Question about ARC Welding Tools
I have a TSM 200 A co2 welder that does arc before you trigger what are possible reasons that can cause that
SOURCE: no arc for craftsman professional wire feed welder
either your not grounded on the vehicle very good or you lost the ground either in your gun or on your clamp
Posted on Apr 15, 2009
  • 24 Answers
SOURCE: The wire at the tip of the mig gun strikes an arc
Sounds like the trigger is getting worn out.
Posted on Apr 24, 2009
SOURCE: My Lincoln 135 mig welder suddenly doesn't have enough arc
check the diodes that there not short or open circuit you will need a meter with diode test..
Posted on Aug 10, 2009
luxur4
  • 92 Answers
SOURCE: solar welder 2175 wire keeps feeding wont stop
Look on the front pannel. thier should be a "latching Switch" indicated by "4 X 2" little arrowes. The 4 is " pull the triger -- the release the arc continues, the "2" is pull the trigger and the arc startes release the trigger the arc stops simplesssssssss
Ken
Posted on Jan 26, 2010
justjordy33
SOURCE: can't fine a operate-parts manual for a chicago arc 180 welder
I would go ahead and contact someone with <a href="http://www.suburbanweldingandsteel.com">chicago welding</a> they really know will be great.
Posted on Aug 02, 2012
My millermatic 200 was working fine then all of sudden the wire would arc without pressing the trigger
you will need to open up the machine and find the relay / contactor chances are the contact are stuck together
Feb 18, 2015 | Welding Tools
Repair mig welder
Control circuit failure or blown fuse on low voltage power supply. Look for 24VAC transformer. If that is OK follow to the trigger contactor and see if it is disconnected, burnt, etc.
Aug 28, 2014 | Welding Tools
Very little power at wire
try to use bare .032 wire and co2 shielded gas, If the equipment does not have a gas solenoid you may have to wire a solenoid to the trigger mechanism to get the gas to flow while the wire is feeding. The bare wire usually copper coated burns much hotter than the flux core when there is a gas shield. Also a .032 bare wire with a gas shield burns a a lower amp range and will get better penetration.
You may have to experiment with the feed rate and gas flow to get the correct setting, but the bare wire has a lot less resistance to current flow than the flux core and will burn a lot hotter when you use a gas shield.
At 115 vac there is not a lot of amperage left to create an arc and run the feeder and the rest of the unit , and the flux core wire takes a lot of amperage to burn both the wire and the flux . .
Apr 03, 2014 | Campbell Hausfeld ® 115V MIG Flux Core...
One of the welds has broken on my silver cross linear chassis is there any way i can fix it myself or get it fixed regards Scott
Welding thin wall tubing requires skill and a special kind of welder. Google you local welding companies. Could have a problem if any plastic components are near to the break.
Dec 14, 2010 | Silver Cross Chassis - Apollo Stroller
My little 110 mig welder is arcing without trigger pulled
i believe that the trigger only send out the wire and does not control the arc the tip should be live as long as the welder is on
Feb 28, 2010 | Lincoln Welding Tools
Solar welder 2175 wire keeps feeding wont stop doesnot arc until trigger is pulled
Ken
Dec 14, 2009 | Welding Tools
The wire feed on my welder will not work.
Maybe you can get lucky like I did . Some times the acr volt selector switch gets corrosion in it and wont let the circuit board know to send power to the wire feed motor. You can cycle this arc volt. switch in my case it is the a,b,c,d,e, switch back and fourth a few times and this will brake the corrosion and your wire might feed again as mine did . This corrosion build up happens from not using and or sollecting the switch much usually on a welder at hm that gets very little use. it is common good luck .
Jul 24, 2009 | Lincoln Electric LINK2400-+2 CV-305 MIG...
WIRE FEED BUT NO ARC
Turn off welder, unplug and press trigger to discharge any possible stored juice. Then, open side door and check the ground cable where it connects inside, it sounds like either ground or the hot is off. Once you determine those are both securely attached, close door, plug in power on, attach ground clamp to test piece off metal and try it again. Let me know if this helps! Thanks:)
May 08, 2009 | Welding Tools
Welding Tools Logo
77 people viewed this question
Top ARC Welding Tools Experts
Craig Butler
Craig Butler
gerald martin
Level 1 Expert
Are you an ARC Welding Tool Expert? Answer questions, earn points and help others
