only one slot it means the maximum amount of RAM it can accept is 1GB. In short the answer is no.
To check for official specs visit this page.
This is to ensure that you do not spend extra cash on RAM only to find it not working afterward. Hope I saved your cash.
May 30, 2010 | Computers & Internet
Slip appears on readout and till does not operate
It sounds like it might be trying to print to a slip printer (check endorsement) that isn't there. This is common when someone has accidentally programmed a status setting incorrectly. If you give me the details of the machine, I may be able to help
May 09, 2010 | Casio Parts Cash Register PC Desktop
Retail Supplies Logo
Top Retail Supplies Experts
Patrick Tinashe...
Are you a Retail Supply Expert? Answer questions, earn points and help others
