Question about Electrical Supplies
My Homelite 720 watt Generator has no spark - Electrical Supplies
wireguy212
  • 1627 Answers
SOURCE: My 5250 watt Power Back generator will not start,
Have you check the engine oil level?If it is down on oil you won't get spark because of the oil level switch shutting the ignition down to protect it's self.
Posted on Jan 22, 2010
  • 56 Answers
SOURCE: I need a manuel for
I hope I can Help!
Is this the manual that you are looking for? If so, you should be able to download it in chrome or firefox quite easily. Just let the pdf load (it will take a minute). Then, hover your mouse near the bottom middle of the page. You should see a little toolbar come up. You can print or save it from there. I would send you the file directly, but cannot do so here. Let me know if that helps!
http://www.homelite.com/product_manual/file_url/135/HG3500_359_trilingual.pdf
Posted on Jun 02, 2011
heatman101
  • 43501 Answers
SOURCE: Our Homelite model 5500 generator
The problem when that happens is usually a loss of residual magnetism...by flashing the generator you can recharge the permanent magnets, and then the generator will work again.
Generator Flashing
This link gives one way to do it.. there are others if your google it...look a few posts down to find the procedure...
heatman101
Posted on Jun 08, 2011
  • 15 Answers
SOURCE: power craft 720 watt petrol generator not producing AC, but engine running fine and ac reset in correct position? What could it be
TRY THE DINAMO OR MAY JUST BE A LOSE WIRE OR BROKEN
Posted on Jan 28, 2012
elie2011
SOURCE: Why won't my Homelite 720 watt Generator start?
hi am elie hawzi i have generator 720wat homeliet had to run wer can i put 2 storc oil in my generator pleas do you have any adia haw can i leave the generator run stridaway thanks for fixya
Posted on Sep 16, 2012
Has gas in bowl and fire but wont start without starting fluid
McCulloch u spray starter fluid Power Generators Questions ...
www.fixya.com > Forum > Tags > u spray starter fluid > Power Generators
McCulloch power generators u spray starter fluid related questions and ... Question about 13HP 338 Cc Portable Generator # FG6000MK ... My 5700 watt 11 HPMcCullough generator wont ... My generator will start if I spray it with either but won'tstay running in less I keep ... The bowl has gas in it and the needle is clean.
This generator McCulloch fg6000mk 11hp has no spark. I've ...
www.fixya.com/.../t7785814-generator_mcculloch_fg6000mk_11hp_no
Jan 13, 2011 - this generator McCulloch fg6000mk 11hp has no spark. I've checked the gas bowl , a small amount of water in the - McCulloch ... water in the bowl not much also sprayed a small amount of starting fluid in .... My 5700 watt 11 HPMcCullough generator wont start. I'm getting good gas to the plug but no spark.
Won't start. I have a never used McCulloch 5700 11HP ...
www.dqrkc.com/support/t1325485-start
Dec 2, 2008 - Question about McCulloch 13HP 338 Cc Portable Generator # ...evaporated. you might tryt a little spray starter fluid in the spark plug ... My generatorwill start if I spray it with either but won't stay running in ... The bowl has gas in it and the needle is clean. ... My 5700 watt 11 HP McCullough generator wont.
1325485 Won't start. I have a never used McCulloch 5700
Jan 21, 2016 | McCulloch 11 HP 5700 WATT GENERATOR
Homelite HG600 Lightnin'bug generator. Where can I get an owner's manual?
Homelite Vintage Camping Generator - HG600 Lightnin Bug ...
? 1:23
www.youtube.com/watch?v=Amq5VLOsiN8
May 6, 2014 - Uploaded by david lum
For Sale: Great Generator 500 watts - quiet - looks like new - starts easily. Complete with owners manual.
Sep 25, 2015 | Electrical Supplies
4500 running watts 5625 starting watts
http://www.manualowl.com/p/Homelite/HGCA4500/Manual/185973
Mar 23, 2015 | Watts Electrical Supplies
Gasoline generator homelite 4400 watt will not run getting gas spark plug is fireing but will not start..
If it has sat for a while, empty the carb. float chamber, flush out with clean fresh petrol. Make sure fresh petrol is in the tank and try again.
May 13, 2014 | Briggs & Stratton Briggs and Stratton...
Jun 28, 2012 | Electrical Supplies
I have a homelite 720 generator but cant fingd the instruction manual and i need to know if the charger leads only charge a battery or can be used as jump leads i know this might sound stupid but i wo
I can't find any reference to a Homelite model 720 generator but most battery charging systems do not supply enough amps to run a car starter. Battery chargers usually work in the two (trickle) to ten amp range. Car starters need way more amps to have enough power to turn an engine over, depending on the size and number of cylinders in the motor. Some chargers have a switch with a 60 amp 'start' position to help the battery turn the motor over, but without that there is little chance the charger side of your generator will supply enough amps to help your battery.
Feb 21, 2012 | Cars & Trucks
My 5250 watt Power Back generator will not start, and their is no spark at the spark plug.
Jan 22, 2010 | Groove Tubes Power Back 5,250-Watt...
Homelite 2500 pwer generator won't keep running when cord put into it
The load may be too much for the generator. Remember that some loads, especially those with motors driving a machine (like air compressors) require much higher startup power than what is listed on the nameplate. General rule of thumb is to allow 2-3 times nameplate rating for generator rating. For example. If your air conditioner is rated as 800 watts, then you would want a genreator AT LEAST 2400 watts to start and run the compressor.
Nov 30, 2009 | Electrical Supplies
Electrical Supplies Logo
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
