I can't fax out what happen? - Office Equipment & Supplies
How to repair a fax sensor. I can send faxes but not receive.
What happens when you use your cell-phone to dial the telephone-number of the FAX?
Does the number "ring" in your ear?
Does the display-panel on the HP show "incoming call" or "answering" ?
What happens?
What does not happen?
Feb 17, 2011 | HP Photosmart 3310 Printer
Is there a fax manual for this Canon Fax-jx200
http://www.usa.canon.com/cusa/support/consumer/copiers_fax/inkjet_fax/fax_jx200#BrochuresAndManuals
Dec 07, 2010 | Canon FAX-JX200
Fax sends certain pages in duplicate
If it only happens with that one vendor, the problem is almost certainly either on their end or somewhere in the interaction between the two fax machines.
The most likely answer is that their fax machine has a problem receiving some pages (either because the line is noisy or for another reason) so it has to reprint them. You could tell your vendor to try turning off error correction on their fax machine and see if that makes a difference.
Hope that helps.
Jul 05, 2010 | HP 920 Plain Paper Fax
Panasonic UF-490 Fax machine is sending more than one fax
You might have a job stuck in memory. Message window should say 00%. Try this press Function key press 7 key press monitor key slowly 4 times press * key press 6 key scroll down to ALL JOB CLEAR press SET wait for reboot Good Luck
Jun 05, 2009 | Panasonic Panafax UF-490 Plain Paper Laser...
Need access code to fax long distance, just started happening.
That would usually be your telephone service provider not the fax machine, if it is a business line, the permissions may have been changed. Check with your business communication administrator, or your local phone service provider.
Hope this is of some help.
ed
May 18, 2009 | Brother FAX-575 Plain Paper Thermal
Cannot get messages out of memory
We switch our off, wait 10 seconds, switch on & fax is printed. We don't think we have lost any faxes this way but be aware it might happen.
Jan 29, 2009 | OKIFAX 4580 Plain Paper LED Fax
Sending error
I try sending a fax then the paper goes through it makes a loud beep and the message says theres been an error try again this happens all the time no matter who I fax. then it prints out error confirmation stating Mode G3 send error
Jul 29, 2008 | HP 1040 Plain Paper Inkjet Fax
Hi, Remote Fax Error being displayed
What happens if you dial the remote fax number as a voice call on another phone? Does that number pick up? Does it give you the modem handshake noise? If not, the remote side has a problem.
Can you fax other numbers? What happens when you dial your own fax line from another phone? If your fax does not pick up and talk to you, your fax may have a problem.
Jul 24, 2008 | Dell 962 Photo All-In-One InkJet Printer
Phone calls get cut off and fax goes into recieve mode
If you are using the fax as both for calls and receiving faxes make sure you have the fax set up to FAX/TEL mode. This should solve your problem.
May 22, 2008 | Canon FAXPHONE L80 Laser
Can't send faxes - Panasonic KX-FPG372 Fax machine
THE PHONE SEEMS TO BE GETING DISTORTED ,IT MAY BE IN THE PATH OF THES DIGITAL BOXES. PLS CHANGE THE LINE OR LOACTION HAPPY FAXING OMNIPRESENT
Sep 07, 2007 | Panasonic KX-FPG372 Plain Paper Thermal...
23 people viewed this question
jasbo
jasbo
