Question about Miller Welding Tools
I have a miller cp 200 that does not feed and the wiring was such a mess from feeding to trigger so can you show me the wiring and connections
4 Suggested Answers
  • 97 Answers
SOURCE: miller 175 trigger will not feed wire very
First thing make sure the lead cable is as straight as possible. and make sure the wire has a unobstructed path. then you should check the trigger input/output switch and see if the switch is getting power to it continuously. I hope this help please rate this thank you
Posted on Mar 15, 2010
  • 6 Answers
SOURCE: Wire feed does not stop. Not the trigger.
you have a problen with the electronic circuit.
Where are you?. Perhaps I can help you.
Posted on Aug 16, 2010
HansPP
  • 2510 Answers
SOURCE: i have a miller S-62
The switch in the trigger must have collapsed or the contacts have welded themselves closed. Strip the torch and check the trigger switch, it will probably have to be replaced, these things are seldom repairable.
Posted on Apr 14, 2011
Wire wont feed on my welder
I would call miller and get a number for the closest repair station. They have a three year parts and labor warranty. 1-920-735-4505
Jan 10, 2015 | Miller Multimatic 200 MIG TIG & Stick...
How do i fix "Trig Stuk" on my Miller welder?
Assuming the Trig Stuk is a message on a display tells me you have a later model welder. Try downloading the manual from Miller. Or if you're adventurous look at the trigger and see if it is stuck, take it apart, clear any debris blocking the trigger contact (preventing it from opening after the trigger is released). Check for cut or twisted wires and see if they are connected at the wire feed motor or has one come off? Is a piece of weld wire touching the motor feed connections?
Sep 03, 2014 | Welding Tools
Miller S-64 wire feeder won't feed wire
Just a thought, have you tried feeding the wire manually to see if there aren't any obstruction through to the handle or nozzle? Hope this helps
Feb 02, 2018 | Welding Tools
Spoolmate 100 wont feed
Check for binding int he inner sleeve first, then increase tension as long as feed motor spins. If feed motor does not spin check wiring to make sure it is connected correctly.
Sep 18, 2012 | Miller MATIC 180 MIG w/cart/AND SPOOLMATE...
My trigger to my millermatic 250 won't stop feeding the wire even when switch is not pressed
Does it feed with the trigger plug removed from the machine? If so, then it is a circuit board. If no, then wires shorted somewhere in the gun.
Apr 17, 2012 | Miller Welding Tools
Miller cricket 115 volt wire welder stock #909071. plug it in, it starts feeding wire...even when switch is off. where do i look?
The contactor is stuck closed, the trigger wiring in the cabinet is shorted together or trigger switch stuck closed.
Jan 09, 2012 | Miller Welding Tools
I have a miller S-62 wire feed, my problem is the wire feed is running, but im not touching the trigger. what is a solution to my problem?
Apr 14, 2011 | Garden
Miller 175 trigger will not feed wire very
Mar 15, 2010 | Welding Tools
Ck the feed roller contact relay
Jun 02, 2009 | Welding Tools
Renegase 180
This fault is typical in most MIG/MAG Units. the feed roller/s need slackening off, pull the trigger so the rollers spin wire the wire not moving, turn the tensioning 1 turn check to see if the wire feeds, if not give a half turn on the tentioner repeat this half turn untill the wire feeds, bend the wire to the torch and pull the trigger, If the wire feeds then thats the correct setting. be awear of all safety rules. use gloves
Nov 01, 2008 | Miller RENEGADE 180 WELDER GENERATOR MIG...
Welding Tools Logo
54 people viewed this question
Top Miller Welding Tools Experts
Robert Lee
Level 1 Expert
Kory Ronning
Jose Velazquez
Jose Velazquez
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
